Discuss
Frigidaire double ovens not getting to temp
 in
My Frigidaire double ovens will not heat to temp. Both ovens act the same when preheating temp never gets much
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire double ovens not getting to temp
  #1 (permalink)
Old 06-22-2014, 07:58 PM
Junior Member
Gator280 is on a distinguished road
Default Frigidaire double ovens not getting to temp
Model Number: PLEB30T9FCC   Brand: Frigidaire   Age: 5 - 10 years
My Frigidaire double ovens will not heat to temp. Both ovens act the same when preheating temp never gets much more than slightly warm.
When checking voltage at the bottom elements they only get 120v, I thought they should get 240 to become red hot. I have checked that both legs of the double breaker are good Is there a way to check voltage at the relay or control board before removing entire oven? Is there any other part that should be checked that would control both ovens?
Thanks in advance for any help or advice given.
Related Models
Frigidaire PLEB30T9FCC ELECTRIC OVEN
Frigidaire PLEB30T9FCD ELECTRIC OVEN
Frigidaire PLEB30T9FCE ELECTRIC OVEN
Frigidaire PLEC30S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECC Frigidaire/cooktop
Frigidaire PLEC36S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECC Frigidaire/cooktop
Frigidaire PLEF398ACA Frigidaire/range
Frigidaire PLEF398ACB Frigidaire/electric Range
Frigidaire PLEF398ACC Frigidaire/electric Range
Frigidaire PLEF398CCA Frigidaire/electric Range
Frigidaire PLEF398CCB Frigidaire/electric Range
Frigidaire PLEF398CCC Frigidaire/electric Range
Frigidaire PLEF398CCD Frigidaire/electric Range
Frigidaire PLEF398CCE Frigidaire/electric Range
Frigidaire PLEF398DCA Frigidaire/electric Range
Frigidaire PLEF398DCB Frigidaire/electric Range
Frigidaire PLEF398DCC Frigidaire/electric Range
Frigidaire PLEF398DCD Frigidaire/range
Frigidaire PLEF398DCE Frigidaire/range
Frigidaire PLEF398DCH Frigidaire/range
Frigidaire PLEF398DCJ Frigidaire/electric Range
Frigidaire PLEF489ACA Frigidaire/electric Range
Frigidaire PLEF489ACB Frigidaire/electric Range
Frigidaire PLEF489ACC Frigidaire/electric Range
Frigidaire PLEF489ACD Frigidaire/electric Range
Frigidaire PLEF489CCA Frigidaire/electric Range
Frigidaire PLEF489CCB Frigidaire/electric Range
Frigidaire PLEF489CCC Frigidaire/electric Range
Frigidaire PLEF489CCD Frigidaire/electric Range
Frigidaire PLEF489CCE Frigidaire/electric Range
Frigidaire PLEF489CCF Frigidaire/electric Range
Frigidaire PLEF489CCG Frigidaire/electric Range
Frigidaire PLEF489CCH ELECTRIC RANGE
Frigidaire PLEF489GCA ELECTRIC RANGE
Frigidaire PLEFM399DCA Frigidaire/electric Range
Frigidaire PLEFM399DCB Frigidaire/electric Range
Frigidaire PLEFM399DCC Frigidaire/electric Range
Frigidaire PLEFM399DCD Frigidaire/range
Frigidaire PLEFMZ99ECA Frigidaire/range
Frigidaire PLEFMZ99ECC Frigidaire/range
Frigidaire PLEFMZ99ECE Frigidaire/electric Range
Frigidaire PLEFMZ99ECF Frigidaire/electric Range
Frigidaire PLEFMZ99ECG Frigidaire/range
Frigidaire PLEFMZ99ECJ Frigidaire/electric Range
Frigidaire PLEFMZ99ECK Frigidaire/range
Frigidaire PLEFMZ99ECM ELECTRIC RANGE
Frigidaire PLEFMZ99ECN ELECTRIC RANGE
Frigidaire PLEFMZ99GCA ELECTRIC RANGE
Frigidaire PLEFMZ99GCB ELECTRIC RANGE
Frigidaire PLEFMZ99GCC ELECTRIC RANGE
Frigidaire PLEFMZ99GCD ELECTRIC RANGE
Frigidaire PLEFMZ99GCE ELECTRIC RANGE
