Discuss
Locations of Gas Oven Ignitor
 in
I picked up Part no. 12400035 ignitor. I do not know where to find the part in the oven to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Locations of Gas Oven Ignitor
  #1 (permalink)
Old 10-24-2009, 04:18 PM
Junior Member
Fixitup is on a distinguished road
Default Locations of Gas Oven Ignitor
Model Number: 30-2769-00   Brand: Tappan   Age: More than 10 years
I picked up Part no. 12400035 ignitor. I do not know where to find the part in the oven to remove and replace with this part no. I read about the GE was located under the oven bottom panel. Is this the same location to replace the part for the Tappan, I purchased this stove 11/3/1989. Pleas Help. Thank you.
Ads By Google
Related Models
Frigidaire 30-2769-00-01 Tap(v1) / Gas Range
Frigidaire 30-2769-00-02 Tap(v3) / Gas Range
Frigidaire 30-2769-23-01 Tap(v2) / Gas Range
Frigidaire 30-2769-23-02 Tap(v4) / Gas Range
Frigidaire 30-3026-00-01 Tap(v1)
Frigidaire 30-3026-00-02 Tap(v2)
Frigidaire 30-3026-00-03 Tap(v3)
Frigidaire 30-3026-00-04 Tap(v4)
Frigidaire 30-3026-23-01 Tap(v5)
Frigidaire 30-3026-23-02 Tap(v6)
Frigidaire 30-3026-23-03 Tap(v7)
Frigidaire 30-3026-23-04 Tap(v8)
Frigidaire 30-3036-00-01 Tap(v9)
Frigidaire 30-3036-00-02 Tap(v10)
Frigidaire 30-3036-00-03 Tap(v11)
Frigidaire 30-3036-00-04 Tap(v12)
Frigidaire 30-3036-23-01 Tap(v13)
Frigidaire 30-3036-23-02 Tap(v14)
Frigidaire 30-3036-23-03 Tap(v15)
Frigidaire 30-3036-23-04 Tap(v16)
Frigidaire 30-3053-00-01 Tap(v1) / Gas Range
Frigidaire 30-3053-00-02 Tap(v1) / Gas Range
Frigidaire 30-3053-00-03 Tap(v1) / Gas Range
Frigidaire 30-3053-00-04 Tap(v1) / Gas Range
Frigidaire 30-3053-23-01 Tap(v2) / Gas Range
Frigidaire 30-3053-23-02 Tap(v2) / Gas Range
Frigidaire 30-3053-23-03 Tap(v2) / Gas Range
Frigidaire 30-3053-23-04 Tap(v2) / Gas Range
Frigidaire 30-3147-00-01 Tap(v1) / Gas Range
Frigidaire 30-3147-00-02 Tap(v4) / Gas Range
Frigidaire 30-3147-00-03 Tap(v7) / Gas Range
Frigidaire 30-3147-23-01 Tap(v2) / Gas Range
Frigidaire 30-3147-23-02 Tap(v5) / Gas Range
Frigidaire 30-3147-23-03 Tap(v8) / Gas Range
Frigidaire 30-3147-66-01 Tap(v3) / Gas Range
Frigidaire 30-3147-66-02 Tap(v6) / Gas Range
Frigidaire 30-3147-66-03 Tap(v9) / Gas Range
Frigidaire 30-3148-00-01 Tap(v1) / Gas Range
Frigidaire 30-3148-00-02 Tap(v4) / Gas Range
Frigidaire 30-3148-00-03 Tap(v7) / Gas Range
Frigidaire 30-3148-23-01 Tap(v2) / Gas Range
Frigidaire 30-3148-23-02 Tap(v5) / Gas Range
Frigidaire 30-3148-23-03 Tap(v8) / Gas Range
Frigidaire 30-3148-66-01 Tap(v3) / Gas Range
Frigidaire 30-3148-66-02 Tap(v6) / Gas Range
Frigidaire 30-3148-66-03 Tap(v9) / Gas Range
Frigidaire 30-3152-00-01 Tap(v1) / Gas Range
Frigidaire 30-3152-00-02 Tap(v1) / Gas Range
Frigidaire 30-3152-00-03 Tap(v1) / Gas Range
Frigidaire 30-3152-00-04 Tap(v2) / Gas Range
Frigidaire 30-3152-23-01 Tap(v2) / Gas Range
Frigidaire 30-3152-23-02 Tap(v2) / Gas Range
Frigidaire 30-3152-23-03 Tap(v3) / Gas Range
Frigidaire 30-3152-23-04 Tap(v4) / Gas Range
Frigidaire 30-3226-00-01 Tap(v17)
Frigidaire 30-3226-00-02 Tap(v18)
Frigidaire 30-3226-00-03 Tap(v19)
Frigidaire 30-3226-00-04 Tap(v20)
Frigidaire 30-3226-23-01 Tap(v1) / Gas Range
Frigidaire 30-3226-23-02 Tap(v2) / Gas Range
Frigidaire 30-3226-23-03 Tap(v3) / Gas Range
