Discuss
Frigidaire error F-9
 in
Range was working fine (oven and stovetop) until I tried to use the clean mode. The display looks like it'
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire error F-9
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-18-2008, 08:35 AM
fix it mom fix it mom is offline
Junior Member
fix it mom is on a distinguished road
Default Frigidaire error F-9
Model Number: unsure   Brand: Frigidaire   Age: 5 - 10 years
Range was working fine (oven and stovetop) until I tried to use the clean mode. The display looks like it's going to work, but there is a faint 'clattering' noise, the door doesn't lock, and it finally displays an F-9 error code. None of the buttons respond and none of the stovetop dials will move. I tried to reset it by flipping the breaker and leaving the power off for a few minutes, but it goes right back to the same cycle of appearing to start the clean process, and never makes it - only back to the F-9 error (so now I can't use it at all!). This range is at our weekend home and I neglected to get the model number off of it before returning to our regular home. It's a stainless convection range, smooth top, approx. 7-8 years old. Help if you can!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-18-2008, 05:26 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The "F9" error code means the EOC (electronic oven control) has found the lock motor switches to be out of sequence or shorted.
Test switches and if there is nothing wrong then replace the EOC.
In order to provide more accurate information I need the complete model number of the unit. You can find it on the frame behind the bottom drawer.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 02-18-2008, 06:25 PM
Junior Member
Default Thank you!
Thanks, Gene. I'll give it a whirl
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F3 Error on Frigidaire over the range microwave dignupfax Microwave Repair 2 01-29-2008 09:26 PM
2H Error qsac226 Dishwasher Repair 0 01-21-2008 06:35 PM
Frigidaire Oven F3 error code sbochen Oven Repair (including Ranges and Cooktops) 2 01-08-2008 08:38 AM
F8 error Frigidaire double oven jps Oven Repair (including Ranges and Cooktops) 3 12-20-2007 01:14 PM
Frigidaire Gallery Range FP5 Cooktop Error dmccoy Oven Repair (including Ranges and Cooktops) 0 09-21-2007 07:00 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
