Discuss
F3 Error Code
 in
RCA electric stove model no. L3S340GL0. Oven quit working, flashes F3 code only, push reset button. Unhooked power attempting to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » F3 Error Code
  #1 (permalink)
Old 02-17-2008, 12:22 PM
Eva Eva is offline
Junior Member
Eva is on a distinguished road
Default F3 Error Code
Model Number: L3SE40GL0   Brand: GE   Age: 1 - 5 years
RCA electric stove model no. L3S340GL0. Oven quit working, flashes F3 code only, push reset button. Unhooked power attempting to reset stove. Replaced oven tempurature sensor, electronic oven control assembly. Still getting F3 code. Any suggestions?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-18-2008, 12:27 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Eva,
Pull the range, remove the rear cover and check the sensor wire harness from the sensor plug to the control board.
Eliminate the sensor plug and hardwire it, using the high temperature porcelain wire nuts (AP3440522).
Check the sensor plug at the control board for tight connection.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
cannot get rid of error code C4 donna58 Dishwasher Repair 1 02-16-2008 02:08 PM
Error Code F2 startz Oven Repair (including Ranges and Cooktops) 1 12-21-2007 11:05 AM
error code 01 platini Washer Repair 5 11-29-2007 12:29 PM
Error Code F2 mrcclc Oven Repair (including Ranges and Cooktops) 2 11-25-2007 07:34 AM
F 1 Error Code Frogburk Oven Repair (including Ranges and Cooktops) 1 08-29-2007 03:10 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