Frigidaire 30-3226-23-04 Tap(v4) / Gas Range
Frigidaire 30-3236-00-01 Tap(v5) / Gas Range
Frigidaire 30-3236-00-02 Tap(v6) / Gas Range
Frigidaire 30-3236-00-03 Tap(v7) / Gas Range
Frigidaire 30-3236-00-04 Tap(v8) / Gas Range
Frigidaire 30-3236-23-01 Tap(v9) / Gas Range
Frigidaire 30-3236-23-02 Tap(v0) / Gas Range
Frigidaire 30-3236-23-03 Tap(v1) / Gas Range
Frigidaire 30-3236-23-04 Tap(v2) / Gas Range
Frigidaire 30-3341-00-01 Tap(v1) / Gas Range
Frigidaire 30-3341-00-02 Tap(v1) / Gas Range
Frigidaire 30-3341-00-03 Tap(v1) / Gas Range
Frigidaire 30-3341-00-04 Tap(v3) / Gas Range
Frigidaire 30-3341-23-01 Tap(v2) / Gas Range
Frigidaire 30-3341-23-02 Tap(v2) / Gas Range
Frigidaire 30-3341-23-03 Tap(v2) / Gas Range
Frigidaire 30-3341-23-04 Tap(v4) / Gas Range
Frigidaire 30-3342-00-01 Tap(v1) / Gas Range
Frigidaire 30-3342-00-02 Tap(v1) / Gas Range
Frigidaire 30-3342-23-01 Tap(v2) / Gas Range
Frigidaire 30-3342-23-02 Tap(v2) / Gas Range
Frigidaire 30-3347-00-01 Tap(v1) / Range
Frigidaire 30-3347-00-02 Tap(v4) / Range
Frigidaire 30-3347-00-03 Tap(v1) / Gas Range
Frigidaire 30-3347-23-01 Tap(v2) / Range
Frigidaire 30-3347-23-02 Tap(v5) / Range
Frigidaire 30-3347-23-03 Tap(v2) / Gas Range
Frigidaire 30-3347-66-01 Tap(v3) / Range
Frigidaire 30-3347-66-02 Tap(v6) / Range
Frigidaire 30-3347-66-03 Tap(v3) / Gas Range
Frigidaire 30-3348-00-01 Tap(v1) / Gas Range
Frigidaire 30-3348-00-02 Tap(v4) / Gas Range
Frigidaire 30-3348-00-03 Tap(v7) / Gas Range
Frigidaire 30-3348-23-01 Tap(v2) / Gas Range
Frigidaire 30-3348-23-02 Tap(v5) / Gas Range
Frigidaire 30-3348-23-03 Tap(v8) / Gas Range
Frigidaire 30-3348-66-01 Tap(v3) / Gas Range
Frigidaire 30-3348-66-02 Tap(v6) / Gas Range
Frigidaire 30-3348-66-03 Tap(v9) / Gas Range
Frigidaire 30-3349-00-01 Tap(v1) / Gas Range
Frigidaire 30-3349-00-02 Tap(v3) / Gas Range
Frigidaire 30-3349-00-03 Tap(v5) / Gas Range
Frigidaire 30-3349-00-04 Tap(v1) / Gas Range
Frigidaire 30-3349-00-05 Tap(v3) / Gas Range
Frigidaire 30-3349-23-01 Tap(v2) / Gas Range
Frigidaire 30-3349-23-02 Tap(v4) / Gas Range
Frigidaire 30-3349-23-03 Tap(v6) / Gas Range
Frigidaire 30-3349-23-04 Tap(v2) / Gas Range
Frigidaire 30-3349-23-05 Tap(v4) / Gas Range
Frigidaire 30-3350-00-01 Tap(v1) / Gas Range
Frigidaire 30-3350-00-02 Tap(v1) / Gas Range
Frigidaire 30-3350-00-03 Tap(v1) / Gas Range
Frigidaire 30-3350-00-04 Tap(v1) / Gas Range
Frigidaire 30-3350-00-05 Tap(v3) / Gas Range
Frigidaire 30-3350-23-01 Tap(v2) / Gas Range
Frigidaire 30-3350-23-02 Tap(v2) / Gas Range
Frigidaire 30-3350-23-03 Tap(v2) / Gas Range
Frigidaire 30-3350-23-04 Tap(v2) / Gas Range
Frigidaire 30-3350-23-05 Tap(v4) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Defrost Timer locations EamonAidanAlexa Refrigerator & Freezer Repair 1 05-26-2009 02:07 PM
gas oven ignitor jleitz Oven Repair (including Ranges and Cooktops) 1 12-06-2008 08:03 AM
oven ignitor not clicking, but pilot will light manually and then the oven will work rosscol Oven Repair (including Ranges and Cooktops) 0 09-10-2008 05:37 PM
oven ignitor not clicking, but pilot will light manually and oven work then rosscol Oven Repair (including Ranges and Cooktops) 1 09-03-2008 04:30 PM
OVEN ignitor Treeman57 Oven Repair (including Ranges and Cooktops) 1 02-28-2008 02:49 PM
