Discuss
Kenmore Oven Won't get to temp
 in
I have an electric Kenmore oven that won't get to the selected temperature. I removed the temperature sensor and tested
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Oven Won't get to temp
  #1 (permalink)
Old 06-24-2014, 06:01 PM
Junior Member
Dennis.Powell is on a distinguished road
Default Kenmore Oven Won't get to temp
Model Number: 790.95301100   Brand: Kenmore   Age: More than 10 years
I have an electric Kenmore oven that won't get to the selected temperature. I removed the temperature sensor and tested the Ohms at 1090, which I understand is within specs. The oven will not heat to 450, but we can usually get it to go up to 400. If it does not heat properly, we shut it off, wait a few minutes and turn it on again. Usually we can get it to start. I assume it is not the baking or broiling elements. The broiler element always comes on when needed, it is the baking element that does not always come on. Would this mean I need to replace the control panel?
Dennis Powell
Related Models
Kenmore 79015011400 ELECTRIC RANGE
Kenmore 79015011401 ELECTRIC RANGE
Kenmore 79015021400 ELECTRIC RANGE
Kenmore 79015021401 ELECTRIC RANGE
Kenmore 79015031400 ELECTRIC RANGE
Kenmore 79015031401 ELECTRIC RANGE
Kenmore 79015032500 ELECTRIC RANGE
Kenmore 79015051401 GAS RANGE
Kenmore 79030172400 GAS WALLOVEN
Kenmore 79030172401 GAS WALLOVEN
Kenmore 79030179400 GAS WALLOVEN
Kenmore 79030179401 GAS WALLOVEN
Kenmore 79030472400 GAS WALLOVEN
Kenmore 79030472401 GAS WALLOVEN
Kenmore 79030472402 GAS WALLOVEN
Kenmore 79030473400 GAS WALLOVEN
Kenmore 79030473401 GAS WALLOVEN
Kenmore 79030473402 GAS WALLOVEN
Kenmore 79030473403 GAS WALLOVEN
Kenmore 79030474400 GAS WALLOVEN
Kenmore 79030474401 GAS WALLOVEN
Kenmore 79030474402 GAS WALLOVEN
Kenmore 79030479400 GAS WALLOVEN
Kenmore 79030479401 GAS WALLOVEN
Kenmore 79030479402 GAS WALLOVEN
Kenmore 79030503600 GAS COOKTOP
Kenmore 79030503601 GAS COOKTOP
Kenmore 79030522800 WALL OVEN
Kenmore 79030522801 WALL OVEN
Kenmore 79030529800 WALL OVEN
Kenmore 79030529801 WALL OVEN
Kenmore 79030552800 GAS WALLOVEN
Kenmore 79030552802 GAS WALLOVEN
Kenmore 79030553800 GAS WALLOVEN
Kenmore 79030553802 GAS WALLOVEN
Kenmore 79030554800 GAS WALLOVEN
Kenmore 79030554802 GAS WALLOVEN
Kenmore 79030559800 GAS WALLOVEN
Kenmore 79030559802 GAS WALLOVEN
Kenmore 79031003600 GAS COOKTOP
Kenmore 79031013600 GAS COOKTOP
Kenmore 79031023700 SEARS PRO/COOKTOP
Kenmore 79031023701 COOKTOP
Kenmore 79031032800 GAS RANGE
Kenmore 79031032801 GAS RANGE
Kenmore 79031032802 GAS RANGE
Kenmore 79031032804 GAS RANGE
Kenmore 79031033800 GAS RANGE
Kenmore 79031033801 GAS RANGE
Kenmore 79031033802 GAS RANGE
Kenmore 79031033803 GAS RANGE
Kenmore 79031033804 GAS RANGE
Kenmore 79031034800 GAS RANGE
Kenmore 79031034801 GAS RANGE
Kenmore 79031034802 GAS RANGE
Kenmore 79031039800 GAS RANGE
Kenmore 79031039801 GAS RANGE
Kenmore 79031039802 GAS RANGE
Kenmore 79031039804 GAS RANGE
Kenmore 79031042800 GAS RANGE
Kenmore 79031042801 GAS RANGE
Kenmore 79031042802 GAS RANGE
Kenmore 79031042803 GAS RANGE
Kenmore 79031042805 GAS RANGE
Kenmore 79031043800 GAS RANGE
Kenmore 79031043801 GAS RANGE
Kenmore 79031043802 GAS RANGE
Kenmore 79031043803 GAS RANGE
Kenmore 79031043805 GAS RANGE
Kenmore 79031049800 GAS RANGE
Kenmore 79031049801 GAS RANGE
Kenmore 79031049802 GAS RANGE
Kenmore 79031049803 GAS RANGE
Kenmore 79031049805 GAS RANGE
Kenmore 79031053000 GAS RANGE
Kenmore 79031062100 GAS RANGE
Kenmore 79031063100 GAS RANGE
Kenmore 79031069100 GAS RANGE
Kenmore 79031073100 GAS RANGE
Kenmore 79032092400 GAS COOKTOP
Kenmore 79032092401 GAS COOKTOP
Kenmore 79032092402 GAS COOKTOP
Kenmore 79032094400 GAS COOKTOP
Kenmore 79032094401 GAS COOKTOP
Kenmore 79032094402 GAS COOKTOP
Kenmore 79032099400 GAS COOKTOP
Kenmore 79032099401 GAS COOKTOP
Kenmore 79032099402 GAS COOKTOP
Kenmore 79032232400 GAS COOKTOP
Kenmore 79032232401 GAS COOKTOP
Kenmore 79032233400 GAS COOKTOP
Kenmore 79032233401 GAS COOKTOP
