Thermador Oven will Broil, Convection but not bake
I have a Thermador SWM272 that has recently stopped heating up when baking. If I start the oven in bake
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador Oven will Broil, Convection but not bake
  #1 (permalink)
Old 06-18-2014, 06:39 PM
Junior Member
JSewell is on a distinguished road
Default Thermador Oven will Broil, Convection but not bake
Model Number: SWM272   Brand: Thermador   Age: 5 - 10 years
I have a Thermador SWM272 that has recently stopped heating up when baking. If I start the oven in bake mode, it shows 100 F and is on preheat, but there's no heat at all from the bake element, only the broil. The fan runs, and after 30 minutes it will reach 240 degrees or so. If I broil, the top element glows red and heats up. I checked the elements and the convection was burnt up so I replaced it and the bake element too but it still won't bake. I'm testing the convection now and can see the fan spinning and I can see the reflection of the convection element glowing. Not sure what could be causing the problem with just baking.
Related Models
Amana SWP25H REF - SXS/I&W
White Westinghouse SWS1233CQ0 White Westinghouse/washer
White Westinghouse SWS1233CQ1 White Westinghouse/washer
White Westinghouse SWS1233CS0 White Westinghouse/washer
White Westinghouse SWS1233CS1 White Westinghouse/washer
White Westinghouse SWS1233HQ0 WASHER
White Westinghouse SWS1233HQ1 WASHER
White Westinghouse SWS1233HS0 WASHER
White Westinghouse SWS1233HS1 WASHER
White Westinghouse SWS1339CC1 White Westinghouse/washer
White Westinghouse SWS1339CC2 White Westinghouse/washer
White Westinghouse SWS1339HQ0 WASHER
White Westinghouse SWS1339HQ1 WASHER
White Westinghouse SWS1339HS0 WASHER
White Westinghouse SWS1339HS1 WASHER
White Westinghouse SWS1549AQ0 Washer - W.westinghouse
White Westinghouse SWS1549AQ1 Washer - West/grupo Famsa
White Westinghouse SWS1549AQ2 White Westinghouse/washer
White Westinghouse SWS1549AS0 Washer - W.westinghouse
White Westinghouse SWS1549AS1 Washer - West/grupo Famsa
White Westinghouse SWS1549AS2 White Westinghouse/washer
White Westinghouse SWS1649CQ0 White Westinghouse/washer
White Westinghouse SWS1649CQ1 White Westinghouse/washer
White Westinghouse SWS1649CS0 White Westinghouse/washer
White Westinghouse SWS1649CS1 White Westinghouse/washer
White Westinghouse SWS1649HQ0 WASHER
White Westinghouse SWS1649HQ1 WASHER
White Westinghouse SWS1649HS0 WASHER
White Westinghouse SWS1649HS1 WASHER
White Westinghouse SWS833HQ0 WASHER
White Westinghouse SWS833HQ1 WASHER
White Westinghouse SWS833HS0 WASHER
White Westinghouse SWS833HS1 WASHER
White Westinghouse SWS933AQ0 Washer - W.westinghse
White Westinghouse SWS933AQ1 Washer - West/grupo Famsa
White Westinghouse SWS933AQ2 White Westinghouse/washer
White Westinghouse SWS933AS0 Washer - W.westinghse
White Westinghouse SWS933AS1 Washer - West/grupo Famsa
White Westinghouse SWS933AS2 White Westinghouse/washer
White Westinghouse SWSG1031DQ0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DQ1 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS0 White Westinghouse/laundry Center
