Discuss
Oven will not bake or broil after wire arcd
 in
Hello my GE Wall Ovens baking element went out so I had removed it.My broil element was working fine Someone
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven will not bake or broil after wire arcd
  #1 (permalink)
Old 06-06-2014, 10:55 PM
Junior Member
Sublime89 is on a distinguished road
Default Oven will not bake or broil after wire arcd
Model Number: JRS04G0P1BG   Brand: GE   Age: More than 10 years
Someone in family turned on oven to bake position after i had disconnected the wire terminals from the baking element and the wire arcd and melted the terminal off one side of wire going to the baking element and also melted part of the heat shield on baking element.
The broil element was working before this and now it is not working either.The oven indication light does come on for broil but does not light up when knob is turned to bake or time bake.
I replaced the terminal on wire and and bought a new baking element and installed it and the oven is still not working.
When i turn it on broil the indication light comes on but there is no heat.(I probably should have bought a new broil element too)
When i turn it on bake the indication light does not come on but the element gets very hot but does not glow red like normal.
Can someone tell me what the problem could be?
I have not taken the oven out from the wall yet.I think i may need to buy a voltage tester/ multimeter before i continue with that step.
Related Models
General Electric JRS04GP1 Electric range
General Electric JRS04GP2BG Electric range
General Electric JRS04GT1BB Electric range
General Electric JRS04GV1BB Electric range
General Electric JRS06BJ1BB Electric range
General Electric JRS06SK1SS Electric range
Jenn-Air JRS1202W REF - SXS
Jenn-Air JRS202 REF - SXS
Jenn-Air JRS202B REF - SXS
Jenn-Air JRS202H REF - SXS
Jenn-Air JRS202L REF - SXS
Jenn-Air JRS202N REF - SXS
Jenn-Air JRS202W REF - SXS
Jenn-Air JRS203 REF - SXS
Jenn-Air JRS203-AQ01B JENN-AIR REFRIGERATION
Jenn-Air JRS203-BQ01A JENN-AIR REFRIGERATION
Jenn-Air JRS203B Ref - Sxs
Jenn-Air JRS205L REF - SXS
Jenn-Air JRS205W REF - SXS
Jenn-Air JRS206A REF - SXS
Jenn-Air JRS206W REF - SXS
Jenn-Air JRS221 REF - SXS
Jenn-Air JRS223 REF - SXS
Jenn-Air JRS223B REF - SXS
Jenn-Air JRS223L REF - SXS
Jenn-Air JRS223N REF - SXS
Jenn-Air JRS223W REF - SXS
Jenn-Air JRS226 REF - SXS
Jenn-Air JRS226B REF - SXS
Jenn-Air JRS226L REF - SXS
Jenn-Air JRS226N REF - SXS
Jenn-Air JRS226W REF - SXS
Jenn-Air JRS227B REF - SXS
Jenn-Air JRS227W REF - SXS
Jenn-Air JRS228B REF - SXS
Jenn-Air JRS228W REF - SXS
Jenn-Air JRS229A REF - SXS
Jenn-Air JRS229B REF - SXS
Jenn-Air JRS229W REF - SXS
Jenn-Air JRSD209A REF - SXS/I&W
Jenn-Air JRSD209B REF - SXS/I&W
Jenn-Air JRSD209TA REF - SXS/I&W
Jenn-Air JRSD209TB REF - SXS/I&W
Jenn-Air JRSD209TW REF - SXS/I&W
Jenn-Air JRSD209W REF - SXS/I&W
Jenn-Air JRSD224 REF - SXS/I&W
Jenn-Air JRSD224B REF - SXS/I&W
Jenn-Air JRSD224L REF - SXS/I&W
Jenn-Air JRSD224N REF - SXS/I&W
Jenn-Air JRSD224W REF - SXS/I&W
Jenn-Air JRSD225 REF - SXS/I&W
Jenn-Air JRSD2250A REF - SXS/I&W
Jenn-Air JRSD2250W REF - SXS/I&W
Jenn-Air JRSD225B Ref - SXS/I&W
Jenn-Air JRSD225L REF - SXS/I&W
Jenn-Air JRSD226 REF - SXS/I&W
Jenn-Air JRSD226B Ref - SXS/I&W
Jenn-Air JRSD227B REF - SXS/I&W
Jenn-Air JRSD227W REF - SXS/I&W
Jenn-Air JRSD229A REF - SXS/I&W
Jenn-Air JRSD229B REF - SXS/I&W
Jenn-Air JRSD229W REF - SXS/I&W
Jenn-Air JRSD245 REF - SXS/I&W
Jenn-Air JRSD2450A REF - SXS/I&W
Jenn-Air JRSD2450W REF - SXS/I&W
Jenn-Air JRSD245B REF - SXS/I&W
Jenn-Air JRSD245L REF - SXS/I&W
Jenn-Air JRSD245N REF - SXS/I&W
Jenn-Air JRSD245W REF - SXS/I&W
Jenn-Air JRSD246 REF - SXS/I&W
  #2 (permalink)
Old 06-07-2014, 05:51 PM
Junior Member
Default
I removed oven from the wall and took it apart and found that the power harness connection leading to control board had melted the red power wire when the baking element had arcd.
This is why the baking element would only heat up a little and the broil element would not heat up at all because they were not getting full power.The red power wire that was burnt connects to the limit switch that controls both bake and broil element.
I cut the red wire on both sides of burnt connection and stripped wire and wired them together.
The oven now works and heats up when turned to broil or bake and the indication light works now for bake when turned on.
Hope this helps someone who made the same mistake as me.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven doesn't get hot on bake or broil Bobbi0411 Oven Repair (including Ranges and Cooktops) 1 09-07-2013 04:40 AM
gas oven won't bake or broil mecole33 Oven Repair (including Ranges and Cooktops) 0 12-21-2010 11:37 AM
Oven bake/broil not working after bake element replacement J Justin Oven Repair (including Ranges and Cooktops) 1 11-05-2009 04:36 PM
Rebuild coiled wire bake/broil elements nyhouzi Oven Repair (including Ranges and Cooktops) 0 11-23-2008 09:37 AM
gas oven no broil or bake joekoool3 Oven Repair (including Ranges and Cooktops) 2 09-05-2008 08:14 AM
