Discuss
Wall oven electronic ignitor failure
 in
Hi, I have Tappan wall oven with electronic ignitor (20-30 years old?). Through current investigation it appears the electronic ignition
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Wall oven electronic ignitor failure
  #1 (permalink)
Old 06-29-2014, 05:39 PM
Junior Member
susanlp is on a distinguished road
Default Wall oven electronic ignitor failure
Model Number: 12-1663-30   Brand: Tappan   Age: More than 10 years
I have Tappan wall oven with electronic ignitor (20-30 years old?). Through current investigation it appears the electronic ignition has failed.
I see on Appliance Repair site that ignitors are listed for model 12-1663-23 and for model 12-1663-45, but not my particular model.
Are they interchangeable? If so, any one know why they list them in 2 different sizes? And how do I determine if I need the shorter wire length or the longer?
FYI - I've determined I need this because the oven has been taken longer and longer to light. The ignitor itself doesn't glow very brightly either.
Thanks for your help.
Susan
Related Models
Frigidaire 12-1663-45-01 Tap(v8) / Gas Range
Frigidaire 12-1663-57-01 Tap(v9) / Gas Range
Frigidaire 12-1663-66-01 Tap(v10) / Gas Range
Frigidaire 12-1863-00-01 Tap(v1)
Frigidaire 12-1863-00-02 Tap(v2)
Frigidaire 12-1863-00-03 Tap(v1) / Gas Wall Oven
Frigidaire 12-2299-00-01 Tap(v1) / Wall Oven
Frigidaire 12-2299-00-02 Tap(v1) / Wall Oven
Frigidaire 12-2299-00-03 Tap(v1) / Wall Oven
Frigidaire 12-2299-00-04 Tap(v2) / Wall Oven
Frigidaire 12-2299-00-06 Tap(v1) / Wall Oven
Frigidaire 12-2299-10-05 Tap(v1) / Wall Oven
Amana 12-2MW ROOM AIR CONDITIONER
Amana 12-2N ROOM AIR CONDITIONER
Amana 12-2NM ROOM AIR CONDITIONER
Frigidaire 12-3219-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-3699-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-3699-00-04 Tap(v1) / Gas Wall Oven
Frigidaire 12-3699-00-05 Tap(v1) / Gas Wall Oven
Frigidaire 12-3883-00-01 Tap(v11) / Gas Range
Frigidaire 12-3883-23-01 Tap(v12) / Gas Range
Frigidaire 12-3883-45-01 Tap(v13) / Gas Range
Frigidaire 12-3883-57-01 Tap(v14) / Gas Range
Frigidaire 12-3883-66-01 Tap(v15) / Gas Range
Frigidaire 12-3893-00-01 Tap(v11) / Gas Range
Frigidaire 12-3893-23-01 Tap(v12) / Gas Range
Frigidaire 12-3893-45-01 Tap(v13) / Gas Range
Frigidaire 12-3893-57-01 Tap(v14) / Gas Range
Frigidaire 12-3893-66-01 Tap(v15) / Gas Range
Amana 12-3G ROOM AIR CONDITIONER
Amana 12-3GH ROOM AIR CONDITIONER
Amana 12-3GM ROOM AIR CONDITIONER
Amana 12-3J ROOM AIR CONDITIONER
Amana 12-3JH ROOM AIR CONDITIONER
Amana 12-3JM ROOM AIR CONDITIONER
Frigidaire 12-4980-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-4980-00-03 Tap(v1) / Gas Wall Oven
Frigidaire 12-4980-00-04 Tap(v1) / Gas Wall Oven
Frigidaire 12-4980-00-05 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-02 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-03 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-04 Tap(v1) / Gas Wall Oven
