pawpace
#1 Posted : Monday, April 28, 2014 10:15:07 AM(UTC)
pawpace
Bottom oven would not come on so replaced the heating element. It came on for a while and then quit working. Now the top and bottom ovens will not come on. If it is the control board, can the control board be repaired or do you need to buy a new one. Due to the expense of a new board, I am not sure if it is worth repairing a 14 year old range.
Thanks for you help.
Mike
#2 Posted : Tuesday, April 29, 2014 3:33:47 AM(UTC)
Parts for Maytag MER6770AAQ Range - AppliancePartsPros.com
Below is a service manual.
You will have to join the site and be logged in to be able to download the manual.
http://appliancejunk.com...wnloads;sa=view;down=390
I would check the wiring to/from the control board before replacing/repairing it.
Yes the board should be repairable, Google "appliance timer repair"
Maytag Gemini double oven electric (Oven Repair (including Ranges and Cooktops))
by mcelroy69 5/13/2020 10:22:20 AM(UTC)
Maytag Gemini Double Oven Throws Codes After Sensor Replacements (Oven Repair (including Ranges and Cooktops))
by Gfiocca 11/18/2014 9:53:30 AM(UTC)
Maytag Gemini Double oven not working (Oven Repair (including Ranges and Cooktops))
by MTODD101 11/14/2014 1:01:34 PM(UTC)
f1-1 again..... arrrgghhh gemini double oven (Oven Repair (including Ranges and Cooktops))
by The Country Toad 10/23/2013 2:18:18 PM(UTC)
Maytag Gemini double oven (Oven Repair (including Ranges and Cooktops))
by kdskattum@gmail.com 3/13/2013 6:34:31 PM(UTC)
Maytag Gemini double oven range (Oven Repair (including Ranges and Cooktops))
by Cstewart135 1/18/2013 2:02:46 PM(UTC)
by bobmullen364 1/6/2012 3:28:13 PM(UTC)
Maytag Gemini Double Oven - Oven lights sporadically (Microwave Repair)
by Marlee 7/4/2011 9:04:46 AM(UTC)
gemini double oven top broil not working (Oven Repair (including Ranges and Cooktops))
by jeff w 2/20/2011 7:13:00 AM(UTC)
maytag gemini double oven gas range (Oven Repair (including Ranges and Cooktops))
by debo 12/29/2009 6:40:14 PM(UTC)
Gemini Double Oven range 30" (Oven Repair (including Ranges and Cooktops))
by jkpinder 12/21/2009 1:00:24 PM(UTC)
