ld_edwards
#1 Posted : Tuesday, April 8, 2014 5:44:24 PM(UTC)
ld_edwards
While using the convection oven everything when out. No panel control or any light at all. Checked power supply to oven and found 240 volts. The oven had been cooking for apx 15 min when this happened. No noise or odor. I found 2 internal fuses and checked them--they tested fine but only one has power. What could have happened?
advown
#2 Posted : Friday, September 26, 2014 6:36:08 AM(UTC)
advown
Check TCOs. That is what went in mine.
GE Advantium - lower heat not working (Microwave Repair)
by Guest 1/3/2024 5:17:41 AM(UTC)
GE Advantium 120 lights work but wil not start or turn the glass (Microwave Repair)
by rayester 8/30/2023 2:00:44 PM(UTC)
GE Advantium combined Microwave and lower oven (Microwave Repair)
by Guest 1/29/2023 2:39:39 PM(UTC)
GE Advantium 120 Model ZSC1201J4SS (Microwave Repair)
by Guest 1/3/2022 1:01:33 PM(UTC)
GE Advantium 120 beeper intermittent (Microwave Repair)
by Guest 6/27/2021 9:42:23 AM(UTC)
GE Advantium turn table doesn't stop turning when door is closed and microwave is not in use. (Microwave Repair)
by mhoney3 4/27/2021 4:26:18 PM(UTC)
GE advantium SCA1001KSS01 (Microwave Repair)
by Twilldo 2/2/2020 8:42:26 AM(UTC)
GE Advantium 2011 OTR (Microwave Repair)
by mkemescher 11/8/2018 5:22:27 PM(UTC)
GE AdvantiumWall Oven/Microwave Hum/Buz (Microwave Repair)
by dmcc2201 1/3/2018 10:40:54 AM(UTC)
GE Advantium preheats but does not hold temperature (Oven Repair (including Ranges and Cooktops))
by dmclaude 4/15/2016 12:32:11 PM(UTC)
GE Advantium 120 Microwave not heating (Microwave Repair)
by Dnl221 4/3/2016 10:43:06 AM(UTC)
GE Advantium 120 Display Problem (Microwave Repair)
by RebrettaV 1/21/2016 6:26:36 PM(UTC)
Dead: GE Advantium 120 (SCA1000HBB04) TCO? (Microwave Repair)
by mbahr 3/23/2015 5:01:27 PM(UTC)
Ge Advantium:Convection Works, Microwave doesn't work (Microwave Repair)
by domsue 1/30/2014 10:30:17 AM(UTC)
GE Advantium 120 Oven (Microwave Repair)
by Terry K 12/9/2012 8:07:01 AM(UTC)
