Discuss
Kenmore bake, broil will not turn off
 in
I have checked the forum but cant find an answer. This ovens bake and broil elements are on full heat
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore bake, broil will not turn off
  #1 (permalink)
Old 07-11-2014, 01:07 AM
Junior Member
dazle1 is on a distinguished road
Default Kenmore bake, broil will not turn off
Model Number: 629.4576569   Brand: Kenmore   Age: 5 - 10 years
I have checked the forum but cant find an answer. This ovens bake and broil elements are on full heat and wont turn off. I have to shut off the breaker. The oven control board 12001607, was blank so i sent it to corecentric to be repaired. Even with the OCB is removed the elements are on full when breaker's on. I replaced OCB and still the elements are on full when powered and the oven off sw. doesnt stop the heating. Could the repair be bad of the OCB? are the relays on the relay board 74001870(one bake and one broil) normally open or normally closed ie does the OCB open the relays to shut off the oven(NC) or are they supposed to be open (NO) and the OCB closes the relays to turn on the oven? how do you test the relays with a multimeter? thankyou
Related Models
Maytag 629.45769 KENMORE COOKING
Maytag 629.46775 KENMORE COOKING
Maytag 629.46776 KENMORE COOKING
Maytag 629.46779 KENMORE COOKING
Jenn-Air 629.46965 RANGE- S/C S/I DDRAFT ELE
Jenn-Air 629.46969 RANGE- S/C S/I DDRAFT ELE
Hardwick 629.70131 RANGE- F/S STD GAS
Hardwick 629.70138 RANGE- F/S STD GAS
Hardwick 629.70231 RANGE- F/S STD GAS
Hardwick 629.70238 RANGE- F/S STD GAS
Jenn-Air 629.80515 MISC / ACCESSORY
Jenn-Air 629.80519 MISC / ACCESSORY
Kenmore 62912103 COOKTOPS
Kenmore 62912104 COOKTOPS
Kenmore 62920245 ELECTRIC/GAS SLIDE-IN RANGE
Kenmore 62921136 Built-In Oven, Electric
Kenmore 62921137 Built-In Oven, Electric
Kenmore 62921238 WALL OVEN
Kenmore 62921239 WALL OVEN
Kenmore 62921336 WALL OVEN
Kenmore 62922001 COOKTOP
Kenmore 62922112 COOKTOPS
Kenmore 62922113 COOKTOPS
Kenmore 62922114 UPDRAFT ELECTRIC COOKTOP
Kenmore 62922115 UPDRAFT ELECTRIC COOKTOP
Kenmore 62922116 ELECTRIC COOKTOP
Kenmore 62922401 COOKTOP
Kenmore 62942015 COIL MODULE
Kenmore 62942019 COIL MODULE
Kenmore 62942025 GLASS CARTRIDGE
Kenmore 62942029 GLASS CARTRIDGE
Kenmore 62942032 GRIDDLE MODULE
Kenmore 62942035 GRILL COVER
Kenmore 62942039 GRILL COVER
Kenmore 62942765 ELECTRIC COOKTOP
Kenmore 62942769 ELECTRIC COOKTOP
Kenmore 62942865 ELECTRIC COOKTOP
Kenmore 62942869 ELECTRIC COOKTOP
Kenmore 62942975 COUNTER UNIT
Kenmore 62942975790 COUNTER UNIT
Kenmore 62942979 COUNTER UNIT
Kenmore 62942979790 COUNTER UNIT
Kenmore 6294576 ELECTRIC SLIDE-IN RANGE
Kenmore 62945765 ELECTRIC RANGE
Kenmore 62945765690 ELECTRIC RANGE
Kenmore 62945765790 ELECTRIC RANGE
Kenmore 62945766790 ELECTRIC RANGE
Kenmore 62945769790 ELECTRIC RANGE
Kenmore 62945775 KENMORE COOKING
Kenmore 62945776 KENMORE COOKING
Kenmore 62945779 KENMORE COOKING
Kenmore 62946775690 ELECTRIC RANGE
Kenmore 62946775790 ELECTRIC RANGE
Kenmore 62946776790 ELECTRIC RANGE
Kenmore 62946779790 ELECTRIC RANGE
Kenmore 62946795 ELECTRIC RANGE
Kenmore 62946796 ELECTRIC RANGE
Kenmore 62946799 ELECTRIC RANGE
Kenmore 62946965 ELECTRIC RANGE
Kenmore 62946969 ELECTRIC RANGE
Kenmore 6294697 ELECTRIC RANGE
Kenmore 62946975 WIRING DIAGRAM-RANGE
Kenmore 62946979 WIRING DIAGRAM-RANGE
Kenmore 62960002600 KENMORE COOKING
Kenmore 62960002601 KENMORE COOKING
Kenmore 62960002606 ELECTRIC RANGE
Kenmore 62960003600 KENMORE COOKING
Kenmore 62960008600 KENMORE COOKING
Kenmore 62960008601 KENMORE COOKING
Kenmore 62960008606 ELECTRIC RANGE
Kenmore 62960009600 KENMORE COOKING
Kenmore 62960009601 KENMORE COOKING
Kenmore 62960009606 ELECTRIC RANGE
Kenmore 62970131 GAS RANGE
Kenmore 62970138 GAS RANGE
Kenmore 62990131 ELECTRIC RANGE
Kenmore 62990138 ELECTRIC RANGE
Kenmore 629CG200 GAS COOKTOP
Magic Chef 62S14XAA RANGE- S/I CONT CLEAN GAS
Magic Chef 62S14XAS RANGE- S/I CONT CLEAN GAS
Magic Chef 62S14XAW RANGE- S/I CONT CLEAN GAS
Hoover 63
