Discuss
slight gas odor
 in
I have an Amana range ARGS7650WW (propane) Recently, we've noticed an ever so slight gas odor coming from it when
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » slight gas odor
  #1 (permalink)
Old 08-22-2014, 03:46 PM
Junior Member
chrisbloke is on a distinguished road
Default slight gas odor
Brand: Amana   Age: More than 10 years
Recently, we've noticed an ever so slight gas odor coming from it when it is not being used. I think I've narrowed it down to coming from one of the valves. (sniff test).
I guess I'm wondering if anyone else has had this issue. I assume I will need to replace the valve but I'd like to know if it is the likely problem. I've sprayed LeakCheck all over it but don't see any bubbles, but the stem that the knob goes onto (where I'm smelling the gas) protrudes out through plastic so it's difficult to get the spray in there.
Has anyone else had this problem?
Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Slight burning smell in Kitchenaid davet18 Washer Repair 1 09-14-2013 01:52 PM
DW won't fill, slight leak underneath tgrenchik Dishwasher Repair 3 11-30-2011 11:07 PM
smells like a vacumn or slight burning jvanpay Washer Repair 0 08-25-2009 12:21 PM
slight grinding, no agitation or spin oilspot Washer Repair 9 12-12-2008 09:39 AM
GE Spacemaker II no heat slight electrical odor live4soccer7 Microwave Repair 13 11-19-2008 03:30 PM
