Discuss
Thermador CM302S Problems
 in
I have 2 problems I am trying to diagnose: 1. Not possible to select the lower oven from the control
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador CM302S Problems
  #1 (permalink)
Old 08-04-2014, 10:25 AM
Junior Member
GeekFIX is on a distinguished road
Default Thermador CM302S Problems
Model Number: CM302S   Brand: Thermador   Age: 5 - 10 years
1. Not possible to select the lower oven from the control panel.
2. The microwave does not heat the food.
I have heard there are some internal fuses but I do not know how to locate as I do not have a schematic. Any guidance is appreciated.
Related Models
Thermador CM302S BUILT-IN OVEN
Thermador CM302W BUILT-IN OVEN
Crosley CM464G MWAVE- CNTRTP / STAND ALONE
Magic Chef CM46B-9P MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM46B-9P-02 MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM46D-8P-02 MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM46D-9P MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM46D-9P-02 MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM46F-14T-02 MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM46F-8P-02 MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM46FN-14T-02 MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM46FN-8P-02 MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM46G-14T-02 MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM46GN-14T-02 MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM46H-14T MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM46HW-14T MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM47F-14T-02 MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM47FN-14T-02 MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM47H-14T MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM47HW-14T MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM47J-14T MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM47JW-14T MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM48F-14T-02 MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM48FN-14T-02 MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM48H-14T MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM48HW-14T MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM48J-14T MWAVE- MOUNTED OVER RANGE/WO
Magic Chef CM48JW-14T MWAVE- MOUNTED OVER RANGE/WO
Amana CM601.000 COMMERCIAL MICROWAVES
Amana CM601.A COMMERCIAL MICROWAVES
Hardwick CM9641A590R RANGE- F/S STD GAS
Hardwick CM9641W590R RANGE- F/S STD GAS
Hardwick CM9641Y590R RANGE- F/S STD GAS
Amana CMA2000 COMMERCIAL MICROWAVES
Amana CMA2000B3 COMMERCIAL MICROWAVES
Amana CMA2000BK COMMERCIAL MICROWAVES
Amana CMA2230 COMMERCIAL MICROWAVES
Amana CMA2230B3 AMANA COMMERCIAL MICROWAVES (COMMERCIAL MICROWAVES)
Maytag CME300 MWAVE- CNTRTP / STAND ALONE
Maytag CME301 MWAVE- CNTRTP / STAND ALONE
Maytag CME400 MWAVE- CNTRTP / STAND ALONE
Maytag CME500 MWAVE- CNTRTP / STAND ALONE
Maytag CME501 MWAVE- CNTRTP / STAND ALONE
Maytag CME601 MWAVE- CNTRTP / STAND ALONE
Maytag CME700 MWAVE- CNTRTP / STAND ALONE
Maytag CME701 MWAVE- CNTRTP / STAND ALONE
