Discuss
Thermador Convection Oven No Heat
 in
I have a Thermador electric double oven Model number SC302TB. The top oven has the convection option. The top oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador Convection Oven No Heat
  #1 (permalink)
Old 02-18-2008, 10:02 AM
rxrep rxrep is offline
Junior Member
rxrep is on a distinguished road
Default Thermador Convection Oven No Heat
Model Number: Sc302TB   Brand: Thermador   Age: 1 - 5 years
I have a Thermador electric double oven Model number SC302TB. The top oven has the convection option. The top oven will get hot if Bake is selected but won't heat up if you choose convection. The fan spins but no heat. Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-18-2008, 06:52 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Remove the cover for the convection heating element (#15 on the convection module break down diagram).
Visually inspect the heating element for any burned spots.
Replace the convection heating element if any burned spots found.
Remove the screws holding the convection heating element and carefully pull the heating element out as far as wires will go. Remove the wire(s) from one of the heating element terminals and check the heating element for continuity.
Replace the convection heating element if it's open.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter.
- The part number for the convection heating element is AP2834569
Here are the break down diagrams for the Thermador oven Model SC302T
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-18-2008, 07:33 PM
Junior Member
Default
THANK YOU. I will let you know how I make out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave Convection Oven bc9ltjj Microwave Repair 4 01-03-2008 10:45 AM
Convection Oven not heating well russ hibbeler Oven Repair (including Ranges and Cooktops) 3 12-11-2007 12:17 PM
Caloric Convection Oven caloricgold Oven Repair (including Ranges and Cooktops) 0 09-03-2007 07:45 PM
micro wave convection oven bobalo Microwave Repair 1 08-21-2007 03:10 AM
Convection Oven wedofood Oven Repair (including Ranges and Cooktops) 0 08-14-2007 01:01 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
