Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   WOLF Range - one burner clicks after lit (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/553434-wolf-range-one-burner-clicks-after-lit.html)
Liamfm 06-25-2014 07:12 AM
I've got a Wolf propane range (30") 4 burner stove with the open burners. One of my burners (back left) continues to click even after the burner is lit. Sometimes it will stop for a bit, but then starts again.
I'm told I should be looking at continuity on the ignitor and also good ground. I'm pretty proficient with my multimeter, but need some advice on where I should be testing from. Am I looking for ground from the igniter tip to the stove body, or from the bottom/wire or from the wire at the module? Same for continuity and resistance?
Any help is appreciated. 3 of the 4 burners function normally, one is problematic.
Thanks in advance!
Liam
