| » F3 Error Code |
Model Number: L3SE40GL0 Brand: GE Age: 1 - 5 years
RCA electric stove model no. L3S340GL0. Oven quit working, flashes F3 code only, push reset button. Unhooked power attempting to reset stove. Replaced oven tempurature sensor, electronic oven control assembly. Still getting F3 code. Any suggestions?
Hi Eva,
Pull the range, remove the rear cover and check the sensor wire harness from the sensor plug to the control board. Eliminate the sensor plug and hardwire it, using the high temperature porcelain wire nuts (AP3440522). Check the sensor plug at the control board for tight connection. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
| Display Modes | |
| cannot get rid of error code C4 | donna58 | Dishwasher Repair | 1 | 02-16-2008 02:08 PM |
| Error Code F2 | startz | Oven Repair (including Ranges and Cooktops) | 1 | 12-21-2007 11:05 AM |
| error code 01 | platini | Washer Repair | 5 | 11-29-2007 12:29 PM |
| Error Code F2 | mrcclc | Oven Repair (including Ranges and Cooktops) | 2 | 11-25-2007 07:34 AM |
| F 1 Error Code | Frogburk | Oven Repair (including Ranges and Cooktops) | 1 | 08-29-2007 03:10 PM |
