| » Left two burners fail to light - Frigidare Range |
Model Number: FGF374CCSG Brand: Frigidaire Age: 1 - 5 years
This is a stand alone four burner range with oven. Recently the left two burners fail to light but can be light with a match. The right two burners light on demand.
When any of the burner controls are set to the light position, I hear and see the spark of the igniter on the right two burners but do not see the spark on the left two burners. I have cleaned the metal surfaces around the igniters on all burners but this did not appear to help. Here are my questions: 1.) It would appear that the burner control switches are OK since I get spark activity from all four burner controls. How can I determine if the problem is in the Igniter Wiring Harness (dwg #3, Item #8) or in the Igniter Module (dwg#3, Item #8)? 2.) How do I gain access to the Igniter Module or Wiring Harness? From the rear of the unit or where? Thank you, LSchm Related Models |
Most likely the problem is a bad igniter module.
According to the break down diagram it should be on the back of the unit, under the rear cover. - The part number for the igniter module is AP2126193 Here are the break down diagrams for the Frigidaire range Model FGF374CCSG Gene.
__________________
Professional appliance repair in Orange County, California. |
Jood,
Most likely the problem is a bad spark (aka ignition) module. - The part number for the spark module is AP2126193 Gene.
__________________
It could be under the top panel or behind the rear cover.
__________________
If no one igniter works then it has nothing to do with ignition switches.
Gene. P.S.By the way, I did not see any opposed replies and the part# PS437415 does not look as a valid Frigidaire part number.
__________________
| Display Modes | |
| burners light sometimes | Dondo | Oven Repair (including Ranges and Cooktops) | 1 | 01-18-2008 03:56 PM |
| Range burners all stopped working | andynanneda | Oven Repair (including Ranges and Cooktops) | 0 | 01-18-2008 05:38 AM |
| Whirlpool range right burners out | bdgreene | Oven Repair (including Ranges and Cooktops) | 0 | 12-30-2007 01:23 PM |
| gas range burners not working properly | Larry216 | Oven Repair (including Ranges and Cooktops) | 1 | 12-10-2007 12:00 PM |
| Burners do not always light | urbandesigner123 | Oven Repair (including Ranges and Cooktops) | 0 | 10-01-2007 02:05 PM |
