Discuss
❥--frididaire range, not working.
 in
Hello all ! I often come here & lurk when I need advice about repairing something, & usually lurking does
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » ❥--frididaire range, not working.
  #1 (permalink)
Old 08-11-2014, 12:36 PM
Junior Member
herbravado is on a distinguished road
Exclamation ❥--frididaire range, not working.
Model Number: FEF368GCE   Brand: Frigidaire   Age: 1 - 5 years
Hello all ! I often come here & lurk when I need advice about repairing something, & usually lurking does the trick. However, I couldn't find a solution that was exact to my issue.
Frigidaire, smooth-top range, model number noted. Had only about a few years. We had an issue before (while still under warranty) with an eye that blew out. It was replaced & never had a problem until now.
Like many others, I began to use my oven one morning & there was a loud pop & spark, followed by the oven going out completely. Checked the stove top, & none of the eyes are working either. Pulled back the stove to check for any damage, but did not do an extensive pull-apart-and-check process. The oven element does have a hole in it (looks damaged) & will need to be replaced, but my question is--
would that cause the ENTIRE stove to stop working?? The clock, buttons, etc. do still light up & work. The oven & stove top are dead. Will replacing the bottom element fix the whole stove? Is there something else that I need to check?
Thanks for any assistance offered.
Related Models
Frigidaire FEF368GCE ELECTRIC RANGE
Frigidaire FEF368GCF ELECTRIC RANGE
Frigidaire FEF368GCG ELECTRIC RANGE
Frigidaire FEF368GCH ELECTRIC RANGE
Frigidaire FEF368GCJ ELECTRIC RANGE
Frigidaire FEF368GMA ELECTRIC RANGE
Frigidaire FEF368GMB ELECTRIC RANGE
Frigidaire FEF368GMD ELECTRIC RANGE
Frigidaire FEF368GME ELECTRIC RANGE
Frigidaire FEF368GMF ELECTRIC RANGE
Frigidaire FEF368GMG ELECTRIC RANGE
Frigidaire FEF368GQA ELECTRIC RANGE
Frigidaire FEF368GQB ELECTRIC RANGE
Frigidaire FEF368GQC ELECTRIC RANGE
Frigidaire FEF368GQD ELECTRIC RANGE
Frigidaire FEF368GSA ELECTRIC RANGE
Frigidaire FEF368GSB ELECTRIC RANGE
Frigidaire FEF368GSC ELECTRIC RANGE
Frigidaire FEF368GSD ELECTRIC RANGE
Frigidaire FEF369CGSA Frg(v1) / Electric Range
Frigidaire FEF369CGSB Frg(v1) / Electric Range
Frigidaire FEF369CGSC ELECTRIC RANGE
Frigidaire FEF369CGSD ELECTRIC RANGE
Frigidaire FEF369CGSE Frigidaire/electric Range
Frigidaire FEF369CGTA Frg(v2) / Electric Range
Frigidaire FEF369CGTB Frg(v2) / Electric Range
Frigidaire FEF369CGTC ELECTRIC RANGE
Frigidaire FEF369CGTD ELECTRIC RANGE
Frigidaire FEF369CGTE Frigidaire/electric Range
Frigidaire FEF369HBA ELECTRIC RANGE
Frigidaire FEF369HCA ELECTRIC RANGE
Frigidaire FEF369HCB ELECTRIC RANGE
Frigidaire FEF369HCC ELECTRIC RANGE
Frigidaire FEF369HCD ELECTRIC RANGE
Frigidaire FEF369HCF ELECTRIC RANGE
Frigidaire FEF369HSA ELECTRIC RANGE
Frigidaire FEF369HSB ELECTRIC RANGE
Frigidaire FEF369HSC ELECTRIC RANGE
Frigidaire FEF369HSD ELECTRIC RANGE
Frigidaire FEF375BHBA Frg/electric Range
Frigidaire FEF375BHBB Frg/electric Range
Frigidaire FEF375CHSA Frg/electric Range
Frigidaire FEF375CHSB Frg/electric Range
Frigidaire FEF375EBA Frigidaire/electric Range
Frigidaire FEF375EBB Frigidaire/range
Frigidaire FEF375EBC Frigidaire/electric Range
Frigidaire FEF375EQA Frigidaire/electric Range
Frigidaire FEF375EQB Frigidaire/range
Frigidaire FEF375EQC Frigidaire/electric Range
Frigidaire FEF375ESA Frigidaire/electric Range
Frigidaire FEF375ESB Frigidaire/range
Frigidaire FEF375ESC Frigidaire/electric Range
Frigidaire FEF375FBA Frigidaire/electric Range
Frigidaire FEF375FBB Frigidaire/range
Frigidaire FEF375FBC Frigidaire/range
Frigidaire FEF375FCA Frigidaire/electric Range
Frigidaire FEF375FCB Frigidaire/range
Frigidaire FEF375FQA Frigidaire/electric Range
Frigidaire FEF375FQB Frigidaire/range
Frigidaire FEF375FQC Frigidaire/range
