Discuss
WOLF Range - one burner clicks after lit
 in
Hi, I've got a Wolf propane range (30") 4 burner stove with the open burners. One of my burners (back
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » WOLF Range - one burner clicks after lit
  #1 (permalink)
Old 06-25-2014, 07:12 AM
Junior Member
Liamfm is on a distinguished road
Default WOLF Range - one burner clicks after lit
Model Number: 30" open burner   Brand: -other-   Age: More than 10 years
I've got a Wolf propane range (30") 4 burner stove with the open burners. One of my burners (back left) continues to click even after the burner is lit. Sometimes it will stop for a bit, but then starts again.
I'm told I should be looking at continuity on the ignitor and also good ground. I'm pretty proficient with my multimeter, but need some advice on where I should be testing from. Am I looking for ground from the igniter tip to the stove body, or from the bottom/wire or from the wire at the module? Same for continuity and resistance?
Any help is appreciated. 3 of the 4 burners function normally, one is problematic.
Thanks in advance!
Liam
Related Models
Frigidaire 30-0127-23-03 Tap(v4) / Gas Range
Frigidaire 30-1049-00-01 Tap(v1) / Gas Range
Frigidaire 30-1049-00-02 Tap(v3) / Gas Range
Frigidaire 30-1049-00-03 Tap(v5) / Gas Range
Frigidaire 30-1049-00-04 Tap(v1) / Gas Range
Frigidaire 30-1049-00-05 Tap(v1) / Gas Range
Frigidaire 30-1049-00-06 Tap(v1) / Gas Range
Frigidaire 30-1049-00-07 Tap(v1) / Gas Range
Frigidaire 30-1049-00-08 Tap(v1) / Gas Range
Frigidaire 30-1049-00-09 Tap(v3) / Gas Range
Frigidaire 30-1049-00-10 Tap(v1) / Gas Range
Frigidaire 30-1049-00-11 Tap(v1) / Gas Range
Frigidaire 30-1049-23-01 Tap(v2) / Gas Range
Frigidaire 30-1049-23-02 Tap(v4) / Gas Range
Frigidaire 30-1049-23-03 Tap(v6) / Gas Range
Frigidaire 30-1049-23-04 Tap(v2) / Gas Range
Frigidaire 30-1049-23-05 Tap(v2) / Gas Range
Frigidaire 30-1049-23-06 Tap(v2) / Gas Range
Frigidaire 30-1049-23-07 Tap(v2) / Gas Range
Frigidaire 30-1049-23-08 Tap(v2) / Gas Range
Frigidaire 30-1049-23-09 Tap(v4) / Gas Range
Frigidaire 30-1049-23-10 Tap(v2) / Gas Range
Frigidaire 30-1049-23-11 Tap(v2) / Gas Range
Frigidaire 30-1149-00-01 Tap(v1) / Gas Range
Frigidaire 30-1149-00-02 Tap(v1) / Gas Range
Frigidaire 30-1149-00-03 Tap(v3) / Gas Range
Frigidaire 30-1149-00-04 Tap(v5) / Gas Range
Frigidaire 30-1149-00-05 Tap(v1) / Gas Range
Frigidaire 30-1149-00-06 Tap(v1) / Gas Range
Frigidaire 30-1149-00-07 Tap(v3) / Gas Range
Frigidaire 30-1149-00-08 Tap(v1) / Gas Range
Frigidaire 30-1149-00-10 Tap(v1) / Gas Range
Frigidaire 30-1149-00-11 Tap(v2) / Gas Range
Frigidaire 30-1149-00-12 Tap(v1) / Gas Range
Frigidaire 30-1149-23-01 Tap(v2) / Gas Range
Frigidaire 30-1149-23-02 Tap(v2) / Gas Range
Frigidaire 30-1149-23-03 Tap(v4) / Gas Range
Frigidaire 30-1149-23-04 Tap(v6) / Gas Range
Frigidaire 30-1149-23-05 Tap(v2) / Gas Range
Frigidaire 30-1149-23-06 Tap(v2) / Gas Range
Frigidaire 30-1149-23-07 Tap(v4) / Gas Range
Frigidaire 30-1149-23-08 Tap(v2) / Gas Range
Frigidaire 30-1149-23-10 Tap(v3) / Gas Range
Frigidaire 30-1149-23-11 Tap(v4) / Gas Range
Frigidaire 30-1149-23-12 Tap(v2) / Gas Range
Frigidaire 30-2022-00-11 Tap(v1) / Gas Range
Frigidaire 30-2022-23-11 Tap(v2) / Gas Range
Frigidaire 30-2022-45-11 Tap(v3) / Gas Range
Frigidaire 30-2022-57-11 Tap(v4) / Gas Range
Frigidaire 30-2022-66-11 Tap(v5) / Gas Range
Frigidaire 30-2118-00-01 Tap(v1) / Gas Range
Frigidaire 30-2118-00-02 Tap(v4) / Gas Range
Frigidaire 30-2118-00-03 Tap(v7) / Gas Range
Frigidaire 30-2118-00-04 Tap(v10) / Gas Range
