Discuss
5 burner gas thermador-x low setting not working
 in
I purchased this 5 burner cooktop used and discovered it has a check date of 6/23/00 -much older than it
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » 5 burner gas thermador-x low setting not working
  #1 (permalink)
Old 06-17-2014, 11:13 AM
Junior Member
Tuolumne Nick is on a distinguished road
Question 5 burner gas thermador-x low setting not working
Model Number: SGCS365RW   Brand: Thermador   Age: More than 10 years
I purchased this 5 burner cooktop used and discovered it has a check date of 6/23/00 -much older than it appeared. All the burners light and adjust thru to low, but NONE of the extra low stay lighted when I turn them to the superlow setting..they click and I can hear the gas valve turn off. It relights fine when I dial it back to low setting, and I hear the valve turn back on at the burner. I am kind of lost here, as I can't seem to get a manual and my experience with cooktops was replacing the valves in a much older unit years ago. (and I got them all in the wrong burners, then!)
This unit was purchased from the fundraising location of Habitat for Humanity, and I was told it was set for LP gas. Not even sure if that was true...but no idea how to tell! Would the unit work at all if it were set up for Natural Gas and I connected it to LP?
I know, a lot of questions here! I really need some help..I am pretty handy with most things, just don't quite understand cooktops.(yet)
Related Models
Thermador SGCS365RW GAS COOKTOP
Thermador SGCS456RB STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RB SN 9803
Thermador SGCS456RS STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RS SN 9803
Thermador SGCS456RW STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RW SN 9803
Thermador SGCV36 COOKTOP
Thermador SGCV3601 COOKTOP
Thermador SGCV36G01 COOKTOP
Thermador SGCV36G02 COOKTOP
Amana SGD22TL REF - SXS/I&W
Amana SGD22TW REF - SXS/I&W
Amana SGD26VL REF - SXS/I&W
Amana SGD26VW REF - SXS/I&W
Amana SGD521SBL REF - SXS/I&W
Amana SGD521SBW REF - SXS/I&W
Amana SGD521SW REF - SXS/I&W
Whirlpool SGDS800HQ0 GAS DRYER
Whirlpool SGDS800JQ0 GAS DRYER
Whirlpool SGDS800JQ1 GAS DRYER
Whirlpool SGDS800JQ2 GAS DRYER
Whirlpool SGDS800MQ0 29"GAS DRYER
Whirlpool SGDS800MQ1 29"GAS DRYER
Whirlpool SGDX600HQ0 DRYER
Whirlpool SGDX600JQ0 DRYER
Whirlpool SGDX600JQ1 DRYER
Whirlpool SGDX600JQ2 DRYER
Whirlpool SGDX600MQ0 29"GAS DRYER
Whirlpool SGDX600MQ1 29"GAS DRYER
Frigidaire SGER341AS0 Frigidaire/dryer
Frigidaire SGER341AS1 Frigidaire/electric Dryer
Frigidaire SGGR341AS0 Frigidaire/dryer
Frigidaire SGGR341AS1 Frigidaire/gas Dryer
Frigidaire SGGR341AS2 Frigidaire/gas Dryer
 SGM365 COOKTOP
Thermador SGN30B GAS COOKTOP
Thermador SGN30S GAS COOKTOP
Thermador SGN30W GAS COOKTOP
Thermador SGN36GB GAS COOKTOP
Thermador SGN36GS GAS COOKTOP
Thermador SGN36GW GAS COOKTOP
Thermador SGNCV36GB GAS COOKTOP
Thermador SGNCV36GS GAS COOKTOP
Thermador SGNCV36GW GAS COOKTOP
Roper SGP335XW0 Range (gas)*
Roper SGP335XW1 Range (gas)*
Roper SGP335XX2 Range (gas)*
White Westinghouse SGQ2152HS0 DRYER
White Westinghouse SGQ2152HS1 DRYER
White Westinghouse SGQ2170KS0 DRYER
 SGQ7000FS0 ELECTROLUX/DRYER
White Westinghouse SGR231CQ0 White Westinghouse/dryer
White Westinghouse SGR231CS0 White Westinghouse/dryer
White Westinghouse SGR231HQ0 DRYER
White Westinghouse SGR231HQ1 DRYER
White Westinghouse SGR231HS0 DRYER
White Westinghouse SGR231HS1 DRYER
White Westinghouse SGR341AQ0 Dryer - W.west
White Westinghouse SGR341AQ1 Dryer - West/grupo Gomo
White Westinghouse SGR341AQ2 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ3 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ4 White Westinghouse/gas Dryer
