Discuss
control board display on
 in
display does not flash..does not show error code...all numbers display...and stay lit. coincidently,my furnace went out
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » control board display on
  #1 (permalink)
Old 02-17-2008, 04:38 PM
phillip melton phillip melton is offline
Junior Member
phillip melton is on a distinguished road
Default control board display on
Model Number: jsp26bw3ad   Brand: GE   Age: 5 - 10 years
coincidently,my furnace went out same day.. repairman replaced control board.
left power off full day..did not solve problem..
any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-18-2008, 02:39 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Phillip,
If you've tried to push the "cancel" or the "clock" buttons and it did not help then the control board has to be replaced.
- The part number for the control board is AP2633034
- The part number for the overlay (clock plate) is AP2025221
Here are the break down diagrams for the GE range Model JSP26BW3AD
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-18-2008, 05:16 PM
Junior Member
Default
thank u gene for prompt reply...I pulled up the part number and it says a qualified tech might be needed...due to some model changes..should I try this myself?? I do not fear any plumbing job,(i can always take a shower..electricity is another matter...
phil
  #4 (permalink)
Old 02-18-2008, 05:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Phil,
I would recommend to order the part first. In most cases it comes with the installation instructions. If not, you can call a tech later and still save on the part.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Control panel in fridge does not display BobD Refrigerator & Freezer Repair 1 06-08-2008 05:11 AM
Control board ckshan Oven Repair (including Ranges and Cooktops) 0 02-13-2008 08:02 AM
control panel display edouard thai Oven Repair (including Ranges and Cooktops) 3 11-15-2007 11:15 PM
Control board? rod Dishwasher Repair 1 11-05-2007 07:30 PM
Sharp R-310FW display board Clark-bar Microwave Repair 1 08-01-2007 04:01 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
