[COLOR="Indigo"]I am having problems with my stove both cooktop and oven. When I light the pilot light on the left it lights fine but the right one will not light. If I light the right one first it will not light unless you hold your finger over the left one. When you take your finger off the flame goes out. If you turn up the pilot lights all of the way they will both light and the flames will pulsate back and forth. With the oven when you light the pilot light it stays lit and when you turn the oven on the flame of the pilot light gets high along with the rest of the flames and the flames are yellow. When I try to adjust the pilot light on the oven it seems like there is only off or on high. What would cause this to happen?:confused: :confused: :confused: [/COLOR]
