Discuss
How to replace surface burner igniters
 in
The ceramic sleeve around two of the surface spark igniters on a client's gas range are broken and do not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » How to replace surface burner igniters
  #1 (permalink)
Old 06-10-2014, 09:46 AM
Junior Member
seekmocha is on a distinguished road
Default How to replace surface burner igniters, corroded in place.
Model Number: SF315PEEQ   Brand: Whirlpool   Age: More than 10 years
The ceramic sleeve around two of the surface spark igniters on a client's gas range are broken and do not spark, so I'm going to replace all four igniters. This is a 22 year old Whirlpool Super Capacity 465 freestanding range. The igniters look like they are corroded in place. I have not yet looked under the cooktop to see what holds them from underneath. I have the repair manual and the parts drawing, which are also not clear as to how the igniters are held in place. And your generic video shows how to replace the igniters in a brand new stove, which does not address the real world issues of dealing with parts rusted in place.
The last time I fixed a stove this old, I ended up grinding out and drilling out the old corroded fastening hardware in order to get inside the cooktop. No amount of corrosion busting chemicals were able to loosen up the old hardware.
So I have several questions: One, what holds the igniters in place on this model range, and is it likely to be something that's rusted into permanent non-movement? Is there any kind of spring clip or mounting bracket, not shown on the parts diagram that I should assume will need replacement?
More generally, what do the experts use for breaking loose old, rusted-in-place hardware?
Related Models
Whirlpool SF315PEEQ0 GAS RANGE
Whirlpool SF315PEEW0 GAS RANGE
Whirlpool SF315PEGN0 GAS RANGE
Whirlpool SF315PEGN1 GAS RANGE
Whirlpool SF315PEGN5 GAS RANGE
Whirlpool SF315PEGN6 GAS RANGE
Whirlpool SF315PEGQ0 GAS RANGE
Whirlpool SF315PEGQ1 GAS RANGE
Whirlpool SF315PEGQ5 GAS RANGE
Whirlpool SF315PEGQ6 GAS RANGE
Whirlpool SF315PEGT5 GAS RANGE
Whirlpool SF315PEGT6 GAS RANGE
Whirlpool SF315PEGV5 GAS RANGE
Whirlpool SF315PEGV6 GAS RANGE
Whirlpool SF315PEGW0 GAS RANGE
Whirlpool SF315PEGW1 GAS RANGE
Whirlpool SF315PEGW5 GAS RANGE
Whirlpool SF315PEGW6 GAS RANGE
Whirlpool SF315PEKB1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRO
Whirlpool SF315PEKQ0 GAS RANGE
Whirlpool SF315PEKQ1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRO
Whirlpool SF315PEKT0 GAS RANGE
Whirlpool SF315PEKT1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRO
Whirlpool SF315PEKV0 GAS RANGE
Whirlpool SF315PEKV1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRO
Whirlpool SF315PEKW0 GAS RANGE
Whirlpool SF315PEKW1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRO
Whirlpool SF315PEMB0 STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEMB1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEMQ0 STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEMQ1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEMT0 STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEMT1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEMW0 STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEMW1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPB0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPB1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPB2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPB3 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPQ0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPQ1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPQ2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPQ3 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPQ4 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPT0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPT1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPT2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPT3 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPW0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPW1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPW2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF315PEPW3 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF316PEPW0 Range (gas)*
