Discuss
Incorrect Temp Reading
 in
The upper oven is no longer reading the correct temp. For example, if I set the oven to 350, it
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Incorrect Temp Reading
  #1 (permalink)
Old 07-14-2014, 10:40 AM
Junior Member
Errant is on a distinguished road
Default Incorrect Temp Reading
Model Number: JJW8627DDB29   Brand: Jenn-Air   Age: 1 - 5 years
The upper oven is no longer reading the correct temp. For example, if I set the oven to 350, it will almost immediately ding, indicating that it has preheated to 350. I can leave it on at that setting for an hour, but a cheapen oven thermometer set inside will only read 150 or so. Any ideas what this could be?
Related Models
Maytag JJW8627DDB29 27" BUILT-IN ELECTRIC OVEN NON-CONVECTION
Jenn-Air JJW8627DDQ WALLOVEN- S/C ELE
Jenn-Air JJW8627DDS WALLOVEN- S/C ELE
Maytag JJW8627DDS29 27" BUILT-IN ELECTRIC OVEN NON-CONVECTION
Jenn-Air JJW8627DDW WALLOVEN- S/C ELE
Jenn-Air JJW8630AAB WALLOVEN- S/C ELE
Jenn-Air JJW8630AAW WALLOVEN- S/C ELE
Jenn-Air JJW8630BAB WALLOVEN- S/C ELE
Jenn-Air JJW8630BAW WALLOVEN- S/C ELE
Jenn-Air JJW8630CAB WALLOVEN- S/C ELE
Jenn-Air JJW8630CAS WALLOVEN- S/C ELE
Jenn-Air JJW8630CAW WALLOVEN- S/C ELE
Jenn-Air JJW8630DDB WALLOVEN- S/C ELE
Maytag JJW8630DDB30 30" BUILT-IN DOUBLE ELECTRIC OVEN CONVECTION
Jenn-Air JJW8630DDQ WALLOVEN- S/C ELE
Jenn-Air JJW8630DDS WALLOVEN- S/C ELE
Maytag JJW8630DDS30 30" BUILT-IN DOUBLE ELECTRIC OVEN CONVECTION
Jenn-Air JJW8630DDW WALLOVEN- S/C ELE
Maytag JJW8630DDW30 30" BUILT-IN DOUBLE ELECTRIC OVEN CONVECTION
Jenn-Air JJW9130DDB WALLOVEN- S/C ELE
Jenn-Air JJW9130DDS WALLOVEN- S/C ELE
Jenn-Air JJW9130DDW WALLOVEN- S/C ELE
Jenn-Air JJW9230DDB WALLOVEN-S/C DBL OVEN ELE
Jenn-Air JJW9230DDS WALLOVEN-S/C DBL OVEN ELE
Jenn-Air JJW9230DDW WALLOVEN-S/C DBL OVEN ELE
Jenn-Air JJW9327DDB11 27" BUILT-IN ELECTRIC OVEN
Jenn-Air JJW9327DDS11 27" BUILT-IN ELECTRIC OVEN
Jenn-Air JJW9330DDB JENN AIR COOKING
Maytag JJW9330DDB13 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN CONVECTION
Jenn-Air JJW9330DDS JENN AIR COOKING
Maytag JJW9330DDS13 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN CONVECTION
Jenn-Air JJW9330DDW JENN AIR COOKING
Maytag JJW9330DDW13 30" BUILT-IN ELECTRIC OVEN SELF-CLEAN CONVECTION
Maytag JJW9427DDB11 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN NON-CONVE
Maytag JJW9427DDS11 27" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN NON-CONVE
Jenn-Air JJW9430DDB WALLOVEN-S/C DBL OVEN ELE
