Mck236
#1 Posted : Saturday, October 18, 2014 8:06:46 PM(UTC)
Mck236
Experienced a spike in electricity from a neighborhood transformer that caused the clock timer control board to burn out. After replacing this ($$) part, have thrown the breaker back on and the only working part on the oven is the lightbulb!
My question is; what additional part should I investigate next?
Any additional help would be appreciated
#2 Posted : Sunday, October 19, 2014 1:15:52 AM(UTC)
Parts for Frigidaire PLEB30T8CCB Oven - AppliancePartsPros.com
Looks like the oven lamps work off of L2 to Neutral.
The control board etc work of of L1 to Neutral so I would start by checking the power, perhaps you have lost the L1 side of the line.
The below is for a range and if your unit is hard wired then there will not be a wall receptacle so the checks will be a littke different.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Mck236
#3 Posted : Saturday, November 15, 2014 1:34:33 PM(UTC)
Mck236
Denman
Thank you!
Pulled the breaker and worked my way back through the wiring as you had suggested. Problem was on the L1 side as you had thought. Thank you my friend, oven works fine due to your expertise.
#4 Posted : Sunday, November 16, 2014 2:00:18 AM(UTC)
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Whirlpool Double Oven not working (Oven Repair (including Ranges and Cooktops))
by velazedv 6/16/2015 12:16:58 PM(UTC)
Thermador Double Oven not working properly (Oven Repair (including Ranges and Cooktops))
by rxrep 12/28/2014 10:32:11 AM(UTC)
Maytag Gemini Double oven not working (Oven Repair (including Ranges and Cooktops))
by MTODD101 11/14/2014 1:01:34 PM(UTC)
double oven not working (Oven Repair (including Ranges and Cooktops))
by dmstelk 1/9/2010 7:55:03 PM(UTC)
GE double oven not working (Oven Repair (including Ranges and Cooktops))
by bigreed67 2/19/2009 9:25:52 PM(UTC)
