Discuss
Will installing a new control board and power cord fix my oven?
 in
Hello, my Frigidaire stove was giving off a burnt plastic smoking smell. When I removed the back panel cover I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Will installing a new control board and power cord fix my oven?
  #1 (permalink)
Old 08-15-2014, 02:13 PM
Junior Member
Nealio is on a distinguished road
Default Will installing a new control board and power cord fix my oven?
Model Number: fef366ecd   Brand: Frigidaire   Age: 5 - 10 years
Hello, my Frigidaire stove was giving off a burnt plastic smoking smell. When I removed the back panel cover I discovered that the plastic part where the power cord connects was melted on one side. Additionally, some of the rubber from one of the wires from the power cord had melted a little. I did a little online research and I believe that the part I need is the “oven control board” or terminal block. Can you verify what I a need to replace based onthe picture? Would replacing the oven control board/terminal block and power cord fix my oven, and/or is there a possibility that there is some other root cause that needs to fixed as well?
Related Models
Frigidaire FEF366ECD Frigidaire/range
Frigidaire FEF366ECE Frigidaire/range
Frigidaire FEF366ECF ELECTRIC RANGE
Frigidaire FEF366ECG ELECTRIC RANGE
Frigidaire FEF366ECH ELECTRIC RANGE
Frigidaire FEF366ECJ ELECTRIC RANGE
Frigidaire FEF366ECK ELECTRIC RANGE
Frigidaire FEF366ECM ELECTRIC RANGE
Frigidaire FEF366ECN ELECTRIC RANGE
Frigidaire FEF366ECP ELECTRIC RANGE
Frigidaire FEF366ECR ELECTRIC RANGE
Frigidaire FEF366EMB Frigidaire/electric Range
Frigidaire FEF366EMC Frigidaire/range
Frigidaire FEF366EMD Frigidaire/range
Frigidaire FEF366EME Frigidaire/range
Frigidaire FEF366EMF ELECTRIC RANGE
Frigidaire FEF366EMJ ELECTRIC RANGE
Frigidaire FEF366EMK ELECTRIC RANGE
Frigidaire FEF366EMM ELECTRIC RANGE
Frigidaire FEF366EQA Frigidaire/range
Frigidaire FEF366EQB Frigidaire/range
Frigidaire FEF366EQC Frigidaire/range
Frigidaire FEF366EQD Frigidaire/electric Range
Frigidaire FEF366EQE Frigidaire/range
Frigidaire FEF366ESA Frigidaire/range
Frigidaire FEF366ESB Frigidaire/range
Frigidaire FEF366ESC Frigidaire/range
Frigidaire FEF366ESD Frigidaire/electric Range
Frigidaire FEF366ESE Frigidaire/range
Frigidaire FEF366ESF ELECTRIC RANGE
Frigidaire FEF366ESJ ELECTRIC RANGE
Frigidaire FEF366ESK ELECTRIC RANGE
Frigidaire FEF366ESM ELECTRIC RANGE
Frigidaire FEF366ESN ELECTRIC RANGE
Frigidaire FEF366LSA ELECTRIC RANGE
Frigidaire FEF366LSB ELECTRIC RANGE
Frigidaire FEF366LSC ELECTRIC RANGE
Frigidaire FEF366MXHCA ELECTRIC RANGE
Frigidaire FEF366MXHCB ELECTRIC RANGE
Frigidaire FEF366XESA Frigidaire/range
Frigidaire FEF366XESB Frigidaire/range
Frigidaire FEF367CA ELECTRIC RANGE
Frigidaire FEF367CABA Frg(v1) / Electric Range
Frigidaire FEF367CABB Frg(v1) / Electric Range
Frigidaire FEF367CABC Frg(v1) / Electric Range
Frigidaire FEF367CABD Frg(v1) / Electric Range
Frigidaire FEF367CABE Frg(v1) / Electric Range
Frigidaire FEF367CABF Frg(v1) / Electric Range
Frigidaire FEF367CABG Frg(v1) / Electric Range
Frigidaire FEF367CASA Frg(v1) / Electric Range
Frigidaire FEF367CASB Frg(v2) / Electric Range
Frigidaire FEF367CASC Frg(v2) / Electric Range
Frigidaire FEF367CASD Frg(v2) / Electric Range
Frigidaire FEF367CASE Frg(v2) / Electric Range
Frigidaire FEF367CASF Frg(v2) / Electric Range
Frigidaire FEF367CASG Frg(v2) / Electric Range
