Discuss
stove and oven: 1 problem or 2? troubleshooting test!
 in
Kitchenaid freestanding range (oven and ceramic stove top) Model ykerc607hs7 12years old. Not sure if one big problem or two
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » stove and oven: 1 problem or 2? troubleshooting test!
  #1 (permalink)
Old 07-09-2014, 12:17 PM
Junior Member
ebo2112 is on a distinguished road
Default stove and oven: 1 problem or 2? troubleshooting test!
Model Number: ykerc607hs7   Brand: Kitchen Aid   Age: More than 10 years
Model ykerc607hs7
12years old.
Not sure if one big problem or two unrelated problems.
Part 1.
Left front (L.F.) burner (Dual ring) was in use (long boil).
Some sort of overheat/condensation-short or meltdown occured and tripped house
breaker.
Tried the two right burners front and rear and they worked.
The two left burners did not work and no pilot lights.
Replaced L.F. burner control switch. noticed the pin at P1 [L1 large black
wire] appeared melted, inspected and dressed with electrical tape.
Also checked L.R. burner control and stripped and re-crimped a melted wire
(the smaller red wire at pin 5-L2)
PROBLEM: the front dual-ring element appears to function normally, but the
L.R. element still doesn't function, however it's pilot light is always on if
the stove is plugged into the wall.
-would/could it be the L.R. burner control needs replacement?
-I note that it appears the two pilot lights on that side are in series...a
clue?
note:The right two elements (R.F., and R.R.) continue to function normally.
Part 2.
POSSIBLY RELATED:
the oven worked following this issue with the cook top.
then the second oven elemnet failed.(i guessed the first one failed months
earlier when the oven started to take longer to heat up)
I tested the elements and found:
- the hidden bake elemenent had failed
- the outer broil element had failed
- the inner ('econo broil'I) broil element did have conitnuity but didnt heat
up.
[ note- there is also a circular convection element which has never worked in
this stove and we never use it.]
I replaced two oven elements (the hidden one and the main one exposed at the
roof of the oven which has two circuits)
I also tested two thermostat components:
1. "thrmstFix" part#PS346980. on the left side of the stove. vertical
connection leads, does have continuity. i beleive this is correct. (component
is labelled 341196).
2. "Thermostat(140)" part#PS982278. on the right side of the stove. flat
connection leads, no continuity. bought a replacement which showed NO
continuity when disconnected. i beleive this is correct. (i think this part
has been re-named "Bi-Metal thermal limiter" or thermal fuse or something like that by the
manufacturer)
PROBLEM 2: I still do not get heat from the elements.
-The control panel takes my selections for type of baking etc and temperature
choices.
- I hear the correct number of relay clicks depending on the choice I make.
- there is 220V at the wall, plus three of the stovetop burners heat up quickly/normally.
Related Models
Whirlpool YKERC607HS7 30" Free-Standing DESIGNER STYLE Convection Oven
Whirlpool YKERC607HS8 30" Free-Standing DESIGNER STYLE Convection Oven
Whirlpool YKERC607HT5 30" Free-Standing DESIGNER STYLE Convection Oven
Whirlpool YKERC607HT6 30" Free-Standing DESIGNER STYLE Convection Oven
Whirlpool YKERC607HT7 30" Free-Standing DESIGNER STYLE Convection Oven
Whirlpool YKERC607HT8 30" Free-Standing DESIGNER STYLE Convection Oven
Whirlpool YKERC607HW5 30" Free-Standing DESIGNER STYLE Convection Oven
Whirlpool YKERC607HW6 30" Free-Standing DESIGNER STYLE Convection Oven
Whirlpool YKERC607HW7 30" Free-Standing DESIGNER STYLE Convection Oven
Whirlpool YKERC607HW8 30" Free-Standing DESIGNER STYLE Convection Oven
Whirlpool YKERC608LS0 30" Free-Standing DESIGNER STYLE Convection Oven
Whirlpool YKERI201PW0 30" ELECTRIC CERAN FREE STANDING RANGE SELF CLEAN OVEN
