Discuss
kenmore electric range wont heat
 in
My Kenmore range stopped heating. The indicator light is on, the oven light is on, clock works but no heat
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » kenmore electric range wont heat
  #1 (permalink)
Old 07-31-2014, 03:44 PM
Junior Member
tf78933 is on a distinguished road
Default kenmore electric range wont heat
Brand: Kenmore   Age: 1 - 5 years
My Kenmore range stopped heating. The indicator light is on, the oven light is on, clock works but no heat from top elements or oven. Just quit while I was cooking. Help
  #2 (permalink)
Old 08-01-2014, 12:56 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
You did not include a model number so the below is a bit of a guess.
On most units the control of the oven and the stove top elements are separate so when the both go out at the same time it is often a line/power problem.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
The elements require the full 240 volts, so you likely lost L2.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Electric Range: No Heat From Bake Or Broil Element john7 Oven Repair (including Ranges and Cooktops) 5 11-30-2012 03:35 AM
Amana electric range (oven) wont heat up flukekiller Oven Repair (including Ranges and Cooktops) 6 12-23-2011 06:01 AM
Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat dsumption Oven Repair (including Ranges and Cooktops) 3 04-04-2011 05:03 PM
Electric Heat Wont Run toby22 Heating, Ventilation, and Air Conditioning (HVAC) 0 12-02-2009 06:23 PM
kenmore electric range oven wont shut off nrmrz Oven Repair (including Ranges and Cooktops) 0 07-23-2009 02:45 PM
