Discuss
Old Caloric oven won't ignite
 in
My parents have an ancient Caloric RWP214 gas oven that won't ignite. The electric igniter coil seems to be getting
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Old Caloric oven won't ignite
  #1 (permalink)
Old 06-17-2014, 07:22 AM
Junior Member
Alan McRae is on a distinguished road
Unhappy Old Caloric oven won't ignite
Model Number: RWP214   Brand: Caloric   Age: More than 10 years
My parents have an ancient Caloric RWP214 gas oven that won't ignite. The electric igniter coil seems to be getting pretty hot, but the gas safety valve never sends any gas to the burner. While I don't have a tool to measure the igniter coil temperature, I could put an ammeter on the igniter coil leads to measure how much current it is drawing. If you could tell me how many amps the gas safety valve needs to see the igniter drawing before it will open, then I could tell if I have a bad igniter or a bad safety valve. (I'm pretty handy with tools & technical procedures, so if it turns out to be the igniter that repair is a no-brainer. But if it's the gas safety valve, then I'd have to think about that as it requires pulling the whole oven out of its cabinet to get at the valve unit.) I know the oven is ancient, but my parents are ancient as well, so funding is very limited. I'd rather DIY repair than have them spend a chunk of their retirement savings on something they only use occasionally. (God bless the microwave.) Thanks for any help you can render.
Related Models
Amana RWS202 SURFACE UNIT- GAS
Amana RWS202UD SURFACE UNIT- GAS
Amana RWS212 SURFACE UNIT- GAS
Amana RWS212U0 SURFACE UNIT- GAS
Amana RWS214 SURFACE UNIT- GAS
Amana RWS214U0 SURFACE UNIT- GAS
Amana RWS214UD SURFACE UNIT- GAS
Amana RWS214UWW SURFACE UNIT- GAS
Amana RWS216 SURFACE UNIT- GAS
Amana RWS216U0 SURFACE UNIT- GAS
General Electric RX66001 Electric range
General Electric RX66002 Electric range
Amana RXS212 SURFACE UNIT- GAS
Amana RXS212U0 SURFACE UNIT- GAS
Amana RXS214 SURFACE UNIT- GAS
Amana RXS214U0 SURFACE UNIT- GAS
Amana RXS216 SURFACE UNIT- GAS
Amana RXS216U0 SURFACE UNIT- GAS
Whirlpool RY160LXTB0 30" Slide-In Electric Range
Whirlpool RY160LXTB02 30" DROP-IN ELECTRIC RANGE
Whirlpool RY160LXTB1 30" DROP-IN ELECTRIC RANGE
Whirlpool RY160LXTB2 30" DROP-IN ELECTRIC RANGE
Whirlpool RY160LXTQ0 30" Slide-In Electric Range
Whirlpool RY160LXTQ02 30" DROP-IN ELECTRIC RANGE
Whirlpool RY160LXTQ1 30" DROP-IN ELECTRIC RANGE
Whirlpool RY160LXTQ2 30" DROP-IN ELECTRIC RANGE
Whirlpool RY160LXTS0 30" Slide-In Electric Range
Whirlpool RY160LXTS03 30" Drop-In Electric Range
Whirlpool RY160LXTS3 30" Drop-In Electric Range
Gaggenau RY4951 REF - BOTTOM MOUNTS
Maytag RY4951000W2 REFRIGERATOR
Maytag RY4951000W3 REFRIGERATOR
Maytag RY495111 REFRIGERATOR
Amana RYD249 SURFACE UNIT- GAS
Amana S-22 REF - SXS/I&W
Amana S100 MISC / ACCESSORY
Jenn-Air S100 RANGE- S/I STD DDRAFT ELE
Hoover S1003
Hoover S1005--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Jenn-Air S101 RANGE- S/I STD DDRAFT ELE
Hoover S1015--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1015030 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1015031 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1015032 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1015033 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1015075 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1017
Hoover S1019--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1019030 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1021--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1021030 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1029--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1029075 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1049--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1049-22
Hoover S1049060 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Jenn-Air S105 RANGE- S/I STD DDRAFT ELE
Jenn-Air S105-C RANGE- S/I STD DDRAFT ELE
Admiral S1050EH-Z RANGE- F/S STD ELE
Admiral S1050EJ-Z RANGE- F/S STD ELE
Hoover S1055
Hoover S1057300
Hoover S1057400
Hoover S1057600 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1057700
Hoover S1057800
Hoover S1059--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1059030 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1059130 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1059600 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1061
Hoover S1063
Admiral S1068H-CZW RANGE- S/C S/I ELE
Admiral S1068J-CHZW RANGE- S/C D/I ELE
General Electric S1070A0WW Washer
General Electric S1070A1WW Washer
General Electric S1070A2WW Washer
General Electric S1070A4WW Washer
General Electric S1070A5WW Washer
Admiral S1070EH-KZ RANGE- F/S STD GAS
Admiral S1070EH-Z RANGE- F/S STD GAS
Admiral S1070EJ-KZ RANGE- F/S STD GAS
Admiral S1070EJ-Z RANGE- F/S STD GAS
Hoover S1071--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1071800 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1073--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1075--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1075033
Hoover S1075060 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1077--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1077060 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Admiral S1078EH-KZ RANGE- F/S STD GAS
Admiral S1078H-KLVW RANGE-F/S CONT CLEAN GAS
Admiral S1078W-KLVW RANGE-F/S CONT CLEAN GAS
Hoover S1079--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1079060 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1083--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1083100 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Admiral S1088H-CKZW RANGE- S/C S/I GAS
Admiral S1088J-TKZW RANGE- S/C S/I GAS
Hoover S1093
Hoover S1095
Jenn-Air S110 RANGE- S/I STD DDRAFT ELE
Hoover S1101---
Hoover S1103--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1105--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1112--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1112050 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1114--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1117900 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1117981 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1120--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1120050 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
  #2 (permalink)
Old 06-17-2014, 05:33 PM
Junior Member
AllAroundAppliance is on a distinguished road
Default
Hello, thank you for asking your question here.
The flat igniter should draw 3.2 amps to open the gas valve. If the igniter is glowing then we know the thermostat is good because it's sending 110v to the igniter.
The most common issue on these older units is the igniters. Over time the igniters get weak and do not draw enough amps to open the gas valve. Check the amp draw on the valve if it's less then 3.2 the igniter is bad. I suspect you will find that the igniter is weak.
You can purchase the part here by clicking on the link below.
Igniter Link Click Here
Appliance Repair Portland
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't ignite; front burners won't ignite SweetMary Oven Repair (including Ranges and Cooktops) 0 07-25-2011 11:32 AM
Caloric Wall Oven Won't Ignite DMilano Oven Repair (including Ranges and Cooktops) 0 07-24-2011 03:45 PM
Caloric, gas oven will not ignite WC H Oven Repair (including Ranges and Cooktops) 0 06-26-2010 06:03 PM
Will Not Ignite ;caloric Double Oven Rwd 212 bobd1950 Oven Repair (including Ranges and Cooktops) 1 11-29-2008 07:52 PM
Caloric Gas Even slow to Ignite & heat up Dwbradley Oven Repair (including Ranges and Cooktops) 2 10-26-2007 02:00 PM
