Discuss
oven won't light
 in
lp oven/stovetop. replaced the thermocouple but oven pilot still will not light. non electric model. Related Models General Electric  RGA720PK1WH
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven won't light
  #1 (permalink)
Old 06-19-2014, 08:02 AM
Junior Member
wallytheb is on a distinguished road
Default oven won't light
Model Number: rga720pk1wh   Brand: Hotpoint   Age: More than 10 years
Related Models
General Electric RGA720PK1WH Gas range
General Electric RGA724EK1WH Gas range
General Electric RGA724PK1WH Gas range
General Electric RGB501PPA1WH Gas range
General Electric RGB501PPW1WH Gas range
General Electric RGB502PS1WH Gas range
Frigidaire RGB506EY1AD Frg(v1) / Gas Range
Frigidaire RGB506EY1WH Frg(v2) / Gas Range
General Electric RGB506EYAD Electric range
General Electric RGB506EYWH Electric range
General Electric RGB506PY2AD Electric range
General Electric RGB506PY2WH Electric range
General Electric RGB506PYAD Electric range
General Electric RGB506PYWH Electric range
General Electric RGB508BEW1AD Gas range
General Electric RGB508BEW1WH Gas range
General Electric RGB508BEW2AD Gas range
General Electric RGB508BEW2WH Gas range
General Electric RGB508BPW1AD Gas range
General Electric RGB508BPW1WH Gas range
General Electric RGB508ES1 Gas range
General Electric RGB508ES2 Gas range
General Electric RGB508ET1AD Gas range
General Electric RGB508ET1WH Gas range
General Electric RGB508ET2AD Gas range
General Electric RGB508ET2WH Gas range
General Electric RGB508ET3AD Gas range
General Electric RGB508ET3WH Gas range
General Electric RGB508ET4AD Gas range
General Electric RGB508ET4WH Gas range
General Electric RGB508PEA1AD Gas range
General Electric RGB508PEA1WH Gas range
General Electric RGB508PEA2AD Gas range
General Electric RGB508PEA2CT Gas range
General Electric RGB508PEA2WH Gas range
General Electric RGB508PEA3AD Gas range
General Electric RGB508PEA3WH Gas range
General Electric RGB508PEA4AD Gas range
General Electric RGB508PEA4WH Gas range
General Electric RGB508PEA5AD Gas range
General Electric RGB508PEA5WH Gas range
General Electric RGB508PEA6WH Gas range
General Electric RGB508PEH1CT Gas range
General Electric RGB508PEH1WH Gas range
General Electric RGB508PEH2CT Gas range
General Electric RGB508PEH2WH Gas range
General Electric RGB508PEH3CT Gas range
General Electric RGB508PEH3WH Gas range
General Electric RGB508PPA1AD Gas range
General Electric RGB508PPA1WH Gas range
General Electric RGB508PPA2AD Gas range
General Electric RGB508PPA2WH Gas range
General Electric RGB508PPA3AD Gas range
General Electric RGB508PPA3WH Gas range
General Electric RGB508PPA4AD Gas range
General Electric RGB508PPA4WH Gas range
General Electric RGB508PPA5AD Gas range
General Electric RGB508PPA5WH Gas range
General Electric RGB508PPH1AD Gas range
General Electric RGB508PPH1CT Gas range
General Electric RGB508PPH1WH Gas range
General Electric RGB508PPH2AD Gas range
General Electric RGB508PPH2WH Gas range
General Electric RGB508PS1 Gas range
General Electric RGB508PS2 Gas range
General Electric RGB508PT1AD Gas range
General Electric RGB508PT1WH Gas range
General Electric RGB508PT2AD Gas range
General Electric RGB508PT2WH Gas range
General Electric RGB508PT3AD Gas range
General Electric RGB508PT3WH Gas range
General Electric RGB523PPH1CT Gas range
General Electric RGB523PPH1WH Gas range
General Electric RGB523PPH2CT Gas range
General Electric RGB523PPH2WH Gas range
General Electric RGB5241F0 Gas range
General Electric RGB5241F1 Gas range
General Electric RGB524EH1 Electric range
General Electric RGB524EJ1 Gas range
General Electric RGB524EJ2 Gas range
General Electric RGB524EJ3 Gas range
General Electric RGB524EN1 Gas range
General Electric RGB524ER1 Gas range
General Electric RGB524ER2 Gas range
General Electric RGB524ER3 Gas range
General Electric RGB524ER4 Gas range
General Electric RGB524ET1AD Gas range
General Electric RGB524ET1WH Gas range
General Electric RGB524EV1AD Gas range
General Electric RGB524EV1WH Gas range
General Electric RGB524EV2AD Gas range
General Electric RGB524EV2WH Gas range
General Electric RGB524EV3AD Gas range
General Electric RGB524EV3WH Gas range
General Electric RGB524EV4AD Gas range
General Electric RGB524EV4WH Gas range
General Electric RGB524EV5AD Gas range
General Electric RGB524EV5WH Gas range
General Electric RGB524F0 Gas range
General Electric RGB524F1 Gas range
General Electric RGB524GES1 Gas range
General Electric RGB524GES2 Gas range
General Electric RGB524GPS1 Gas range
General Electric RGB524GPS2 Gas range
General Electric RGB524PEA1AD Gas range
General Electric RGB524PEA1WH Gas range
General Electric RGB524PEA2AD Gas range
General Electric RGB524PEA2CT Gas range
General Electric RGB524PEA2WH Gas range
General Electric RGB524PEA3AD Gas range
General Electric RGB524PEA3WH Gas range
General Electric RGB524PEA4AD Gas range
General Electric RGB524PEA4WH Gas range
General Electric RGB524PEA5AD Gas range
General Electric RGB524PEA5WH Gas range
General Electric RGB524PEA6WH Gas range
General Electric RGB524PEH1CT Gas range
General Electric RGB524PEH1WH Gas range
General Electric RGB524PEH2CT Gas range
General Electric RGB524PEH2WH Gas range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven burner wont light or takes a long time to light shadyray Oven Repair (including Ranges and Cooktops) 5 03-21-2016 08:44 PM
Oven will not light, no light on control panel but timer works (Gene) Xray39 Oven Repair (including Ranges and Cooktops) 1 10-30-2011 09:42 AM
Magic Chef oven pilot light won't light. dugduzrepairs Oven Repair (including Ranges and Cooktops) 0 10-20-2011 09:08 PM
Blinking Blue Lights (Oven ON Light & Oven Heating Light bubbah2os Oven Repair (including Ranges and Cooktops) 1 02-05-2010 01:07 PM
magic chef propane oven won't light (has pilot light) A and J Oven Repair (including Ranges and Cooktops) 3 09-19-2008 12:36 PM
