My gas range wont light. I checked the igniter it was pulling 3.0 amps so I replaced it. It still doesn't light. The new igniter pulls 3.5 amps so it must not be the igniter. Everything I can find online says to test the igniter, but not what to do if it checks good. So what do I do now? The range works but not the broiler or the oven. Thanks Pat
