Discuss
Kenmore Range Hood - help switching out light knob
 in
hello! the knob that operates the light switch on my kenmore range hood has the back tab broken off so
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Range Hood - help switching out light knob
  #1 (permalink)
Old 08-14-2014, 03:55 PM
Junior Member
cjoplin is on a distinguished road
Default Kenmore Range Hood - help switching out light knob
Model Number: 233.52340590   Brand: Kenmore   Age: 5 - 10 years
hello! the knob that operates the light switch on my kenmore range hood has the back tab broken off so it doesn't move the light switch. the light still functions if i operate the switch from the rear of the assembly with a (wooden) chopstick. thanks to this site, i have the correct replacement knob, s99111123, but i am unable to find an easy way to get the plastic front piece off to change out the knobs. i wasn't able to decipher anything from the instruction manual. is there a way to do it without taking apart/unhooking the entire hood? i am afraid to break the plastic tabs if i pull too hard. thank you!
Related Models
Kenmore 23310428 RANGE HOOD
Kenmore 23310442 RANGE HOOD
Kenmore 23334201 RANGE HOOD
Kenmore 23334202 RANGE HOOD
Kenmore 23334203 RANGE HOOD
Kenmore 23334204 RANGE HOOD
Kenmore 23334311 RANGE HOOD
Kenmore 23334319 RANGE HOOD
Kenmore 23350303200 RANGE HOOD
Kenmore 23350363200 RANGE HOOD
Kenmore 23350941590 RANGE HOOD
Kenmore 23350944590 RANGE HOOD
Kenmore 23350949590 RANGE HOOD
Kenmore 23351003600 RANGE HOOD
Kenmore 23351040590 RANGE HOOD
Kenmore 23351041590 RANGE HOOD
Kenmore 23351044590 RANGE HOOD
Kenmore 23351049590 RANGE HOOD
Kenmore 23351063600 RANGE HOOD
Kenmore 2335108010 KENMORE RANGE HOOD
Kenmore 2335108011 KENMORE RANGE HOOD
Kenmore 2335108012 KENMORE RANGE HOOD
Kenmore 2335108910 RANGE HOOD
Kenmore 2335108911 RANGE HOOD
Kenmore 23351141590 RANGE HOOD
Kenmore 23351144590 RANGE HOOD
Kenmore 23351200 RANGE HOOD
Kenmore 23351303200 RANGE HOOD
Kenmore 23351344590 RANGE HOOD
Kenmore 23351345590 RANGE HOOD
Kenmore 23351348590 RANGE HOOD
Kenmore 23351363200 RANGE HOOD
Kenmore 2335137810 KENMORE RANGE HOODS
Kenmore 2335137812 KENMORE RANGE HOOD
Kenmore 2335137813 KENMORE RANGE HOOD
Kenmore 2335138910 KENMORE RANGE HOOD
Kenmore 2335138911 RANGE HOOD
Kenmore 2335138912 RANGE HOOD
Kenmore 23351423200 RANGE HOOD
Kenmore 23351483 RANGE HOOD
Kenmore 23351540590 RANGE HOOD
Kenmore 23351544590 RANGE HOOD
Kenmore 23351545590 RANGE HOOD
Kenmore 23351600 RANGE HOOD
Kenmore 23351603 RANGE HOOD
Kenmore 23351640590 RANGE HOOD
Kenmore 23351644590 RANGE HOOD
Kenmore 23351645590 RANGE HOOD
Kenmore 23351648590 RANGE HOOD
Kenmore 23351649590 RANGE HOOD
Kenmore 2335167810 KENMORE RANGE HOOD
Kenmore 2335167811 KENMORE RANGE HOOD
Kenmore 2335167812 KENMORE RANGE HOOD
Kenmore 2335168910 KENMORE RANGE HOOD
Kenmore 2335168911 RANGE HOOD
Kenmore 2335168912 KENMORE RANGE HOOD
Kenmore 2335168913 RANGE HOOD
Kenmore 23351740590 RANGE HOOD
Kenmore 23351744590 RANGE HOOD
Kenmore 23351745590 RANGE HOOD
Kenmore 23351749590 RANGE HOOD
Kenmore 23351840590 RANGE HOOD
