I have a really old GE double oven. The bottom oven works fine, but the top doesn't work.
The "On" lights turn on when it's set to Broil but it doesn't heat up. And when the knob is turned to Bake, the "On" light only flashes on and then goes back off, and it doesn't heat up.
So I'm thinking both the elements need to be replaced. Does that sound accurate or could it be something else?
Anyone have any ideas or thoughts?
Thanks in advance!
