I am replacing the control board but can't remove two of the wire connectors. They have white plastic sleeves that insert onto the flat posts on the old control board. I don't see a clip or anything that would release the connector and have pulled pretty hard, yet they do not pull off. I noticed on the new control board the flat posts have holes in the center. Is there a trick to releasing the connectors?
Kevin