White Westinghouse SWSG1031DS1 White Westinghouse/laundry Center
White Westinghouse SWSG1031HQ0 LAUNDRY CENTER
White Westinghouse SWSG1031HQ2 LAUNDRY CENTER
White Westinghouse SWSG1031HQ4 LAUNDRY CENTER
White Westinghouse SWSG1031HS0 LAUNDRY CENTER
White Westinghouse SWSG1031HS1 LAUNDRY CENTER
White Westinghouse SWSG1031HS2 LAUNDRY CENTER
White Westinghouse SWSG1031HS4 LAUNDRY CENTER
White Westinghouse SWT1549AQ0 Washer - W.westinghouse
White Westinghouse SWT1549AS0 Washer - W.westinghouse
White Westinghouse SWT933AQ0 Washer - W.westinghouse
White Westinghouse SWT933AS0 Washer - W.westinghouse
White Westinghouse SWX703AQ0 Washer - W.westinghouse
White Westinghouse SWX703AQ1 Washer - West/grupo Famsa
White Westinghouse SWX703AQ2 White Westinghouse/washer
White Westinghouse SWX703AS0 Washer - W.westinghouse
White Westinghouse SWX703AS1 Washer - West/grupo Famsa
White Westinghouse SWX703AS2 White Westinghouse/washer
White Westinghouse SWX703CQ0 White Westinghouse/washer
White Westinghouse SWX703CQ1 White Westinghouse/washer
White Westinghouse SWX703CS0 White Westinghouse/washer
White Westinghouse SWX703CS1 White Westinghouse/washer
White Westinghouse SWX703HQ0 WASHER
White Westinghouse SWX703HQ1 WASHER
White Westinghouse SWX703HS0 WASHER
White Westinghouse SWX703HS1 WASHER
White Westinghouse SWXG831DQ0 White Westinghouse/laundry Center
White Westinghouse SWXG831DQ1 White Westinghouse/laundry Center
White Westinghouse SWXG831DS0 White Westinghouse/laundry Center
White Westinghouse SWXG831DS1 White Westinghouse/laundry Center
White Westinghouse SWXG831HQ1 LAUNDRY CENTER
White Westinghouse SWXG831HQ2 LAUNDRY CENTER
White Westinghouse SWXG831HQ4 LAUNDRY CENTER
White Westinghouse SWXG831HS0 LAUNDRY CENTER
White Westinghouse SWXG831HS1 LAUNDRY CENTER
White Westinghouse SWXG831HS2 LAUNDRY CENTER
White Westinghouse SWXG831HS4 LAUNDRY CENTER
Amana SX19ML REF - SXS/I&W
Amana SX19MW REF - SXS/I&W
Amana SX19NL REF - SXS/I&W
Amana SX19NW REF - SXS/I&W
Amana SX22H REF - SXS/I&W
Amana SX22J REF - SXS/I&W
Amana SX22J Ref - SXS/I&W
Amana SX22MG REF - SXS/I&W
Amana SX22ML REF - SXS/I&W
Amana SX22MW REF - SXS/I&W
Amana SX22NE REF - SXS/I&W
Amana SX22NL REF - SXS/I&W
Amana SX22NW REF - SXS/I&W
Amana SX22SE REF - SXS/I&W
Amana SX22SL REF - SXS/I&W
Amana SX22SW REF - SXS/I&W
Amana SX23VE REF - SXS/I&W
Amana SX23VL REF - SXS/I&W
Amana SX23VW REF - SXS/I&W
Amana SX25H REF - SXS/I&W
Amana SX25J REF - SXS/I&W
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Convection & Bake Elements Don't Work, Broil Element Works Shadam Oven Repair (including Ranges and Cooktops) 4 04-11-2014 07:04 AM
Thermador oven will not Bake,only Broil and Self-clean pjflirty Oven Repair (including Ranges and Cooktops) 1 03-19-2011 07:58 PM
Bosch oven bake and convection bake not heating tbnicky Oven Repair (including Ranges and Cooktops) 1 07-27-2010 07:25 PM
Bosch convection bake and broil not heating 1jazzyldy Oven Repair (including Ranges and Cooktops) 0 03-07-2010 11:38 PM
Oven bake/broil not working after bake element replacement J Justin Oven Repair (including Ranges and Cooktops) 1 11-05-2009 04:36 PM