Frigidaire 30-2118-23-01 Tap(v2) / Gas Range
Frigidaire 30-2118-23-02 Tap(v5) / Gas Range
Frigidaire 30-2118-23-03 Tap(v8) / Gas Range
Frigidaire 30-2118-23-04 Tap(v11) / Gas Range
Frigidaire 30-2118-66-01 Tap(v3) / Gas Range
Frigidaire 30-2118-66-02 Tap(v6) / Gas Range
Frigidaire 30-2118-66-03 Tap(v9) / Gas Range
Frigidaire 30-2118-66-04 Tap(v12) / Gas Range
Frigidaire 30-2119-00-01 Tap(v1) / Gas Range
Frigidaire 30-2119-00-02 Tap(v4) / Gas Range
Frigidaire 30-2119-23-01 Tap(v2) / Gas Range
Frigidaire 30-2119-23-02 Tap(v5) / Gas Range
Frigidaire 30-2119-66-01 Tap(v3) / Gas Range
Frigidaire 30-2119-66-02 Tap(v6) / Gas Range
Frigidaire 30-2132-00-01 Tap(v1) / Gas Range
Frigidaire 30-2132-00-02 Tap(v1) / Gas Range
Frigidaire 30-2132-00-03 Tap(v3) / Gas Range
Frigidaire 30-2132-00-04 Tap(v1) / Gas Range
Frigidaire 30-2132-23-01 Tap(v2) / Gas Range
Frigidaire 30-2132-23-02 Tap(v2) / Gas Range
Frigidaire 30-2132-23-03 Tap(v4) / Gas Range
Frigidaire 30-2132-23-04 Tap(v2) / Gas Range
Frigidaire 30-2138-00-01 Tap(v1) / Gas Range
Frigidaire 30-2138-00-02 Tap(v4) / Gas Range
Frigidaire 30-2138-00-03 Tap(v7) / Gas Range
Frigidaire 30-2138-00-04 Tap(v1) / Gas Range
Frigidaire 30-2138-00-05 Tap(v4) / Gas Range
Frigidaire 30-2138-00-06 Tap(v7) / Gas Range
Frigidaire 30-2138-23-01 Tap(v2) / Gas Range
Frigidaire 30-2138-23-02 Tap(v5) / Gas Range
Frigidaire 30-2138-23-03 Tap(v8) / Gas Range
Frigidaire 30-2138-23-04 Tap(v2) / Gas Range
Frigidaire 30-2138-23-05 Tap(v5) / Gas Range
Frigidaire 30-2138-23-06 Tap(v8) / Gas Range
Frigidaire 30-2138-66-01 Tap(v3) / Gas Range
Frigidaire 30-2138-66-02 Tap(v6) / Gas Range
Frigidaire 30-2138-66-03 Tap(v9) / Gas Range
Frigidaire 30-2138-66-04 Tap(v3) / Gas Range
Frigidaire 30-2138-66-05 Tap(v6) / Gas Range
Frigidaire 30-2138-66-06 Tap(v9) / Gas Range
Frigidaire 30-2139-00-01 Tap(v1) / Gas Range
Frigidaire 30-2139-00-02 Tap(v3) / Gas Range
Frigidaire 30-2139-00-03 Tap(v1) / Gas Range
Frigidaire 30-2139-00-04 Tap(v3) / Gas Range
Frigidaire 30-2139-00-05 Tap(v5) / Gas Range
Frigidaire 30-2139-00-06 Tap(v1) / Gas Range
Frigidaire 30-2139-00-07 Tap(v1) / Gas Range
Frigidaire 30-2139-00-08 Tap(v3) / Gas Range
Frigidaire 30-2139-00-09 Tap(v1) / Gas Range
Frigidaire 30-2139-23-01 Tap(v2) / Gas Range
Frigidaire 30-2139-23-02 Tap(v4) / Gas Range
Frigidaire 30-2139-23-03 Tap(v2) / Gas Range
Frigidaire 30-2139-23-04 Tap(v4) / Gas Range
Frigidaire 30-2139-23-05 Tap(v6) / Gas Range
Frigidaire 30-2139-23-06 Tap(v2) / Gas Range
Frigidaire 30-2139-23-07 Tap(v2) / Gas Range
Frigidaire 30-2139-23-08 Tap(v4) / Gas Range
Frigidaire 30-2139-23-09 Tap(v2) / Gas Range
Frigidaire 30-2228-00-01 Tap(v1)
Frigidaire 30-2228-00-02 Tap(v3)
Frigidaire 30-2228-00-03 Tap(v5)
Frigidaire 30-2228-23-01 Tap(v2)
Frigidaire 30-2228-23-02 Tap(v4)
Frigidaire 30-2228-23-03 Tap(v6)
Frigidaire 30-2232-00-01 Tap(v1) / Gas Range
Frigidaire 30-2232-00-02 Tap(v1) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
viking range burner clicks even when lit mattbiel Oven Repair (including Ranges and Cooktops) 6 08-08-2017 09:28 AM
Electric Wolf cooktop burner malfunctioning JustJoan Oven Repair (including Ranges and Cooktops) 0 06-24-2013 12:34 PM
how do I replace ignitor on stove burner (not oven) for a wolf r366 sdfor Oven Repair (including Ranges and Cooktops) 2 01-07-2013 11:59 AM
Wolf Range burner problem rmbelson Heating, Ventilation, and Air Conditioning (HVAC) 0 09-13-2012 11:18 AM
Help troubleshooting burner flame height -- Wolf AS30KI. SuperWolfMan Oven Repair (including Ranges and Cooktops) 0 05-28-2012 01:08 PM