Kenmore 23351840591 RANGE HOOD
Kenmore 23351841590 RANGE HOOD
Kenmore 23351841591 RANGE HOOD
Kenmore 23351844100 RANGE HOOD
Kenmore 23351844591 RANGE HOOD
Kenmore 23351848590 RANGE HOOD
Kenmore 23351848591 RANGE HOOD
Kenmore 2335188410 KENMORE RANGE HOOD
Kenmore 2335188411 KENMORE RANGE HOOD
Kenmore 2335188610 KENMORE RANGE HOOD
Kenmore 2335188910 KENMORE RANGE HOOD
Kenmore 2335188911 RANGE HOOD
Kenmore 233518910 RANGE HOOD
Kenmore 23351898 RANGE HOOD
Kenmore 23351899 RANGE HOOD
Kenmore 23352045590 RANGE HOOD
Kenmore 23352052000 RANGE HOOD
Kenmore 23352052002 RANGE HOOD
Kenmore 23352053000 RANGE HOOD
Kenmore 23352053002 RANGE HOOD
Kenmore 23352054002 RANGE HOOD
Kenmore 23352057000 RANGE HOOD
Kenmore 23352059000 RANGE HOOD
Kenmore 23352059002 RANGE HOOD
Kenmore 2335207810 KENMORE RANGE HOOD
Kenmore 2335207811 KENMORE RANGE HOOD
Kenmore 2335208390 KENMORE RANGE HOOD
Kenmore 2335208510 KENMORE RANGE HOOD
Kenmore 2335208610 KENMORE RANGE HOOD
Kenmore 2335208910 RANGE HOOD
Kenmore 2335209690 RANGE HOOD
Kenmore 2335209950 RANGE HOOD
Kenmore 23352145590 RANGE HOOD
Kenmore 23352152000 RANGE HOOD
Kenmore 23352152002 RANGE HOOD
Kenmore 23352153000 RANGE HOOD
Kenmore 23352153002 RANGE HOOD
Kenmore 23352154002 RANGE HOOD
Kenmore 23352157000 RANGE HOOD
Kenmore 23352159000 RANGE HOOD
Kenmore 23352159002 RANGE HOOD
Kenmore 2335217810 KENMORE RANGE HOOD
Kenmore 2335217811 KENMORE RANGE HOOD
Kenmore 2335218510 KENMORE RANGE HOOD
Kenmore 2335218610 KENMORE RANGE HOOD
Kenmore 2335218910 RANGE HOOD
Kenmore 2335219690 RANGE HOOD
Kenmore 2335219950 RANGE HOOD
Kenmore 23352303200 RANGE HOOD
Kenmore 23352340590 RANGE HOOD
Kenmore 23352344590 RANGE HOOD
Kenmore 23352345590 RANGE HOOD
Kenmore 23352349590 RANGE HOOD
Kenmore 23352363200 RANGE HOOD
Kenmore 2335237810 RANGE HOOD
Kenmore 2335237811 RANGE HOOD
Kenmore 2335238510 RANGE HOOD
Kenmore 2335238910 RANGE HOOD
  #2 (permalink)
Old 10-25-2014, 11:01 AM
Junior Member
wearcd is on a distinguished road
Default Easy once you know!
After an hour and a half trying to get some help with this problem from Sears, I finally figured it out on my own! If you'll look just to the right of the switch panel - up and inside the hood with the switch panel on your right - there's a circular piece of plastic that protrudes just slightly through the metal hood. If you will push out on that round piece just slightly, the plastic panel can easily be slid to the left and lifted off! Bite me, Sears!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Range Hood not working but light does conniemaclachlan Oven Repair (including Ranges and Cooktops) 0 11-13-2011 03:48 PM
Kenmore Range Hood Light Not Working rgodsey Oven Repair (including Ranges and Cooktops) 0 02-14-2011 08:40 PM
R&R light sw. on a range hood quincyguy Oven Repair (including Ranges and Cooktops) 2 04-10-2010 07:11 PM
light fixture for range hood cehender Oven Repair (including Ranges and Cooktops) 0 07-28-2008 09:05 PM
Range hood,light cover ZippyDSMlee Oven Repair (including Ranges and Cooktops) 1 05-16-2008 04:54 PM