Frigidaire FEF375FSA Frigidaire/electric Range
Frigidaire FEF375FSB Frigidaire/range
Frigidaire FEF375FSC Frigidaire/range
Frigidaire FEF375GCA Frigidaire/range
Frigidaire FEF375GCB ELECTRIC RANGE
Frigidaire FEF375GCC ELECTRIC RANGE
Frigidaire FEF375GCE ELECTRIC RANGE
Frigidaire FEF375GCF ELECTRIC RANGE
Frigidaire FEF375XEQA Frigidaire/electric Range
Frigidaire FEF375XESA Frigidaire/electric Range
Frigidaire FEF376AQA Frigidaire/range
Frigidaire FEF376AQB Frigidaire/range
Frigidaire FEF376AQC Frigidaire/range
Frigidaire FEF376AQE Frigidaire/electric Range
Frigidaire FEF376AQF Frigidaire/electric Range
Frigidaire FEF376AQG Frigidaire/electric Range
Frigidaire FEF376AQH Frigidaire/electric Range
Frigidaire FEF376AQJ Frigidaire/electric Range
Frigidaire FEF376AQK Frigidaire/electric Range
Frigidaire FEF376AQL Frigidaire/electric Range
Frigidaire FEF376ASA Frigidaire/range
Frigidaire FEF376ASB Frigidaire/range
Frigidaire FEF376ASC Frigidaire/range
Frigidaire FEF376ASE Frigidaire/electric Range
Frigidaire FEF376ASF Frigidaire/electric Range
Frigidaire FEF376ASG Frigidaire/electric Range
Frigidaire FEF376ASH Frigidaire/electric Range
Frigidaire FEF376ASJ Frigidaire/electric Range
Frigidaire FEF376ASK Frigidaire/electric Range
Frigidaire FEF376ASL Frigidaire/electric Range
Frigidaire FEF376CJBA ELECTRIC RANGE
Frigidaire FEF376CJBB Frigidaire/electric Range
Frigidaire FEF376CJSA ELECTRIC RANGE
Frigidaire FEF376CJSB Frigidaire/electric Range
Frigidaire FEF376CJTA ELECTRIC RANGE
Frigidaire FEF376CJTB Frigidaire/electric Range
Frigidaire FEF377BADA Frg(v2) / Electric Range
Frigidaire FEF377BADB Frg(v1) / Electric Range
Frigidaire FEF377BADD Frg(v1) / Electric Range
Frigidaire FEF377BAWA Frg(v1) / Electric Range
Frigidaire FEF377BAWB Frg(v2) / Electric Range
Frigidaire FEF377BAWD Frg(v2) / Electric Range
Frigidaire FEF377CFBA Frg(v1) / Electric Range
Frigidaire FEF377CFBB Frg(v1) / Electric Range
Frigidaire FEF377CFBC Frg(v1) / Electric Range
Frigidaire FEF377CFBD Frg(v1) / Electric Range
Frigidaire FEF377CFBE Electric Range
Frigidaire FEF377CFSA Frg(v2) / Electric Range
Frigidaire FEF377CFSB Frg(v2) / Electric Range
Frigidaire FEF377CFSC Frg(v2) / Electric Range
Frigidaire FEF377CFSD Frg(v2) / Electric Range
Frigidaire FEF377CFSE Electric Range
Frigidaire FEF377CFTA Frg(v3) / Electric Range
Frigidaire FEF377CFTB Frg(v3) / Electric Range
Frigidaire FEF377CFTC Frg(v3) / Electric Range
Frigidaire FEF377CFTD Frg(v3) / Electric Range
Frigidaire FEF377CFTE Electric Range
Frigidaire FEF377WJCA Frigidaire/electric Range
Frigidaire FEF377XEQA Frigidaire/electric Range
Frigidaire FEF378CEBA Frg(v1) / Electric Range
  #2 (permalink)
Old 08-12-2014, 01:12 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Frigidaire FEF368GCE Range - AppliancePartsPros.com
Sounds like a power problem.
The control board and lights use half the line (120 volts) (L1 to Neutral)
All the elements need the full line (240 volts) (L1 to L2)
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
No but along with the above it might.
See above.
Sometimes when an element blows it also damages the control board but you will not know if it did till you replace the element.
Be sure to unplug the unit when replacing the element as most stoves have one side of the element live even when the element is turned to off.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frididaire Gas Range shuts off/PF during baking martray2 Oven Repair (including Ranges and Cooktops) 0 06-03-2014 12:32 PM
Over the range Microwave Frididaire help Joelem Microwave Repair 0 02-06-2014 06:12 AM
frididaire dryer lauralynn Dryer Repair 1 12-10-2010 04:39 PM
Old Frididaire Ken777 Oven Repair (including Ranges and Cooktops) 0 09-13-2009 09:58 AM
Frididaire range oven won't turn off. Kenymac Oven Repair (including Ranges and Cooktops) 1 03-19-2008 12:53 PM