Maytag CME800 MWAVE- CNTRTP / STAND ALONE
Maytag CME8000AAB MWAVE- CNTRTP / STAND ALONE
Maytag CME8000AAE MWAVE- CNTRTP / STAND ALONE
Maytag CME8010AAB MWAVE- CNTRTP / STAND ALONE
Maytag CME8010AAE MWAVE- CNTRTP / STAND ALONE
Maytag CME900 MWAVE- CNTRTP / STAND ALONE
Maytag CME901 MWAVE- MOUNTED UNDER CABINET
Maytag CME9010AAB MWAVE- MOUNTED UNDER CABINET
Maytag CME9010AAE MWAVE- MOUNTED UNDER CABINET
Maytag CME9010BAB MWAVE- MOUNTED UNDER CABINET
Maytag CME9010BAE MWAVE- MOUNTED UNDER CABINET
Maytag CME9010CAB MWAVE- MOUNTED UNDER CABINET
Maytag CME9010CAE MWAVE- MOUNTED UNDER CABINET
Maytag CME9010CAM MWAVE- MOUNTED UNDER CABINET
Maytag CME9010DAB MWAVE- MOUNTED UNDER CABINET
Maytag CME9010DAE MWAVE- MOUNTED UNDER CABINET
Frigidaire CMEF212EB1 Universal Canada/electric Range
Frigidaire CMEF212EB2 Universal Canada/electric Range
Frigidaire CMEF212EB3 Universal Canada/electric Range
Frigidaire CMEF212EB4 ELECTRIC RANGE
Frigidaire CMEF212EB5 ELECTRIC RANGE
Frigidaire CMEF212EB6 ELECTRIC RANGE
Frigidaire CMEF212EQ1 Universal Canada/electric Range
Frigidaire CMEF212ES1 Universal Canada/electric Range
Frigidaire CMEF212ES2 Universal Canada/electric Range
Frigidaire CMEF212ES3 ELECTRIC RANGE
Frigidaire CMEF212ES4 ELECTRIC RANGE
Frigidaire CMEF212ESD ELECTRIC RANGE
Frigidaire CMEF212ESE ELECTRIC RANGE
Menu Master CMM2000C MENU MASTER COMMERCIAL MICROWA (COMMERCIAL MICROWAVES)
Amana CMM2000CS COMMERCIAL MICROWAVES
Amana CMM2230C COMMERCIAL MICROWAVES
Amana CMM2230CS COMMERCIAL MICROWAVES
KitchenAid CMO2743BL1 Microwaves*
Amana CMP1.A COMMERCIAL MICROWAVES
Maytag CMS130BCLWH FREEZER- VERTICAL
Maytag CMS180BCLWH FREEZER- VERTICAL
Maytag CMS210ACLWH FREEZER- VERTICAL
Maytag CMS210ADLWH FREEZER- VERTICAL
Maytag CMS210BCLWH FREEZER- VERTICAL
Thermador CMT-127
Thermador CMT-131
Thermador CMT-18
Thermador CMT-19
Thermador CMT-19 SERVICE CODE H & UP
Thermador CMT-20
Thermador CMT-21
Thermador CMT-21 SERVICE CODE J & UP
Thermador CMT-227
Thermador CMT-231
Whirlpool CMT061SGW0 MICROWAVE OVEN 0.5 CU. FT.
Whirlpool CMT101SGW0 MICROWAVE OVEN 1.0 CU. FT.
Whirlpool CMT102SGW0 MICROWAVE OVEN 1.0 CU. FT.
Thermador CMT127N-01 OVEN
Whirlpool CMT135SGW0 MICROWAVE
Thermador CMT227N-01 ELECTRIC WALL OVEN
Thermador CMT227W OVEN
Thermador CMT231-01 S/N 89110145 & UP
Maytag CMV1000ADA MWAVE- MOUNTED UNDER CABINET
Maytag CMV1000ADB MWAVE- MOUNTED UNDER CABINET
Maytag CMV1000ADW MWAVE- MOUNTED UNDER CABINET
Maytag CMV1000BAB MWAVE- MOUNTED UNDER CABINET
Maytag CMV1000BAQ MWAVE- MOUNTED UNDER CABINET
Maytag CMV1000BAW MWAVE- MOUNTED UNDER CABINET
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
thermador cooktop problems billg87 Oven Repair (including Ranges and Cooktops) 4 01-29-2017 02:36 PM
Problems with Thermador Cook n Vent lzurcher Oven Repair (including Ranges and Cooktops) 3 06-05-2014 09:36 AM
Thermador oven problems bobirino Oven Repair (including Ranges and Cooktops) 0 05-15-2014 03:36 PM
Thermador oven problems seltzd Oven Repair (including Ranges and Cooktops) 3 09-17-2012 12:13 PM
problems with thermador cmt 227 ninamoo Oven Repair (including Ranges and Cooktops) 0 03-22-2011 09:48 AM
