GE Electric Glass Top - Flash Under Glass top and circuit tripeed
I've done a number of repairs on this glass top successfully. I've replaced a burner element, and a switch without
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Electric Glass Top - Flash Under Glass top and circuit tripeed
  #1 (permalink)
Old 08-18-2014, 01:34 PM
Junior Member
rehdwolfe is on a distinguished road
Default GE Electric Glass Top - Flash Under Glass top and circuit tripeed
Model Number: Jp355w0k1ww   Brand: GE   Age: 5 - 10 years
I've replaced a burner element, and a switch without problem.
The latest problem was the indicator light was staying on even when all knobs were off.
I replaced the light (which looked burned out). This worked for a while (maybe 30 minutes or so) then i observed a bright flash, an audible "pop" and the unit tripped the circuit breaker.
Looking at this site and applianceassistance.com it seems like a short is the likely cause. I've read about testing for continuity with a volt meter.
My questions are:
* Is this a likely diagnosis ?
* Do I test the wires for continuity as well ? If so, should wires offer resistance with no power and how much ?
Related Models
General Electric JP355WK1WW Electric range
General Electric JP356BM1BB Electric range
General Electric JP356SM1SS Electric range
General Electric JP356WM1WW Electric range
General Electric JP360AV1AA Electric range
General Electric JP360BV1BB Electric range
General Electric JP360WV1WW Electric range
General Electric JP362B9K1 Electric range
General Electric JP362B9N1 Electric range
General Electric JP370B9K1 Electric range
General Electric JP370B9K2 Electric range
General Electric JP370B9K3 Electric range
General Electric JP370B9K4 Electric range
General Electric JP372B9K1 Electric range
General Electric JP372B9K2 Electric range
General Electric JP372B9K3 Electric range
General Electric JP372B9K4 Electric range
General Electric JP372B9K5 Electric range
General Electric JP372B9N1 Electric range
General Electric JP373B1K1 Electric range
General Electric JP373B1K2 Electric range
General Electric JP373B1K3 Electric range
General Electric JP373B1N1 Electric range
General Electric JP378B9K1 Electric range
General Electric JP378B9K2 Electric range
General Electric JP378B9N1 Electric range
General Electric JP380BVBB Electric range
General Electric JP3812L1 ELECTRIC COOKTOP
General Electric JP383B9R1BC Electric range
General Electric JP383B9T1BC Gas range
General Electric JP384 9T1BL
General Electric JP3849R1BL Electric range
General Electric JP3849T1BL Electric range
General Electric JP385 9T1WH
General Electric JP3859R1WH Electric range
General Electric JP3859T1WH Electric range
General Electric JP385BD1BB Range accessory
General Electric JP385BV1BB Range accessory
General Electric JP385CV1BC Range accessory
General Electric JP385WD1WW Range accessory
General Electric JP385WV1WW Range accessory
General Electric JP386B9R1BC Electric range
General Electric JP386B9T1BC Gas range
General Electric JP387B1T1BC Gas range
General Electric JP387T1BB Range accessory
General Electric JP387T1WW Range accessory
General Electric JP388 9T1BL
General Electric JP3889R1BL Electric range
General Electric JP3889S1BL Electric range
General Electric JP3889T1BL Electric range
General Electric JP389 9T1WH
General Electric JP3899R1WH Gas range
General Electric JP3899S1WH Electric range
General Electric JP3899T1WH Electric range
General Electric JP389BD1BBC Range accessory
General Electric JP389BJ1BB Range accessory
General Electric JP389WD1WWC Range accessory
General Electric JP389WJ1WW Range accessory
General Electric JP392R Electric range
General Electric JP393R Electric range
General Electric JP620N1 Electric range
General Electric JP621BN1 Electric range
General Electric JP622R1AD Electric range
General Electric JP622R1WH Electric range
General Electric JP623BR1BC Electric range
General Electric JP626AV1AA Electric range
General Electric JP626AV2AA Electric range
General Electric JP626BJ1BB Electric range
General Electric JP626BJ2BB Electric range
General Electric JP626BK1BB Electric range
General Electric JP626BK2BB Electric range
General Electric JP626CC1CC Electric range
General Electric JP626CF1CC Electric range
General Electric JP626CF2CC Electric range
General Electric JP626CK1CC Electric range
General Electric JP626CK2CC Electric range
General Electric JP626WF1WW Electric range
General Electric JP626WF2WW Electric range
General Electric JP626WK1WW Electric range
General Electric JP626WK2WW Electric range
General Electric JP626WV1WW Electric range
General Electric JP626WV2WW Electric range
General Electric JP651*C1 Electric range
General Electric JP651*J1 Electric range
General Electric JP651*J2 Electric range
General Electric JP6510J2 ELECTRIC COOKTOP
General Electric JP6519*C1 Electric range
General Electric JP6519C1 Electric range
General Electric JP651B*C1 Electric range
General Electric JP651B*J1 Electric range
General Electric JP651B*J2 Electric range
General Electric JP651B0J2 ELECTRIC COOKTOP
General Electric JP651B9C1 Electric range
General Electric JP655BK1BB Electric range
General Electric JP655BM1BB Electric range
General Electric JP655SK1SS Electric range
General Electric JP655SM1SS Electric range
General Electric JP655TK1WW Electric range
General Electric JP655TM1WW Electric range
General Electric JP656*C1 Electric range
General Electric JP656*C2 Electric range
General Electric JP656*C3 Electric range
General Electric JP6560C3 ELECTRIC COOKTOP
General Electric JP656B*C1 Electric range
General Electric JP656B*C2 Electric range
General Electric JP656B*C3 Electric range
General Electric JP656B0C3 ELECTRIC COOKTOP
General Electric JP658T1BB Electric range
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
White Flash Under Glass Cooktop KatKat Oven Repair (including Ranges and Cooktops) 1 05-21-2013 06:17 PM
GE glass top electric stove rgotcliffe Oven Repair (including Ranges and Cooktops) 0 01-17-2011 10:13 AM
Door glass shattered, does a repair person need to install the new glass? DonnaMarie Oven Repair (including Ranges and Cooktops) 1 12-11-2010 05:20 AM
Glass oven door glass is dirty between the two glass mhobbs Oven Repair (including Ranges and Cooktops) 3 09-29-2010 09:17 AM
Glass Door replacement part search leads to wrong glass! hundoracer Oven Repair (including Ranges and Cooktops) 2 11-20-2009 09:20 PM