Amana 630.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 630.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 630.002 RANGE- S/C S/I DDRAFT GAS
Amana 630.003 RANGE- S/C S/I DDRAFT GAS
Frigidaire 6307B WASHER
Frigidaire 6308A WASHER
Frigidaire 6309A WASHER
Amana 631.000 RANGE- S/C S/I DDRAFT GAS
Amana 631.001 RANGE- S/C S/I DDRAFT GAS
Amana 631.002 RANGE- S/C S/I DDRAFT GAS
Amana 631.003 RANGE- S/C S/I DDRAFT GAS
Amana 631.004 RANGE- S/C S/I DDRAFT GAS
Amana 631.006 RANGE- S/C S/I DDRAFT GAS
Amana 632-3J ROOM AIR CONDITIONER
Frigidaire 6337B WASHER
Frigidaire 6338A WASHER
Frigidaire 6339A WASHER
Hoover 634
Frigidaire 6347B WASHER
Frigidaire 6348A WASHER
Frigidaire 6358A WASHER
Frigidaire 6389-80A WASHER
Frigidaire 6389-80B WASHER
Frigidaire 6389-87A WASHER
Frigidaire 6389-87B WASHER
Hoover 64
Maytag 640C DRYER- GAS
Maytag 640W DRYER- GAS
Magic Chef 6458XRA RANGE- S/C S/I GAS
Magic Chef 6458XRS RANGE- S/C S/I GAS
Magic Chef 6458XRW RANGE- S/C S/I GAS
Magic Chef 6458XTA RANGE- S/C S/I GAS
Magic Chef 6458XTS RANGE- S/C S/I GAS
Magic Chef 6458XTW RANGE- S/C S/I GAS
Kenmore 6476037210 KENMORE 30 IN GAS RANGE
Kenmore 6476037220 KENMORE 30 IN GAS RANGE
Kenmore 6476037240 KENMORE 30 IN GAS RANGE
  #2 (permalink)
Old 07-11-2014, 03:46 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I cannot find any tech info on the given model number.
The Sears parts site does have part breakdown diagrams and it looks like this unit uses a control board and a relay board.
I am assuming that OCB stands for Oven Control Board.
This would point to a problem with the relay board.
I cannot say but I would replace the relay board first.
The relays are normally open.
The control board energizes the relay to close it contacts and turn the element on.
You really do not have to check them.
All you could check is if the relay contacts are always closed (welded together).
This could be done by unplugging the unit and then checking across the contacts. Since I do not have a wiring diagram I cannot give you test points.
This would be very unlikely as both relays would have to weld together at the same time.
I cannot say for sure what is going on.
The relay board also has a transformer on it.
I think this is probably to provide low voltage to the control board which is then turned into low DC voltage on the board and that runs the electronics.
There may be a problem with the transformer.
This is why the control board is dead.
I cannot explain why this is also closing the element relays.
Hopefully the relay board has not blown the control board.
__________________
  #3 (permalink)
Old 07-12-2014, 01:14 AM
Junior Member
Default
Thankyou for the response, Knowing the relays are supposed to be N.O. is very helpful. I heard from corecentric today, they are sending a label because they reviewed the repair and saw they never replaced the relays on the OCB which control the turning on and off of the other relays. Im also sending in the relay board because we both felt that since the problem persists when the OCB isnt installed, that the relays on the relay board are suspect.
In response, the OCB was only dead before it was repaired, it wasnt a trans. problem, and repaired it still wouldnt shut off the relays, which if they are N.O. then it couldnt do since it isnt closing the relays. Thanks for your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Gas Range - bake and broil not working makemyovenwork Oven Repair (including Ranges and Cooktops) 0 11-25-2013 04:21 PM
Kenmore Electric Oven no Bake or Broil bcsman Oven Repair (including Ranges and Cooktops) 0 08-17-2011 09:53 AM
oven heating elements not working - also light doesn't turn on when bake/broil dial i rnelson Oven Repair (including Ranges and Cooktops) 0 06-07-2011 03:59 PM
Neither Bake or Broil Elements Turn On adam808 Oven Repair (including Ranges and Cooktops) 4 11-30-2010 09:42 PM
Kenmore-no bake, no broil after new control board dennis728 Oven Repair (including Ranges and Cooktops) 0 03-29-2010 04:27 PM
