Discuss
Top burner stays on , F5 error
 in
The burners on a flat top electric range won't go off , with the switch and gives a F5 error
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Top burner stays on , F5 error
  #1 (permalink)
Old 08-08-2014, 01:12 PM
Junior Member
scot120 is on a distinguished road
Default Top burner stays on , F5 error
Model Number: 790.99019101   Brand: Kenmore   Age: 5 - 10 years
The burners on a flat top electric range won't go off , with the switch and gives a F5 error code , when it's on high . It works on lower settings . It will reset if I turn the breaker off and back on . Also the oven goes off , when the door is opened and display blinks .It all started at the same time .
Related Models
Kenmore 79015011400 ELECTRIC RANGE
Kenmore 79015011401 ELECTRIC RANGE
Kenmore 79015021400 ELECTRIC RANGE
Kenmore 79015021401 ELECTRIC RANGE
Kenmore 79015031400 ELECTRIC RANGE
Kenmore 79015031401 ELECTRIC RANGE
Kenmore 79015032500 ELECTRIC RANGE
Kenmore 79015051401 GAS RANGE
Kenmore 79030172400 GAS WALLOVEN
Kenmore 79030172401 GAS WALLOVEN
Kenmore 79030179400 GAS WALLOVEN
Kenmore 79030179401 GAS WALLOVEN
Kenmore 79030472400 GAS WALLOVEN
Kenmore 79030472401 GAS WALLOVEN
Kenmore 79030472402 GAS WALLOVEN
Kenmore 79030473400 GAS WALLOVEN
Kenmore 79030473401 GAS WALLOVEN
Kenmore 79030473402 GAS WALLOVEN
Kenmore 79030473403 GAS WALLOVEN
Kenmore 79030474400 GAS WALLOVEN
Kenmore 79030474401 GAS WALLOVEN
Kenmore 79030474402 GAS WALLOVEN
Kenmore 79030479400 GAS WALLOVEN
Kenmore 79030479401 GAS WALLOVEN
Kenmore 79030479402 GAS WALLOVEN
Kenmore 79030503600 GAS COOKTOP
Kenmore 79030503601 GAS COOKTOP
Kenmore 79030522800 WALL OVEN
Kenmore 79030522801 WALL OVEN
Kenmore 79030529800 WALL OVEN
Kenmore 79030529801 WALL OVEN
Kenmore 79030552800 GAS WALLOVEN
Kenmore 79030552802 GAS WALLOVEN
Kenmore 79030553800 GAS WALLOVEN
Kenmore 79030553802 GAS WALLOVEN
Kenmore 79030554800 GAS WALLOVEN
Kenmore 79030554802 GAS WALLOVEN
Kenmore 79030559800 GAS WALLOVEN
Kenmore 79030559802 GAS WALLOVEN
Kenmore 79031003600 GAS COOKTOP
Kenmore 79031013600 GAS COOKTOP
Kenmore 79031023700 SEARS PRO/COOKTOP
Kenmore 79031023701 COOKTOP
Kenmore 79031032800 GAS RANGE
Kenmore 79031032801 GAS RANGE
Kenmore 79031032802 GAS RANGE
Kenmore 79031032804 GAS RANGE
Kenmore 79031033800 GAS RANGE
Kenmore 79031033801 GAS RANGE
Kenmore 79031033802 GAS RANGE
Kenmore 79031033803 GAS RANGE
Kenmore 79031033804 GAS RANGE
Kenmore 79031034800 GAS RANGE
Kenmore 79031034801 GAS RANGE
Kenmore 79031034802 GAS RANGE
Kenmore 79031039800 GAS RANGE
Kenmore 79031039801 GAS RANGE
Kenmore 79031039802 GAS RANGE
Kenmore 79031039804 GAS RANGE
Kenmore 79031042800 GAS RANGE
Kenmore 79031042801 GAS RANGE
Kenmore 79031042802 GAS RANGE
Kenmore 79031042803 GAS RANGE
Kenmore 79031042805 GAS RANGE
Kenmore 79031043800 GAS RANGE
Kenmore 79031043801 GAS RANGE
Kenmore 79031043802 GAS RANGE
Kenmore 79031043803 GAS RANGE
Kenmore 79031043805 GAS RANGE
Kenmore 79031049800 GAS RANGE
Kenmore 79031049801 GAS RANGE
Kenmore 79031049802 GAS RANGE
Kenmore 79031049803 GAS RANGE
Kenmore 79031049805 GAS RANGE
Kenmore 79031053000 GAS RANGE
Kenmore 79031062100 GAS RANGE
Kenmore 79031063100 GAS RANGE
Kenmore 79031069100 GAS RANGE
Kenmore 79031073100 GAS RANGE
Kenmore 79032092400 GAS COOKTOP
Kenmore 79032092401 GAS COOKTOP
Kenmore 79032092402 GAS COOKTOP
Kenmore 79032094400 GAS COOKTOP
Kenmore 79032094401 GAS COOKTOP
Kenmore 79032094402 GAS COOKTOP
Kenmore 79032099400 GAS COOKTOP
Kenmore 79032099401 GAS COOKTOP
Kenmore 79032099402 GAS COOKTOP
Kenmore 79032232400 GAS COOKTOP
Kenmore 79032232401 GAS COOKTOP
Kenmore 79032233400 GAS COOKTOP
Kenmore 79032233401 GAS COOKTOP
Kenmore 79032234400 GAS COOKTOP
Kenmore 79032234401 GAS COOKTOP
Kenmore 79032239400 GAS COOKTOP
Kenmore 79032239401 GAS COOKTOP
Kenmore 79032242400 GAS COOKTOP
Kenmore 79032242401 GAS COOKTOP
Kenmore 79032243400 GAS COOKTOP
Kenmore 79032243401 GAS COOKTOP
Kenmore 79032244400 GAS COOKTOP
Kenmore 79032244401 GAS COOKTOP
Kenmore 79032249400 GAS COOKTOP
Kenmore 79032249401 GAS COOKTOP
Kenmore 79032302000 GAS COOKTOP
Kenmore 79032303000 GAS COOKTOP
Kenmore 79032309000 GAS COOKTOP
Kenmore 79032312000 GAS COOKTOP
Kenmore 79032313000 GAS COOKTOP
Kenmore 79032319000 GAS COOKTOP
Kenmore 79032323000 GAS COOKTOP
Kenmore 79032329000 GAS COOKTOP
Kenmore 79032333000 GAS COOKTOP
Kenmore 79032339000 GAS COOKTOP
Kenmore 79032353000 COOKTOP
Kenmore 79032392400 GAS COOKTOP
Kenmore 79032392401 GAS COOKTOP
Kenmore 79032393700 GAS COOKTOP
Kenmore 79032394400 GAS COOKTOP
Kenmore 79032394401 GAS COOKTOP
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Top burner stays on , F5 error scot120 Oven Repair (including Ranges and Cooktops) 1 08-08-2014 01:34 PM
Burner ON light stays lit but burner not working mkc5869 Oven Repair (including Ranges and Cooktops) 1 04-19-2012 02:47 PM
Frigidaire Burner stays on dvj1989 Oven Repair (including Ranges and Cooktops) 0 06-25-2011 09:18 AM
Stove Top - burner stays on cyganow Oven Repair (including Ranges and Cooktops) 1 04-25-2009 08:02 PM
Stove burner will not go off stays red always glennb100 Oven Repair (including Ranges and Cooktops) 2 07-11-2008 10:50 AM