Maytag JJW9430DDB13 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN NON-CONVE
Jenn-Air JJW9430DDS WALLOVEN-S/C DBL OVEN ELE
Maytag JJW9430DDS13 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN NON-CONVE
Jenn-Air JJW9430DDW WALLOVEN-S/C DBL OVEN ELE
Maytag JJW9430DDW13 30" BUILT-IN DOUBLE ELECTRIC OVEN SELF-CLEAN NON-CONVE
Jenn-Air JJW9527AAB WALLOVEN- S/C ELE
Jenn-Air JJW9527AAQ WALLOVEN- S/C ELE
Jenn-Air JJW9527AAS WALLOVEN- S/C ELE
Jenn-Air JJW9527AAW WALLOVEN- S/C ELE
Jenn-Air JJW9527BAB WALLOVEN- S/C ELE
Jenn-Air JJW9527BAQ WALLOVEN- S/C ELE
Jenn-Air JJW9527BAS WALLOVEN- S/C ELE
Jenn-Air JJW9527BAW WALLOVEN- S/C ELE
Jenn-Air JJW9527CAB WALLOVEN- S/C ELE
Jenn-Air JJW9527CAQ WALLOVEN- S/C ELE
Jenn-Air JJW9527CAS WALLOVEN- S/C ELE
Jenn-Air JJW9527CAW WALLOVEN- S/C ELE
Jenn-Air JJW9527DDB WALLOVEN- S/C ELE
Maytag JJW9527DDB29 27" BUILT-IN ELECTRIC OVEN CONVECTION
Jenn-Air JJW9527DDS WALLOVEN- S/C ELE
Maytag JJW9527DDS29 27" BUILT-IN ELECTRIC OVEN CONVECTION
Jenn-Air JJW9527DDW WALLOVEN- S/C ELE
Maytag JJW9527DDW29 27" BUILT-IN ELECTRIC OVEN CONVECTION
Jenn-Air JJW9530AAB WALLOVEN- S/C ELE
Jenn-Air JJW9530AAQ WALLOVEN- S/C ELE
Jenn-Air JJW9530AAS WALLOVEN- S/C ELE
Jenn-Air JJW9530AAW WALLOVEN- S/C ELE
Jenn-Air JJW9530ACB WALLOVEN- S/C ELE
Jenn-Air JJW9530ACW WALLOVEN- S/C ELE
Jenn-Air JJW9530BAB WALLOVEN- S/C ELE
Jenn-Air JJW9530BAQ WALLOVEN- S/C ELE
Jenn-Air JJW9530BAS WALLOVEN- S/C ELE
Jenn-Air JJW9530BAW WALLOVEN- S/C ELE
Jenn-Air JJW9530BCB WALLOVEN- S/C ELE
Jenn-Air JJW9530BCW WALLOVEN- S/C ELE
Jenn-Air JJW9530CAB WALLOVEN- S/C ELE
Jenn-Air JJW9530CAQ WALLOVEN- S/C ELE
Jenn-Air JJW9530CAS WALLOVEN- S/C ELE
Jenn-Air JJW9530CAW WALLOVEN- S/C ELE
Jenn-Air JJW9530CCB WALLOVEN- S/C ELE
Jenn-Air JJW9530CCS WALLOVEN- S/C ELE
Jenn-Air JJW9530CCW WALLOVEN- S/C ELE
Jenn-Air JJW9530DDB WALLOVEN- S/C ELE
Maytag JJW9530DDB30 30" BUILT-IN ELECTRIC OVEN CONVECTION
Jenn-Air JJW9530DDP WALLOVEN- S/C ELE
Maytag JJW9530DDP29 30" BUILT-IN ELECTRIC OVEN CONVECTION
Maytag JJW9530DDR15 30" BUILT-IN ELECTRIC OVEN CONVECTION
Jenn-Air JJW9530DDS WALLOVEN- S/C ELE
Maytag JJW9530DDS31 30" BUILT-IN ELECTRIC OVEN CONVECTION
Jenn-Air JJW9530DDW WALLOVEN- S/C ELE
Maytag JJW9530DDW30 30" BUILT-IN ELECTRIC OVEN CONVECTION
Jenn-Air JJW9627AAB WALLOVEN- S/C ELE
Jenn-Air JJW9627AAQ WALLOVEN- S/C ELE
Jenn-Air JJW9627AAS WALLOVEN- S/C ELE
Jenn-Air JJW9627AAW WALLOVEN- S/C ELE
Jenn-Air JJW9627BAB WALLOVEN- S/C ELE
Jenn-Air JJW9627BAQ WALLOVEN- S/C ELE