Frigidaire FEF367CATA Frg(v1) / Electric Range
Frigidaire FEF367CATB Frg(v3) / Electric Range
Frigidaire FEF367CATC Frg(v3) / Electric Range
Frigidaire FEF367CATD Frg(v3) / Electric Range
Frigidaire FEF367CATE Frg(v3) / Electric Range
Frigidaire FEF367CATF Frg(v3) / Electric Range
Frigidaire FEF367CATG Frg(v3) / Electric Range
Frigidaire FEF367CGSA Frg(v1) / Electric Range
Frigidaire FEF367CGSB
Frigidaire FEF367CGSD Frigidaire/electric Range
Frigidaire FEF367CGSE Frigidaire/electric Range
Frigidaire FEF367CGTA Frg(v2) / Electric Range
Frigidaire FEF367CGTB
Frigidaire FEF367CGTD Frigidaire/electric Range
Frigidaire FEF367CGTE Frigidaire/electric Range
Frigidaire FEF368CASA Frg(v1) / Electric Range
Frigidaire FEF368CASB Frg(v2) / Electric Range
Frigidaire FEF368CCBA Frg(v1) / Electric Range
Frigidaire FEF368CCBB Frg(v1) / Electric Range
Frigidaire FEF368CCBC Frg(v1) / Electric Range
Frigidaire FEF368CCBD Frg(v1) / Electric Range
Frigidaire FEF368CCBE Frg(v1) / Electric Range
Frigidaire FEF368CCBF Frg(v1) / Electric Range
Frigidaire FEF368CCBG Frg(v1) / Electric Range
Frigidaire FEF368CCSA Frg(v2) / Electric Range
Frigidaire FEF368CCSB Frg(v2) / Electric Range
Frigidaire FEF368CCSC Frg(v2) / Electric Range
Frigidaire FEF368CCSD Frg(v2) / Electric Range
Frigidaire FEF368CCSE Frg(v2) / Electric Range
Frigidaire FEF368CCSF Frg(v2) / Electric Range
Frigidaire FEF368CCSG Frg(v2) / Electric Range
Frigidaire FEF368CCTA Frg(v3) / Electric Range
Frigidaire FEF368CCTB Frg(v3) / Electric Range
Frigidaire FEF368CCTC Frg(v3) / Electric Range
Frigidaire FEF368CCTD Frg(v3) / Electric Range
Frigidaire FEF368CCTE Frg(v3) / Electric Range
Frigidaire FEF368CCTF Frg(v3) / Electric Range
Frigidaire FEF368CCTG Frg(v3) / Electric Range
Frigidaire FEF368CJBC Frigidaire/electric Range
Frigidaire FEF368CJSC Frigidaire/electric Range
Frigidaire FEF368CJSD Frigidaire/electric Range
Frigidaire FEF368CJTC Frigidaire/electric Range
Frigidaire FEF368GBA ELECTRIC RANGE
Frigidaire FEF368GBB ELECTRIC RANGE
Frigidaire FEF368GBC ELECTRIC RANGE
Frigidaire FEF368GBD ELECTRIC RANGE
Frigidaire FEF368GCA ELECTRIC RANGE
Frigidaire FEF368GCB ELECTRIC RANGE
Frigidaire FEF368GCC ELECTRIC RANGE
Frigidaire FEF368GCD ELECTRIC RANGE
Frigidaire FEF368GCE ELECTRIC RANGE
Frigidaire FEF368GCF ELECTRIC RANGE
Frigidaire FEF368GCG ELECTRIC RANGE
Frigidaire FEF368GCH ELECTRIC RANGE
Frigidaire FEF368GCJ ELECTRIC RANGE
Frigidaire FEF368GMA ELECTRIC RANGE
Frigidaire FEF368GMB ELECTRIC RANGE
Frigidaire FEF368GMD ELECTRIC RANGE
Frigidaire FEF368GME ELECTRIC RANGE
Frigidaire FEF368GMF ELECTRIC RANGE
Frigidaire FEF368GMG ELECTRIC RANGE
Frigidaire FEF368GQA ELECTRIC RANGE
Frigidaire FEF368GQB ELECTRIC RANGE
Frigidaire FEF368GQC ELECTRIC RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Removing control panel and installing new control board devronh Oven Repair (including Ranges and Cooktops) 2 03-05-2014 07:51 AM
Installing control board AP3141629 in GE oven vrkazak Oven Repair (including Ranges and Cooktops) 1 12-14-2011 04:58 PM
Help with installing control board suz d Oven Repair (including Ranges and Cooktops) 1 07-22-2011 06:55 AM
Installing Control Board Clock in Kenmore (GE) Oven mikelapke Oven Repair (including Ranges and Cooktops) 2 11-18-2010 04:52 PM
No power to control board and oven will not heat clarkrm1974@yahoo.com Oven Repair (including Ranges and Cooktops) 0 11-05-2010 03:35 PM