Whirlpool SF316PERW0 30" GAS FREESTANDING RANGE ELECTRONIC IGNITION STANDARD CLEAN OVEN
Whirlpool SF316PESW0 Range (gas)*
Whirlpool SF316PESW1 Range (gas)*
Whirlpool SF316PESW2 Range (gas)*
Whirlpool SF316PESW3 Range (gas)*
Whirlpool SF316PESW4 Range (gas)*
Whirlpool SF316PESW5 Range (gas)*
Whirlpool SF316PESW6 Range (gas)*
Whirlpool SF316PESW7 Range (gas)*
Whirlpool SF316PEWN0 30" GAS FREESTANDING RANGE STANDARD CLEAN OVEN
Whirlpool SF316PEWW0 30" GAS FREESTANDING RANGE STANDARD CLEAN OVEN
Whirlpool SF316PSPW0 Range (gas)*
Whirlpool SF317PCYW0 Range (gas)*
Whirlpool SF317PEAN0 GAS FREE STANDING RANGE
Whirlpool SF317PEAN1 GAS RANGES & OVENS
Whirlpool SF317PEAN2 GAS RANGES & OVENS
Whirlpool SF317PEAN3 30" GAS FREESTANDING RANGE SEALED BURNER STANDARD CLEAN OVEN
Whirlpool SF317PEAN4 30" GAS FREESTANDING RANGE STANDARD CLEAN OVEN
Whirlpool SF317PEAW0 GAS FREE STANDING RANGE
Whirlpool SF317PEAW1 GAS RANGES & OVENS
Whirlpool SF317PEAW2 GAS RANGES & OVENS
Whirlpool SF317PEAW3 30" GAS FREESTANDING RANGE SEALED BURNER STANDARD CLEAN OVEN
Whirlpool SF317PEAW4 30" GAS FREESTANDING RANGE STANDARD CLEAN OVEN
Whirlpool SF317PEXW0 Range (gas)*
Whirlpool SF317PEYN0 GAS RANGE
Whirlpool SF317PEYN1 GAS RANGE
Whirlpool SF317PEYW0 GAS RANGE
Whirlpool SF317PEYW1 GAS RANGE
Whirlpool SF318PEWN0 30" SEALED GAS FREESTANDING RANGE ELECTRONIC IGNITION
Whirlpool SF318PEWN1 30" SEALED GAS FREESTANDING RANGE ELECTRONIC IGNITION
Whirlpool SF318PEWQ0 30" SEALED GAS FREESTANDING RANGE ELECTRONIC IGNITION
Whirlpool SF318PEWQ1 30" SEALED GAS FREESTANDING RANGE ELECTRONIC IGNITION
Whirlpool SF318PEWW0 30" SEALED GAS FREESTANDING RANGE ELECTRONIC IGNITION
Whirlpool SF318PEWW1 30" SEALED GAS FREESTANDING RANGE ELECTRONIC IGNITION
Whirlpool SF318PEWZ0 30" SEALED GAS FREESTANDING RANGE ELECTRONIC IGNITION
Whirlpool SF318PEWZ1 30" SEALED GAS FREESTANDING RANGE ELECTRONIC IGNITION
Whirlpool SF325LEKQ0 RANGE
Whirlpool SF325LEKQ1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRO
Whirlpool SF325LEKT0 RANGE
Whirlpool SF325LEKT1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRO
Whirlpool SF325LEKW0 RANGE
Whirlpool SF325LEKW1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRO
Whirlpool SF325PEEN0 GAS RANGE AND OVEN
Whirlpool SF325PEEQ0 Free Standing, Gas
Whirlpool SF325PEEW0 GAS RANGE AND OVEN
Whirlpool SF325PEEZ0 Free Standing, Gas
Whirlpool SF325PEGN0 30" GAS RANGE
Whirlpool SF325PEGN1 30" GAS RANGE
Whirlpool SF325PEGN4 GAS FREESTANDING RANGE
Whirlpool SF325PEGN5 GAS FREESTANDING RANGE
Whirlpool SF325PEGN6 FREE STANDING, GAS
Whirlpool SF325PEGQ0 30" GAS RANGE
Whirlpool SF325PEGQ1 30" GAS RANGE
Whirlpool SF325PEGQ6 FREE STANDING, GAS
Whirlpool SF325PEGS5 GAS RANGE
Whirlpool SF325PEGT5 RANGE
Whirlpool SF325PEGT6 FREE STANDING, GAS
Whirlpool SF325PEGW0 30" GAS RANGE
Whirlpool SF325PEGW1 30" GAS RANGE
Whirlpool SF325PEGW4 GAS FREESTANDING RANGE
Whirlpool SF325PEGW5 GAS FREESTANDING RANGE
Whirlpool SF325PEGW6 FREE STANDING, GAS
Whirlpool SF325PEGZ0 30" GAS RANGE
Whirlpool SF325PEGZ1 30" GAS RANGE
Whirlpool SF325PEGZ4 GAS FREESTANDING RANGE
Whirlpool SF325PEGZ5 GAS FREESTANDING RANGE
Whirlpool SF325PEGZ6 FREE STANDING, GAS
  #2 (permalink)
Old 06-10-2014, 03:23 PM
Junior Member
Larry75243 is on a distinguished road
Default
Sounds like a real pain if they are corroded in place!
