Hi I am replacing the infinite switch for the dual burner on my Amana AKT3650WW. The original switch has TUDP416 marked on it, the replacement is 12002125. I have read through this thread but the wires I have on my original switch are different colors and the terminals numbered differently. I thought I had it figured out, but truth is I need some expert help.
Original switch N - three red wires attached to it 2 - two black wires and a brown wire 3 - a blue and white wire 4 - a blue wire 5 - a yellow wire
New switch (my attempt) P1 - dual black - connecting all switches & jumper to S1 P2 - dual red - connecting all switches S1 - jumper back to P1 S2 - yellow - indicator light 2 - single red that goes to element sensor 4 - blue - outside element 4a - blue & white - inside element
So my confusion is around what the brown wire is for that is piggybacked to the dual black on the original switch. Is the single red the correct one to connect to 2.
Any help you can give me is greatly appreciated.
