Hello, I have a Bosch electric Stove (Model # HES245U/01) that has worked great for years. About a month ago it started having 2 problems. \
1.) Top Burners will Not remain lit or powered up. When you first turn any one of them on, they heat up quickly as usual, but then turn off by themselves within 20 seconds. It is impossible to cook anything on them as you have to continually turn them back on every 20 seconds. The oven itself is working fine, no problem heating up at all.
2.) Excessive beeping sounds are emitted every 60 seconds. Sometimes it may beep every 15 seconds, it varies. I have to keep it turned off at the breaker panel because my wife can not take those beeps anymore.
Any help you can give me on these 2 issues would be greatly appreciated, Thank You
