I have an old oven and when baking food or cookies it bakes the outside too quickly and burns while the inside is under-cooked. Also looks like the back and front are not baked the same. I am unable to find on the internet a replacement for the thermostat - no longer available from the manufacturer. Also am unable to calibrate the temperature dial to be lower. Would you know of a compatible thermostat? Thanks.
