Discuss
Upper oven does not work
 in
I hit the self cleaning button bt mistake and tried to stop it a number of times by shutting the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Upper oven does not work
  #1 (permalink)
Old 06-24-2014, 12:25 PM
Junior Member
billhoch77@yahoo.com is on a distinguished road
Default Upper oven does not work
Model Number: RBD245PDQ4   Brand: Whirlpool   Age: More than 10 years
I hit the self cleaning button bt mistake and tried to stop it a number of times by shutting the circuit breaker off. I din't wait for it to cool down and it kept recycling through the self-clean cycle each time I switched the breaker. Since then the upper oven has not worked, but the lower oven does. I think it is the control panel or thermal fuse or both. The plastic touch screen on the front of the oven has partially de-laminated due to the extended time the oven was going through the self-clean cycles.
Can anyone tell me what the most likely solution is, how do I confirm that, and is this a problem that I can repair with the proper part and guidance from you experts?
Related Models
Whirlpool RBD245PDQ4 ELECTRIC OVEN
Whirlpool RBD245PDQ6 ELECTRIC OVEN
Whirlpool RBD245PDQ7 ELECTRIC OVEN
Whirlpool RBD245PDQ8 ELECTRIC OVEN
Whirlpool RBD245PDQ9 ELECTRIC OVEN
Whirlpool RBD245PDS12 ELECTRIC OVEN
Whirlpool RBD245PDS14 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PDS15 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PDT10 ELECTRIC OVEN
Whirlpool RBD245PDT11 ELECTRIC OVEN
Whirlpool RBD245PDT12 ELECTRIC OVEN
Whirlpool RBD245PDT14 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PDT15 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PDT8 ELECTRIC OVEN
Whirlpool RBD245PDT9 ELECTRIC OVEN
Whirlpool RBD245PRB00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRB02 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRB03 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRB04 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD245PRB05 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD245PRQ00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRQ02 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRQ03 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRQ04 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD245PRQ05 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD245PRS00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRS01 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRS02 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRS03 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRS04 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD245PRS05 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD245PRT00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRT02 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRT03 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD245PRT04 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD245PRT05 24" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD275PDB1 Built-In Oven, Electric
Whirlpool RBD275PDB10 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDB11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDB12 OVEN
Whirlpool RBD275PDB13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDB14 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDB15 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDB2 Built-In Oven, Electric
Whirlpool RBD275PDB3 27" BUILT-IN ELECTRIC OVEN
Whirlpool RBD275PDB4 27" ELECTRIC DOUBLE OVEN
Whirlpool RBD275PDB6 27" ELECTRIC WALL OVEN
Whirlpool RBD275PDB7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD275PDB8 ELECTRIC WALL OVEN
Whirlpool RBD275PDB9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD275PDQ1 Built-In Oven, Electric
Whirlpool RBD275PDQ10 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDQ11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDQ12 OVEN
Whirlpool RBD275PDQ13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDQ14 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDQ15 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDQ2 Built-In Oven, Electric
Whirlpool RBD275PDQ3 27" BUILT-IN ELECTRIC OVEN
Whirlpool RBD275PDQ4 27" ELECTRIC DOUBLE OVEN
Whirlpool RBD275PDQ6 27" ELECTRIC WALL OVEN
Whirlpool RBD275PDQ7 BUILT IN ELECTRIC OVEN
Whirlpool RBD275PDQ8 WALL OVEN
Whirlpool RBD275PDQ9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD275PDS12 BUILT-IN DOUBLE OVEN, ELECTRIC
Whirlpool RBD275PDS14 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDS15 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDT10 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDT11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDT12 OVEN
Whirlpool RBD275PDT13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD275PDT14 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDT15 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PDT8 BUILT-IN OVEN - ELECTRIC
Whirlpool RBD275PDT9 BUILT-IN OVEN - ELECTRIC
Whirlpool RBD275PRB00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PRB02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PRQ00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PRQ02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PRS00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PRS01 27" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION-UPPER SELF-CLEAN (GOLD LINE)
Whirlpool RBD275PRS02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PRT00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PRT02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PVB00 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PVB02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD275PVB03 27" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD275PVQ00 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PVQ02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD275PVQ03 27" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD275PVS00 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PVS02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD275PVT00 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD275PVT02 27" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD275PVT03 27" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD276PDB1 Built-In Oven, Electric
Whirlpool RBD276PDB10 OVEN
Whirlpool RBD276PDB11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD276PDB12 OVEN
Whirlpool RBD276PDB2 Built-In Oven, Electric
Whirlpool RBD276PDB4 27" ELECTRIC DOUBLE OVEN
Whirlpool RBD276PDB6 27" BUILT-IN ELECTRIC OVEN
Whirlpool RBD276PDB7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD276PDB8 BUILT-IN ELECTRIC OVEN
Whirlpool RBD276PDB9 OVEN
Whirlpool RBD276PDQ1 Built-In Oven, Electric
Whirlpool RBD276PDQ10 OVEN
Whirlpool RBD276PDQ11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD276PDQ12 OVEN
Whirlpool RBD276PDQ2 Built-In Oven, Electric
Whirlpool RBD276PDQ4 27" ELECTRIC DOUBLE OVEN
Whirlpool RBD276PDQ6 27" BUILT-IN ELECTRIC OVEN
Whirlpool RBD276PDQ7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD276PDQ8 BUILT-IN ELECTRIC OVEN
Whirlpool RBD276PDQ9 OVEN
Whirlpool RBD277PDB1 ELECTRIC OVEN
Whirlpool RBD277PDB2 ELECTRIC OVEN
Whirlpool RBD277PDB4 ELECTRIC OVEN
Whirlpool RBD277PDQ1 ELECTRIC OVEN
Whirlpool RBD277PDQ2 ELECTRIC OVEN
  #2 (permalink)
Old 06-24-2014, 02:10 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Whirlpool RBD245PDQ4 Wall Oven - AppliancePartsPros.com
If everything else looks normal and the unit stays in preheat (never comes ready) then it is probably the thermal cutoff (item 36 in section 02).
Remove power from the unit and check it with a meter should be 0 ohms.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Upper Oven will not work. Dan1612 Oven Repair (including Ranges and Cooktops) 3 04-30-2012 10:57 AM
KitchenAid Upper oven does not work after cleaning reguser Oven Repair (including Ranges and Cooktops) 0 01-06-2012 12:04 AM
upper oven does not work Igor Oven Repair (including Ranges and Cooktops) 0 11-23-2010 07:08 PM
upper oven doen't work Anna Banana Oven Repair (including Ranges and Cooktops) 3 01-27-2010 08:57 PM
Whirlpool double oven upper won't work dwgourley Oven Repair (including Ranges and Cooktops) 0 07-23-2008 04:19 PM
