Discuss
Kitchenaid Gas Range Door Handle loose
 in
I have a Kitchenaid gas range and the oven door handle is loose. I can see it has two screws
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kitchenaid Gas Range Door Handle loose
  #1 (permalink)
Old 10-24-2009, 12:51 PM
Junior Member
y1jmg is on a distinguished road
Default Kitchenaid Gas Range Door Handle loose
Brand: Kitchen Aid   Age: 1 - 5 years
I have a Kitchenaid gas range and the oven door handle is loose. I can see it has two screws on each end of the handle, but the screws are mounted from inside the oven door. I need to open the oven door to tighten the screws, but can't figure how to take it apart.
  #2 (permalink)
Old 01-26-2010, 10:15 AM
Junior Member
wambach is on a distinguished road
Default
On my Wirlpool stove/range (model #Rf375PXDN O) I did it this way. Open door to stove. Locate two screws on top edge of door. Remove screws. Front door panel will rotate toward you and away from the interior door panel. This will allow access to two hex head fasteners at parallel distances consistent with the outside door handle. Use a pliers, hex head nut driver or wrench to tighten them. Push the front door panel back to its original position and replace the two top door screws. It was that easy!
Good luck,
Dave
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator door handle loose David White Refrigerator & Freezer Repair 2 02-08-2010 07:05 PM
Loose Freezer Door Handle wgorczycki Refrigerator & Freezer Repair 2 11-04-2009 01:14 PM
Door Handle Loose WHITEKNIGHT Microwave Repair 1 09-12-2008 09:56 AM
Loose refrigerator door handle danek Refrigerator & Freezer Repair 3 11-23-2007 07:50 AM
loose oven door handle duck Oven Repair (including Ranges and Cooktops) 1 07-31-2007 06:04 PM