Whirlpool YKERI201PW1 30" ELECTRIC CERAN FREE STANDING RANGE SELF CLEAN OVEN
Whirlpool YKERI201PW3 30" ELECTRIC CERAN FREE STANDING RANGE SELF CLEAN OVEN
Whirlpool YKERI203PT0 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool YKERI203PT1 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool YKERI203PW0 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool YKERI203PW1 30" ELECTRIC CERAN FREE STANDING RANGE CONVECTION OVEN
Whirlpool YKERI204PB0 30" ELECTRIC FREE STANDING RANGE CONVECTION OVEN
Whirlpool YKERI204PB1 30" ELECTRIC FREE STANDING RANGE CONVECTION OVEN
Whirlpool YKERI204PB2 30" ELECTRIC FREE STANDING RANGE CONVECTION OVEN
Whirlpool YKERI204PW0 30" ELECTRIC FREE STANDING RANGE CONVECTION OVEN
Whirlpool YKERI204PW1 30" ELECTRIC FREE STANDING RANGE CONVECTION OVEN
Whirlpool YKERI204PW2 30" ELECTRIC FREE STANDING RANGE CONVECTION OVEN
Whirlpool YKERI204PW3 30" ELECTRIC FREE STANDING RANGE CONVECTION OVEN
Whirlpool YKERI500HW2 30" ELECTRONIC RANGE FREESTANDING DESIGNER STYLE Self-Clean Oven
Whirlpool YKERI500HW3 30" ELECTRONIC RANGE FREESTANDING DESIGNER STYLE Self-Clean Oven
Whirlpool YKERS205TB0 30" FREE STANDING ELECTRIC RANGE
Whirlpool YKERS205TB2 30" FREE STANDING ELECTRIC RANGE
Whirlpool YKERS205TB3 30" FREE STANDING ELECTRIC RANGE
Whirlpool YKERS205TS0 30" FREE STANDING ELECTRIC RANGE
Whirlpool YKERS205TS2 30" FREE STANDING ELECTRIC RANGE
Whirlpool YKERS205TS3 30" FREE STANDING ELECTRIC RANGE
Whirlpool YKERS205TS4 30" FREE STANDING ELECTRIC RANGE
Whirlpool YKERS205TS5 30" FREE STANDING ELECTRIC RANGE
Whirlpool YKERS205TW0 30" FREE STANDING ELECTRIC RANGE
Whirlpool YKERS205TW2 30" FREE STANDING ELECTRIC RANGE
Whirlpool YKERS205TW3 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS206XB0 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS206XBL0 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS206XS0 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS206XS1 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS206XSS0 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS206XW0 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS206XW1 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS206XWH0 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS208XB0 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS208XB1 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS208XS0 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS208XS1 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS208XW0 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS208XW1 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS308XS0 30" FREE STANDING ELECTRIC RANGE
KitchenAid YKERS308XS1 30" FREE STANDING ELECTRIC RANGE
Whirlpool YKERS507HB0 30" ELECTRONIC RANGE FREESTANDING DESIGNER STYLE Self-Clean Oven Coil Cooktop
Whirlpool YKERS507HB1 30" ELECTRONIC RANGE FREESTANDING DESIGNER STYLE Self-Clean Oven Coil Cooktop
Whirlpool YKERS507HB2 30" ELECTRONIC RANGE FREESTANDING DESIGNER STYLE Self-Clean Oven Coil Cooktop
Whirlpool YKERS507HB3 30" ELECTRONIC RANGE FREESTANDING DESIGNER STYLE Self-Clean Oven Coil Cooktop
Whirlpool YKERS507HW0 30" ELECTRONIC RANGE FREESTANDING DESIGNER STYLE Self-Clean Oven Coil Cooktop
Whirlpool YKERS507HW1 30" ELECTRONIC RANGE FREESTANDING DESIGNER STYLE Self-Clean Oven Coil Cooktop
Whirlpool YKERS507HW2 30" ELECTRONIC RANGE FREESTANDING DESIGNER STYLE Self-Clean Oven Coil Cooktop
Whirlpool YKERS507HW3 30" ELECTRONIC RANGE FREESTANDING DESIGNER STYLE Self-Clean Oven Coil Cooktop
Whirlpool YKERS807SB00 30" FREE STANDING ELECTRIC OVEN CONVECTION
Whirlpool YKERS807SB01 30" FREE STANDING ELECTRIC OVEN SELF CLEAN
Whirlpool YKERS807SB02 30" FREE STANDING ELECTRIC OVEN SELF CLEAN
Whirlpool YKERS807SP00 30" FREE STANDING ELECTRIC OVEN CONVECTION
Whirlpool YKERS807SP01 30" FREE STANDING ELECTRIC OVEN SELF CLEAN
Whirlpool YKERS807SP02 30" FREE STANDING ELECTRIC OVEN SELF CLEAN
