The oven stopped working. I was told to replace the control board, which I did. I did replace it recently.
The problems I had before I did replace the control board were:
- the clock shows rhe time but I can't put it at the proper time, even when I press set up, the word cloch appears but nothing happen when I push the arrow;
- when I press convect, the words conv \ bake shows up, but it does nothing when I press the arrow;
- Timer 1 and 2 are working;
- the oven light doesn't work;
- when I press back and enter at the same time for locking the door, it works, the word continue shows up, nothing happen when I push it; by pushing back and enter at the same time, it does unlock the door;
- all the range surface elements are working porperly and so the warm zone and the warm drawer;
I would appreciate receiving some help regarding these matters.
Thank you !
