djrhineh
#1 Posted : Sunday, December 28, 2014 4:59:00 PM(UTC)
djrhineh
I have a Whirlpool WFG361LVS1 gas range that would will not always light when using the bake cycle, sometimes it worked fine other times it did not. Then all of a sudden the bake and broil quit working altogether. I did some research and determined it was the Gas-Valve by checking the resistance and found it was at the bottom of the limit (198 ohms), I ordered one from AppliancePartsPros.com. I changed out the parts and it worked awesome for 5 or 6 times and now its back to the bake cycle working sometimes. Clicks 4 times and shuts off if it does not light on the first try.
What should I do next. The new part has the same same resistance reading as the old part I replaced (198 ohms). Could the new part gone bad already, or do I have another problem. Do I need to order a Spark Module or a Spark Electrode.
Is there a way to test the Spark Module. Any help is appreciated, I am getting really frustrated.
djrhineh
#2 Posted : Thursday, January 1, 2015 4:41:14 PM(UTC)
djrhineh
Please help I am getting frustrated and don't know what to do