Jenn-Air JJW9627BAS WALLOVEN- S/C ELE
Jenn-Air JJW9627BAW WALLOVEN- S/C ELE
Jenn-Air JJW9627CAB WALLOVEN- S/C ELE
Jenn-Air JJW9627CAQ WALLOVEN- S/C ELE
Jenn-Air JJW9627CAS WALLOVEN- S/C ELE
Jenn-Air JJW9627CAW WALLOVEN- S/C ELE
Jenn-Air JJW9627DDB WALLOVEN- S/C ELE
Maytag JJW9627DDB30 27" BUILT-IN DOUBLE ELECTRIC OVEN CONVECTION
Jenn-Air JJW9627DDS WALLOVEN- S/C ELE
Maytag JJW9627DDS30 27" BUILT-IN DOUBLE ELECTRIC OVEN CONVECTION
Jenn-Air JJW9627DDW WALLOVEN- S/C ELE
Maytag JJW9627DDW30 27" BUILT-IN DOUBLE ELECTRIC OVEN CONVECTION
Jenn-Air JJW9630AAB WALLOVEN- S/C ELE
Jenn-Air JJW9630AAQ WALLOVEN- S/C ELE
Jenn-Air JJW9630AAS WALLOVEN- S/C ELE
Jenn-Air JJW9630AAW WALLOVEN- S/C ELE
Jenn-Air JJW9630ACB WALLOVEN- S/C ELE
Jenn-Air JJW9630ACW WALLOVEN- S/C ELE
Jenn-Air JJW9630BAB WALLOVEN- S/C ELE
Jenn-Air JJW9630BAQ WALLOVEN- S/C ELE
Jenn-Air JJW9630BAS WALLOVEN- S/C ELE
Jenn-Air JJW9630BAW WALLOVEN- S/C ELE
Jenn-Air JJW9630BCB WALLOVEN- S/C ELE
Jenn-Air JJW9630BCW WALLOVEN- S/C ELE
Jenn-Air JJW9630CAB WALLOVEN- S/C ELE
Jenn-Air JJW9630CAQ WALLOVEN- S/C ELE
Jenn-Air JJW9630CAS WALLOVEN- S/C ELE
  #2 (permalink)
Old 07-14-2014, 12:54 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Maytag JJW8627DDB29 Wall Oven - AppliancePartsPros.com
It could be the oven sensor.
Below is a link take a look at 7, 8, 20 and 21.
http://www.applianceaid.com/electric...air-topics.php
__________________
  #3 (permalink)
Old 07-14-2014, 01:23 PM
Junior Member
Default
Thank you, Denman. The sensor was my first thought, so I did go ahead and order one. Your link will help me with removal, testing, and reinstallation. Thank you!
I will let you know how it goes after the new part arrives
  #4 (permalink)
Old 10-13-2014, 08:30 PM
Junior Member
Default
I finally received my new sensors (74030P046-60) and they are not the correct sensors. Mine are straight, and these are L-shaped. I believe the correct part number should be 12001656, so I will reorder and give it another try.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
chest freezer displaying incorrect temp, compressor always running VinceB Refrigerator & Freezer Repair 1 04-26-2014 05:54 AM
reading wrong temp crosspatch Refrigerator & Freezer Repair 1 04-16-2013 02:09 PM
Fan Temp Reading Higher Then Room Temp RICK.JOHANNES@NORTRAX.COM Refrigerator & Freezer Repair 0 01-16-2012 06:28 AM
Flashing Temp reading in refrigerator jgmiller32 Refrigerator & Freezer Repair 0 03-10-2011 04:16 PM
