My oven is not heating up, and I have traced it down to the baking element, following threads in this forum. I have 240V to the terminals on the element, but infinite resistance when I measure across the element. My issue is that in this model of oven, I can't see the element inside the oven. The Broil element is exposed, but the baking element is covered, and I see no access panels or other convenient way to get it out to replace it. Does anyone have experience with this? I get that it will be some work, but I want to keep the dis-assembly to a minimum so that I am more likely to put it back together properly.
