Discuss
oven temp
 in
I set the temp to 350 and press start. After an hour the tempo has only reached 145. If I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven temp
  #1 (permalink)
Old 07-09-2014, 12:15 PM
Junior Member
rondegenaro is on a distinguished road
Default oven temp
Brand: Kenmore   Age: More than 10 years
I set the temp to 350 and press start. After an hour the tempo has only reached 145. If I change to broil I can get the temp up to 350 and then change to bake. Is the bottom element bad and needs replacing or is there a problem with the temp gauge?
  #2 (permalink)
Old 07-09-2014, 01:36 PM
Junior Member
ebo2112 is on a distinguished road
Default
I would access the bottom element, disconect it and test with ohm-meter (multi-meter).
You are hoping for zero (or very low) resistance across the contacts you just unplugged - resistance is measured in ohms (greek letter omega).
If resistance is very high or infinite , the element is burnt out.
Seems the logical place to start.
  #3 (permalink)
Old 07-10-2014, 02:38 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Does the unit stay in preheat?
If yes then odds are that the oven sensor is OK.
If the unit shows it is ready then it is probably a control problem.
A model number would be helpful.
If you check the bake (lower) element be sure to unplug the unit when doing this.
Many units have one side of the element always hooked to power so they must be unplugged or the breakers shut off.
Unplugging is the safer of the two.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven heats up to Temp, but wont light back up to keep at temp Pooler Oven Repair (including Ranges and Cooktops) 1 05-06-2014 08:46 AM
Actual Oven Temp Lower Than Set Temp oddie Oven Repair (including Ranges and Cooktops) 0 01-05-2012 06:06 PM
Internal Oven temp 100 degrees hotter than set temp saadragna Oven Repair (including Ranges and Cooktops) 1 11-14-2010 06:52 AM
oven temp selector and temp in oven varies significantly larry68417 Oven Repair (including Ranges and Cooktops) 1 11-12-2010 08:02 PM
Oven temp varies from display temp topxfuelx69 Oven Repair (including Ranges and Cooktops) 0 10-14-2009 02:45 PM