Frigidaire PLEFZ398ECA Frigidaire/electric Range
Frigidaire PLEFZ398ECB Frigidaire/electric Range
Frigidaire PLEFZ398ECC Frigidaire/range
Frigidaire PLEFZ398ECD Frigidaire/electric Range
Frigidaire PLEFZ398ECE Frigidaire/range
Frigidaire PLEFZ398ECF Frigidaire/range
Frigidaire PLEFZ398GCA ELECTRIC RANGE
Frigidaire PLEFZ398GCB ELECTRIC RANGE
Frigidaire PLEFZ398GCC ELECTRIC RANGE
Frigidaire PLES389ACA Frigidaire/electric Range
Frigidaire PLES389ACB Frigidaire/electric Range
Frigidaire PLES389ACC Frigidaire/electric Range
Frigidaire PLES389ACD Frigidaire/electric Range
Frigidaire PLES389CCA Frigidaire/electric Range
Frigidaire PLES389CCB Frigidaire/electric Range
Frigidaire PLES389CCC Frigidaire/electric Range
Frigidaire PLES389DCA Frigidaire/electric Range
Frigidaire PLES389DCB Frigidaire/electric Range
Frigidaire PLES389DCC Frigidaire/electric Range
Frigidaire PLES389DCD Frigidaire/electric Range
Frigidaire PLES389DCE Frigidaire/electric Range
Frigidaire PLES389ECB Frigidaire/electric Range
Frigidaire PLES389ECC Frigidaire/electric Range
Frigidaire PLES389ECD Frigidaire/electric Range
Frigidaire PLES389ECE Frigidaire/range
Frigidaire PLES389ECF Frigidaire/electric Range
Frigidaire PLES389ECG Frigidaire/electric Range
Frigidaire PLES389ECH Frigidaire/electric Range
Frigidaire PLES389ECI ELECTRIC RANGE
Frigidaire PLES389ECJ ELECTRIC RANGE
Frigidaire PLES399ECB Frigidaire/electric Range
Frigidaire PLES399ECC Frigidaire/electric Range
Frigidaire PLES399ECD Frigidaire/range
Frigidaire PLES399ECE Frigidaire/electric Range
Frigidaire PLES399ECF Frigidaire/electric Range
Frigidaire PLES399ECG Frigidaire/electric Range
Frigidaire PLES399ECH ELECTRIC RANGE
Frigidaire PLES399ECI ELECTRIC RANGE
Frigidaire PLEW27S3ECA Frigidaire/warmer Drawer
Frigidaire PLEW27S3FCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3ACA Frigidaire/warmer Drawer
Frigidaire PLEW30S3CCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3DCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3DCB Frigidaire/warmer Drawer
Frigidaire PLEW30S3FCA Frigidaire/warmer Drawer
Frigidaire PLEW30S3FCB Frigidaire/warmer Drawer
Frigidaire PLFH1779GS0 FREEZER
Frigidaire PLFH1779GS1 FREEZER
Frigidaire PLFH1779GS2 FREEZER
Frigidaire PLFH1779GS3 FREEZER
Frigidaire PLFU1777DS0 Frigidaire/freezer
Frigidaire PLFU1777DS1 Frigidaire/freezer
Frigidaire PLFU1777DS2 Frigidaire/freezer
Frigidaire PLFU1778ES0 Frigidaire/freezer
Frigidaire PLFU1778ES1 Frigidaire/freezer
Frigidaire PLFU1778ES2 Frigidaire/freezer
Frigidaire PLFU1778ES3 FREEZER
Frigidaire PLFU1778ES4 FREEZER
Frigidaire PLFU1778ES5 FREEZER
Frigidaire PLFU1778ES6 FREEZER
Frigidaire PLFU1778ES7 FREEZER
Frigidaire PLFU1778ES8 FREEZER
Frigidaire PLFU2067DS0 Frigidaire/freezer
Frigidaire PLFU2067DS1 Frigidaire/freezer
Frigidaire PLFU2067DS2 Frigidaire/freezer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Double Ovens tango08 Oven Repair (including Ranges and Cooktops) 0 10-17-2011 03:03 PM
U34 Temp Sensor Dacor Double Wall Ovens Mitch409 Oven Repair (including Ranges and Cooktops) 0 01-19-2011 12:32 PM
Dead Whirlpool double ovens chollon Oven Repair (including Ranges and Cooktops) 3 06-02-2010 04:53 AM
Dacor double ovens teamburton Oven Repair (including Ranges and Cooktops) 1 10-26-2009 01:51 PM
double wall ovens cfreemanlvc Oven Repair (including Ranges and Cooktops) 0 09-25-2009 03:30 PM