Whirlpool YKERS807SS00 30" FREE STANDING ELECTRIC OVEN CONVECTION
Whirlpool YKERS807SS01 30" FREE STANDING ELECTRIC OVEN SELF CLEAN
Whirlpool YKERS807SS02 30" FREE STANDING ELECTRIC OVEN SELF CLEAN
Whirlpool YKESA907PB00 30" SLIDE-IN ELECTRIC OVEN CONVECTION
Whirlpool YKESA907PB01 30" SLIDE-IN ELECTRIC OVEN CONVECTION
Whirlpool YKESA907PB02 30" SLIDE-IN ELECTRIC OVEN CONVECTION
Whirlpool YKESA907PC00 30" SLIDE-IN ELECTRIC OVEN CONVECTION
Whirlpool YKESA907PC02 30" SLIDE-IN ELECTRIC OVEN CONVECTION
Whirlpool YKESA907PP00 30" SLIDE-IN ELECTRIC OVEN CONVECTION
Whirlpool YKESA907PP01 30" SLIDE-IN ELECTRIC OVEN CONVECTION
Whirlpool YKESA907PP02 30" SLIDE-IN ELECTRIC OVEN CONVECTION
Whirlpool YKESA907PS00 30" SLIDE-IN ELECTRIC OVEN CONVECTION
Whirlpool YKESA907PS01 30" SLIDE-IN ELECTRIC OVEN CONVECTION
Whirlpool YKESA907PS02 30" SLIDE-IN ELECTRIC OVEN CONVECTION
Whirlpool YKESC300HW5 30" Slide-In Electronic Range DESIGNER STYLE
Whirlpool YKESC300HW6 30" Slide-In Electronic Range DESIGNER STYLE
Whirlpool YKESC300HW7 30" Slide-In Electronic Range DESIGNER STYLE
Whirlpool YKESC300HW8 30" Slide-In Electronic Range DESIGNER STYLE
Whirlpool YKESC307HB5 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC307HB6 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC307HB7 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC307HB8 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC307HS5 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC307HS6 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC307HS7 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC307HS8 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC307HT5 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC307HT6 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC307HT7 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC307HT8 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC307HW5 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC307HW6 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC307HW7 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC307HW8 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESC308LS0 30" Slide-In Range DESIGNER STYLE Convection Oven
Whirlpool YKESS907SB00 30" Built-In ELECTRIC OVEN
Whirlpool YKESS907SB01 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Whirlpool YKESS907SB03 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Whirlpool YKESS907SP00 30" Built-In ELECTRIC OVEN
KitchenAid YKESS907SP01 30" SLIDE-IN ELECTRIC OVEN
Whirlpool YKESS907SP03 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Whirlpool YKESS907SS00 30" Built-In ELECTRIC OVEN
Whirlpool YKESS907SS01 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Whirlpool YKESS907SS03 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Whirlpool YKESS907SW01 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Whirlpool YKESS908SS00 30" Slide-In ELECTRIC OVEN
Whirlpool YKESS908SS01 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Whirlpool YKESS908SS03 30" SLIDE-IN ELECTRIC OVEN SELF CLEAN
Whirlpool YKESV908PM00 30" SLIDE-IN ELECTRIC OVEN CONVECTION
Whirlpool YKESV908PM01 30" SLIDE-IN ELECTRIC OVEN CONVECTION
Whirlpool YKESV908PS00 30" SLIDE-IN ELECTRIC OVEN CONVECTION
Whirlpool YKESV908PS01 30" SLIDE-IN ELECTRIC OVEN CONVECTION
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
problem with Amana stove oven chuckdog Oven Repair (including Ranges and Cooktops) 5 08-20-2012 01:16 AM
Whirlpool oven/stove pf problem habrams Oven Repair (including Ranges and Cooktops) 0 03-31-2012 10:44 AM
Troubleshooting defrosting problem Watt-man Refrigerator & Freezer Repair 4 09-06-2011 04:30 PM
gas stove oven problem debmike Oven Repair (including Ranges and Cooktops) 1 11-20-2010 07:51 PM
What should I test next to fix my stove? edee_em Oven Repair (including Ranges and Cooktops) 6 02-04-2010 08:26 PM