I looked at the parts diagram and saw where the ignitor fits in and you're right, it doesn't really show much as to how it is held in.
I'm guessing this is what you are replacing, the top burner ignitors?
Whirlpool 8053717 Top Burner Igniter - AppliancePartsPros.com
I own an older freestanding gas range that has parts that look very similar to this one and when I was having problems with it starting, mine wasn't those ceramic ignitors that actually create the spark on top of the range, it was the square ignitor control switches.
Whirlpool 3196690 Igniter Switch - AppliancePartsPros.com
In mine, they were behind what your model calls the manifold, Section 03, and I discovered 2 were cracked and due to having my elderly mom here part of the year and not wanting her to worry about it not lighting, I replaced all 4.
If those are all working, and hopefully they are because they are showing $40 for each one, without having to do any drilling of the corrosion, have you tried vinegar to remove the corrosion to get the busted ceramic tip out??
It is cheap and simple.
Remove the burner top that holds the ignitor and remove the wire.
Find something that will hold the part that is just a bit bigger around and deep enough where the stuck ignitor will be covered.
Put the burner top in and pour straight apple cider vinegar on it till it covers the corroded part.
Check it daily.
After 36-48 hours, check it and see if the part pops out. Maybe tap on it with something about the size of a punch?
I had a pair of linesmen pliers I found outside in a vacant lot, no idea how long they had been out there but they were rusted shut and solid. Nothing would penetrate to free them up. I tried putting them in a vise and driving a wedge of wood between the handles after hitting with penetrating oil a few times, nothing.
Stuck them into an old narrow Tupperware container and filled to just above the hinge point.
After 3 days they opened up and I hit them with a bit of WD-40 and they've been fine since.
Unless you are in a hurry to get them out, I'd try this trick once on one of them and see how long it takes for the vinegar to cut into the corrosion. It did not hurt any of the other metal, just cut into the rust.
Hope this helps and good luck.
  #3 (permalink)
Old 06-10-2014, 10:11 PM
Junior Member
Default
I was hoping that I would not have to unscrew the burner tops, the mounting screws for the two burners that are not working are totally rusted. Looks like that is a vain hope. I'm guessing the spark igniter is sandwiched between the cooktop and the burner, but I sure wish somebody would confirm or deny that for me.
Would like to know in advance what the screw sizes are so I can get some stainless steel replacements.
I like the idea of using vinegar to dissolve the rust, although I will probably use a stronger CLR (Calcium/Lime/Rust remover) hoping for faster action, since the client may not appreciate being without the stove for a day or so while the rust is soaking. In the past I've tried Liquid Wrench and PB Blaster with no success, even after waiting an hour for soak time.
  #4 (permalink)
Old 06-16-2014, 05:38 PM
Junior Member
Default
FYI, I ended up using a Dremel tool to grind off the tops of the burner screws so I could get it all apart. The square recess on 6 of the eight screws was rusted to uselessness. Grinding took a long time - later I discovered that it was possible to grab the the other end of the screws with vice grips and turn them enough to break them loose from the rust. I replaced them all with 8-32 x 1/2 stainless steel button head hex recess screws.
PB Blaster corrosion dissolver and vinegar had no effect on breaking the screws loose.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
burner igniters continually operate hanknj Oven Repair (including Ranges and Cooktops) 0 09-22-2013 07:02 PM
Surface Burners Igniters not working Patrick Christol Oven Repair (including Ranges and Cooktops) 1 11-11-2012 03:42 PM
Igniters keep clicking after burner lights rsisk Oven Repair (including Ranges and Cooktops) 3 09-17-2008 07:38 AM
burner igniters fire continously Mark65 Oven Repair (including Ranges and Cooktops) 0 10-08-2007 02:51 PM
Burner (all 4) igniters failed Charlie2 Oven Repair (including Ranges and Cooktops) 0 10-06-2007 12:00 PM
