Discuss
Maytag Gemini Dual Electric Oven
 in
Top oven broiler and bottom oven bake won't heat. How can I determine if it is the heating coils or
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag Gemini Dual Electric Oven
  #1 (permalink)
Old 08-07-2014, 05:38 AM
Junior Member
wesjpeck is on a distinguished road
Default Maytag Gemini Dual Electric Oven
Brand: Maytag   Age: 5 - 10 years
Top oven broiler and bottom oven bake won't heat. How can I determine if it is the heating coils or something more significant?
  #2 (permalink)
Old 08-07-2014, 06:58 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Check them for resistance with a meter.
Be sure to remove power from the unit when doing this as many units always have one side of the line (120 volts) connected to the elements even when they are shut off.
Undo the screw/s holding the element to the back of the oven.
Carefully pull the element into the oven.
Remove the wires from it and check it with a meter.
Should be around 20 ohms.
It is a good idea to clip something (clothespin etc.) to the wires so they do not disappear into the back of the unit while you are checking the element.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Gemini dual element not heating howardG Oven Repair (including Ranges and Cooktops) 2 09-14-2013 07:18 PM
Maytag Gemini electric double oven Abrim Oven Repair (including Ranges and Cooktops) 2 07-30-2013 01:12 AM
Maytag Gemini Dual Gas Oven Lower oven won't work edlakes Microwave Repair 1 06-16-2009 06:48 PM
Maytag Gemini Dual Burner Fail Jodice Oven Repair (including Ranges and Cooktops) 0 03-03-2009 09:57 AM
