I replaced the control board which is not avaliable so it had to be remanufactured. When I reset the breaker the display showed a pf and the time. I started pressing the buttons and three of them worked the rest did not. Then the display showed E1 F2 error code, which is the code for Keypad not attached...but it is attached. If not how do I get display out put from some buttons but not others?