White Westinghouse SGR341AQ5 White Westinghouse/dryer
White Westinghouse SGR341AS0 Dryer - W.west
White Westinghouse SGR341AS1 Dryer - West/grupo Gomo
White Westinghouse SGR341AS2 White Westinghouse/gas Dryer
White Westinghouse SGR341AS3 White Westinghouse/gas Dryer
White Westinghouse SGR341AS4 White Westinghouse/gas Dryer
White Westinghouse SGR341AS5 White Westinghouse/dryer
White Westinghouse SGR341CC0 White Westinghouse/dryer
White Westinghouse SGR341FC0 White Westinghouse/dryer
White Westinghouse SGR351CQ0 White Westinghouse/dryer
White Westinghouse SGR351CS0 White Westinghouse/dryer
White Westinghouse SGR351FQ0 White Westinghouse/dryer
White Westinghouse SGR351FS0 White Westinghouse/dryer
White Westinghouse SGR351HQ0 DRYER
White Westinghouse SGR351HQ1 DRYER
White Westinghouse SGR351HS0 DRYER
White Westinghouse SGR351HS1 DRYER
White Westinghouse SGR641HQ0 DRYER
White Westinghouse SGR641HQ1 DRYER
White Westinghouse SGR641HS0 DRYER
White Westinghouse SGR641HS1 DRYER
Thermador SGS/X304ZB
Thermador SGS/X304ZS
Thermador SGS/X304ZW
Thermador SGS/X365ZB
Thermador SGS/X365ZS
Thermador SGS/X365ZW
Thermador SGS304ZB
Thermador SGS304ZS
Thermador SGS304ZW
Thermador SGS30B GAS COOKTOP
Thermador SGS30S GAS COOKTOP
Thermador SGS30W GAS COOKTOP
Thermador SGS365ZB
Thermador SGS365ZS
Thermador SGS365ZW
Thermador SGS36GB GAS COOKTOP
Thermador SGS36GS GAS COOKTOP
Thermador SGS36GW GAS COOKTOP
Whirlpool SGS375HQ0 30" GAS FREESTANDING, SELF-CLEAN RANGE
Whirlpool SGS375HQ5 GAS RANGE
Whirlpool SGS375HQ6 GAS RANGE
Whirlpool SGS375HQ7 COOKING PRODUCT - GAS
Roper SGS395XX0 Range (gas)*
Whirlpool SGS395XX1
Whirlpool SGS395XX2
Thermador SGS456ZS
Thermador SGSCV36GB GAS COOKTOP
Thermador SGSCV36GS GAS COOKTOP
Thermador SGSCV36GW GAS COOKTOP
Thermador SGSX304ZB
Thermador SGSX304ZS
Thermador SGSX304ZW
  #2 (permalink)
Old 06-25-2014, 09:46 AM
Junior Member
Therm Owner is on a distinguished road
Default
Just thought I would suggest something as I own a pro line Thermador gas range with 2 xtra-low top burners. once you turn the dial past the simmer setting you get a timed simmer setting which turns the flame on and off for varying amounts of time depending on how low you set it. It is computer controlled and is supposed to turn on and off to get the temperatures lower than the lowest simmer setting. Hope this helps. even though you don't have the same model this may also be how your burner works. wait to see if the burner relights after x number of minutes on its own in the extra low setting range.
  #3 (permalink)
Old 06-26-2014, 05:10 PM
Junior Member
Smile You are correct!!!
Thank you VERY much for suggesting that these burners work by turning the gas valve on and off to maintain the temp! You were 100% correct-I suppose this was something that was in the manual, which, in keeping with my experiences with Thermador (this is my 3rd cooktop of theirs in the last 30 years) is NEVER available once they discontinue a model. It's like they don't want people to have them. Sheesh. Thanks again! -Tuolumne Nick
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador cooktop - burner not working lbellerjeau Oven Repair (including Ranges and Cooktops) 4 02-24-2012 03:12 PM
Thermador XLO burner still not working! DrHomes Oven Repair (including Ranges and Cooktops) 0 05-06-2011 10:30 AM
Thermador XLO burner still not working! DrHomes Oven Repair (including Ranges and Cooktops) 0 05-06-2011 10:29 AM
Thermador cooktop burner not working lbellerjeau Oven Repair (including Ranges and Cooktops) 0 02-13-2010 11:19 AM
thermador 4 burner top not working Hacsta Oven Repair (including Ranges and Cooktops) 1 06-29-2009 06:43 AM
