30 Inch door will not open several days after normal use. No cleaning was performed for months but main oven door feels like it is locked. Oven interior lighting does not come on, both ovens will not heat, no indicator lights will light but range has power because top burners igniters work fine. Both ovens have baking pans and frying pans carefully stored on racks inside. Cycling circuit breaker off for 5 minutes had no effect. Turning either oven switch to Bake, Broil, or Clean, etc has no effect. Seems like whole Oven section not getting any power. Help !!
PS: Came home the other day and found both blue oven indicator lights on, including red "cleaning" indicator light for main oven, even though both oven bake/broil/clean switches were off and no heating or cleaning was taking place, both ovens cold, main oven door still locked. Oven interior lights still inop. I keep the circuit breaker off now for safety sake.