Frigidaire 12-5063-00-04 Tap(v16) / Gas Range
Frigidaire 12-5063-00-05 Tap(v17) / Gas Range
Frigidaire 12-5063-23-04 Tap(v18) / Gas Range
Frigidaire 12-5063-23-05 Tap(v19) / Gas Range
Frigidaire 12-5063-45-04 Tap(v20) / Gas Range
Frigidaire 12-5063-45-05 Tap(v21) / Gas Range
Frigidaire 12-5063-57-04 Tap(v22) / Gas Range
Frigidaire 12-5063-57-05 Tap(v23) / Gas Range
Frigidaire 12-5063-66-04 Tap(v24) / Gas Range
Frigidaire 12-5063-66-05 Tap(v25) / Gas Range
Frigidaire 12-5299-00-01 Tap(v2) / Wall Oven
Frigidaire 12-5299-00-02 Tap(v1) / Wall Oven
Frigidaire 12-5299-00-04 Tap(v2) / Wall Oven
Frigidaire 12-6219-00-01 Tap(v2) / Gas Wall Oven
Frigidaire 12-6263-00-01 Tap(v16) / Gas Range
Frigidaire 12-6263-23-01 Tap(v17) / Gas Range
Frigidaire 12-6263-45-01 Tap(v18) / Gas Range
Frigidaire 12-6263-57-01 Tap(v19) / Gas Range
Frigidaire 12-6263-66-01 Tap(v20) / Gas Range
Frigidaire 12-6663-00-01 Tap(v21) / Gas Range
Frigidaire 12-6663-23-01 Tap(v22) / Gas Range
Frigidaire 12-6663-45-01 Tap(v23) / Gas Range
Frigidaire 12-6663-57-01 Tap(v24) / Gas Range
Frigidaire 12-6663-66-01 Tap(v25) / Gas Range
Frigidaire 12-6699-00-01 Tap(v2) / Gas Wall Oven
Amana 120.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 120.001 MWAVE - FAMILY SIZE (60 HZ)
Maytag 12001294 MISC / ACCESSORY
Maytag 12001302 MISC / ACCESSORY
Maytag 12001685 MISC / ACCESSORY
Maytag 12001686 MISC / ACCESSORY
Maytag 12001687 MISC / ACCESSORY
Maytag 12001688 MISC / ACCESSORY
Maytag 12001747 MISC / ACCESSORY
General Electric 1200L02 DISHWASHER
Thermador 1201
Thermador 1205
Jenn-Air 12103 SURFACE UNIT- DDRAFT GAS
Jenn-Air 12104 SURFACE UNIT- DDRAFT GAS
Roper 1213*2A GAS RANGE
Roper 1213*3A GAS RANGE
Roper 1213W1A GAS RANGE
Roper 1213Z2A GAS RANGE
Roper 1213Z3A GAS RANGE
Roper 1215*0A GAS RANGE
Roper 1215*1A GAS RANGE
Roper 1215W0A GAS RANGE
Roper 1215W1A GAS RANGE
Roper 1225*0A GAS RANGE
Roper 1225*1A GAS RANGE
Roper 1225*2A GAS RANGE
Roper 1225*3A GAS RANGE
Roper 1225W1A GAS RANGE
Roper 1225W2A GAS RANGE
Roper 1225W3A GAS RANGE
Roper 1233*0A GAS RANGE
Roper 1233*1A GAS RANGE
Roper 1233*2A GAS RANGE
Roper 1233Z1A GAS RANGE
Roper 1233Z2A GAS RANGE
Roper 1234*0A GAS RANGE
Whirlpool 1234W0A
Whirlpool 1234^0A
Roper 1235*0A GAS RANGE
Roper 1235*1A GAS RANGE
Roper 1235W0A GAS RANGE
Roper 1235W1A GAS RANGE
Frigidaire 1236B DISHWASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore gas wall oven model # 790-30172400 Electronic Oven Control jamforoush Oven Repair (including Ranges and Cooktops) 0 04-22-2012 11:20 PM
GE Wall mount dual oven (Electronic) justnawe1 Oven Repair (including Ranges and Cooktops) 1 11-04-2010 04:47 PM
Jenn-Air Wall Oven - Electronic Control Convection Cilly Oven Repair (including Ranges and Cooktops) 1 11-09-2009 03:52 PM
Electronic controls on built in wall oven P.Gulick Oven Repair (including Ranges and Cooktops) 1 11-04-2009 05:54 AM
Need electronic control panel for wall oven tankersm Oven Repair (including Ranges and Cooktops) 2 01-01-2008 10:05 AM
