Discuss
check oven sensor
 in
How do check and change the oven sensor.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » check oven sensor
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-18-2008, 09:38 AM
Jamie Cantrell Jamie Cantrell is offline
Junior Member
Jamie Cantrell is on a distinguished road
Default check oven sensor
Model Number: jdp36gp1   Brand: GE   Age: More than 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-18-2008, 05:56 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Before we will proceed with the test and replacement procedures I would like to know why you believe there is a problem with the oven sensor.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 06-30-2008, 03:26 PM
jmbinjax jmbinjax is offline
Junior Member
jmbinjax is on a distinguished road
Default Oven Sensor?
I have the exact same range and I'm thinking I need the oven sensor also. The oven heats but does not heat to the temperurature indicated on the display. Both elements work. If I place an oven thermometer in the oven and set the oven to 400 degrees, the temperature gets to only about 200 degrees but the oven stops heating as if it thinks it's at 400 degrees. I'm thinking the oven sensor is bad. Is there anyway to check the sensor and is it easily replaced?
Thanks!!!
  #4 (permalink)
Old 06-30-2008, 04:19 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
jmbinjax,
What is the complete model number of the unit?
__________________
  #5 (permalink)
Old 06-30-2008, 05:33 PM
Junior Member
Default
Gene:
I believe it is JDP36GP1. I don't have immediate access to the unit, it is in my parents house.
  #6 (permalink)
Old 06-30-2008, 07:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the rear cover, locate the two sensor wires coming to the control board and measure the sensor resistance. It suppose to be about 1100 Ohms at the room temperature.
If the reading is correct then the control board has to be replaced. Unfortunately this part is no longer available.
If the reading is wrong then located the sensor plug (where it's coming through the back panel), unplug it and measure the sensor resistance at this plug.
If the reading is wrong then replace the sensor.
If the reading is correct then the problem is a bad wire harness and/or sensor plug.
- The part number for the oven sensor is AP2023670
__________________
  #7 (permalink)
Old 07-01-2008, 03:35 AM
Junior Member
Default
Thank you!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How To Check Continuity With Ohmmeter Admin / APP Team Oven Repair (including Ranges and Cooktops) 13 07-16-2008 12:59 PM
Replacing oven sensor Jemper Oven Repair (including Ranges and Cooktops) 6 06-16-2008 02:51 PM
To check defrost heater don419 Refrigerator & Freezer Repair 2 02-26-2008 08:51 PM
temp sensor or oven control board? Mike523 Oven Repair (including Ranges and Cooktops) 1 12-17-2007 08:29 PM
How can I check the relay and/or cap frepair Refrigerator & Freezer Repair 1 10-18-2007 07:37 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
