Discuss
Electric modular cooktop not heating
 in
Our Kenmore Classic Grille came with the house, is on an island, has side down-drafts and two (left/right)
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Electric modular cooktop not heating
  #1 (permalink)
Old 02-16-2008, 08:28 PM
nfurlong nfurlong is offline
Junior Member
nfurlong is on a distinguished road
Default Electric modular cooktop not heating
Model Number: 911.4398610   Brand: Kenmore   Age: More than 10 years
Our Kenmore Classic Grille came with the house, is on an island, has side down-drafts and two (left/right) plugin modules. We use it in 4-burner hot plate mode.
The left rear hot plate is the only one that heats up reliably anymore. The right rear used to be reliable, but now it heats up slowly and doesn't reach high temp like it used to. The fronts work sporadically, but when they work they're also slow and don't heat up to high temp.
We thoroughly cleaned the contacts on the ceramic plug (female) but no change in behavior. I will test the other modules (grille and griddle) on both sides and collect that data, but the hot plates have been gradually getting weaker over the past year or so.
Any ideas? Where can I find the circuit that was so nicely described in the Ohm meter testing section?
Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electric cooktop mckeagcs Oven Repair (including Ranges and Cooktops) 0 02-02-2008 01:42 PM
Electric cooktop repair loud1123 Oven Repair (including Ranges and Cooktops) 1 01-28-2008 02:41 PM
Jenn Air Electric Cooktop Mike Gallagher Oven Repair (including Ranges and Cooktops) 0 11-30-2007 07:48 PM
Modular cooktop not working AzingerChamp Oven Repair (including Ranges and Cooktops) 2 09-20-2007 03:00 PM
whirlpool electric coil cooktop jaffej Oven Repair (including Ranges and Cooktops) 0 07-25-2007 10:06 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