Kenmore 79032234400 GAS COOKTOP
Kenmore 79032234401 GAS COOKTOP
Kenmore 79032239400 GAS COOKTOP
Kenmore 79032239401 GAS COOKTOP
Kenmore 79032242400 GAS COOKTOP
Kenmore 79032242401 GAS COOKTOP
Kenmore 79032243400 GAS COOKTOP
Kenmore 79032243401 GAS COOKTOP
Kenmore 79032244400 GAS COOKTOP
Kenmore 79032244401 GAS COOKTOP
Kenmore 79032249400 GAS COOKTOP
Kenmore 79032249401 GAS COOKTOP
Kenmore 79032302000 GAS COOKTOP
Kenmore 79032303000 GAS COOKTOP
Kenmore 79032309000 GAS COOKTOP
Kenmore 79032312000 GAS COOKTOP
Kenmore 79032313000 GAS COOKTOP
Kenmore 79032319000 GAS COOKTOP
Kenmore 79032323000 GAS COOKTOP
Kenmore 79032329000 GAS COOKTOP
Kenmore 79032333000 GAS COOKTOP
Kenmore 79032339000 GAS COOKTOP
Kenmore 79032353000 COOKTOP
Kenmore 79032392400 GAS COOKTOP
Kenmore 79032392401 GAS COOKTOP
Kenmore 79032393700 GAS COOKTOP
Kenmore 79032394400 GAS COOKTOP
Kenmore 79032394401 GAS COOKTOP
  #2 (permalink)
Old 06-25-2014, 03:07 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
If it is just that the bake element does not come on then it could be just a bad bake element.
Unplug the unit and check the bake element resistance, most of them are around 30 ohms.
It is very important to remove power from the unit as one side of the elements is always connected to power.
If the element checks out OK, check rhe wiring to the element.
If that is OK then odds are that the control board is bad.
__________________
  #3 (permalink)
Old 06-25-2014, 10:42 AM
Junior Member
Default Bake element resistance
I tested the bake element and it registered 16 Ohms. Would that mean the element is bad? If you are not sure, where could I find the specs for this element?
Dennis
  #4 (permalink)
Old 06-26-2014, 03:22 AM
Senior Expert
APP Volunteer
Default
Dis some searching and it looks like this element is 3500 watts so the 16 ohms you measure is OK.
__________________
  #5 (permalink)
Old 07-04-2014, 07:39 AM
Junior Member
Default Fixed
Thanks for your help. I replaced the control panel and the oven is working correctly. Thanks again.
Dennis
  #6 (permalink)
Old 07-04-2014, 09:13 AM
Senior Expert
APP Volunteer
Default
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
denman (also a Dennis)
__________________
  #7 (permalink)
Old 08-09-2014, 04:29 PM
Junior Member
Default Not yet fixed
Okay, we have been away for a few weeks, and now the oven is having issues again. The broiler burner stays on and the lower burner does not stay hot. Things are burning on top.
Is it possible I put the connectors back on in reverse positions? The oven is a Kenmore and the replacement control panel was made by Fridgidair. Could this be the problem?
Help again.
  #8 (permalink)
Old 08-11-2014, 04:50 AM
Senior Expert
APP Volunteer
Default
I cannot say.
No.
Kenmore does not make anything.
The 790 at the start of the model number actually tells us that it is a Frigidaire unit.
Have you tried unplugging the unit for several minutes to see if itwill reset?
Read more: Kenmore Oven Won't get to temp
http://forum.appliancepartspros.com
__________________
  #9 (permalink)
Old 08-11-2014, 02:43 PM
Junior Member
Default
Grrrr. I'm growling at myself. I checked the wires and I had crossed them. I had the broil wire on the bake connection and vice versa. Thanks for the help.
Dennis
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Gas Oven inconsistent temp danireland Oven Repair (including Ranges and Cooktops) 0 05-06-2011 11:26 PM
Kenmore oven goes to high, cant set temp. tnbgmn Oven Repair (including Ranges and Cooktops) 1 01-02-2011 01:39 PM
kenmore oven will light, bring oven to temp, but won't re-light after the temp.... weedsnager Oven Repair (including Ranges and Cooktops) 1 12-02-2009 05:28 PM
Kenmore gas oven won't come up to temp mlgardner1221 Oven Repair (including Ranges and Cooktops) 0 02-02-2009 02:32 PM
Kenmore gas oven temp waaay off Craigo Oven Repair (including Ranges and Cooktops) 0 12-06-2008 09:17 PM
